TR/0603FA375-R
TR/0603FA375-R
    EATON(伊顿)
    一次性保险丝(熔断) 375mA 32V
TR/0603FA375-R 数据手册
Effective January 2019 Supersedes May 2017 Technical Data 4336 0603FA HALOGEN Fast-acting Chip™ surface mount fuse HF FREE Pb Environmental data • Operating temperature: -55 ºC to +125 ºC with proper derating • Load humidity test: MIL-STD-202, Method 103B • Moisture resistance test: MIL-STD-202, Method 106E • Thermal shock test: MIL-STD-202, Method 107D • High frequency vibration test: MIL-STD-202, Surface Mount Device Method 204D Product features • • • • AEC-Q200 qualified Fast-acting surface-mount fuse Satisfies the EIA/IS-722 standard Solder immersion compatible Ordering • Specify packaging and product code (i.e., TR/0603FA250-R) Agency information • UL Recognition Guide & File numbers: JDYX2 &E19180 • CSA Component Acceptance: 053787 C 000 & Class Number: 1422 30 100% 200% Soldering method 4 hours minimum 60 seconds maximum • Wave immersion: +260 °C, 10 seconds maximum • Infrared reflow: +260 °C, 30 seconds maximum P ar t Number 0603FA 250-R 0603FA 375-R 0603FA 500-R 0603FA 750-R 0603FA1-R 0603FA 1.25-R 0603FA 1.5-R 0603FA2-R 0603FA 2.5-R 0603FA3-R 0603FA 3.5-R 0603FA4-R 0603FA5-R C urrent R ating (A) 250 mA 375 mA 500 mA 750 mA 1 1.25 1.5 2 2.5 3 3.5 4 5 S pec ific ations Voltage R ating 50 Vdc 50 Vdc 32 Vac/50 Vdc 32 Vac/dc 32 Vac/dc 32 Vac/dc 32 Vac/dc 32 Vac/dc 32 Vac/dc 32 Vac/dc 32 Vac/dc 32 Vac/dc 32 Vac/dc Interrupting Rating (A) at Rated Voltage* 50 50 50 ac/35 dc 50 50 35 35 35 35 35 35 35 35 DC C old R es is tanc e** ( Ω) Typic al 3.100 1.250 1.025 0.450 0.150 0.108 0.086 0.051 0.037 0.028 0.022 0.017 0.011 Typic al Melting I2t*** 0.0004 0.0009 0.00193 0.0090 0.0025 0.0130 0.0319 0.0491 0.0625 0.0699 0.1200 0.2430 0.6950 Typic al Voltage Drop† 0.921 0.605 0.600 0.440 0.211 0.151 0.138 0.116 0.113 0.110 0.103 0.097 0.090 * DC Interrupting rating (Measured at designated voltage, time constant of less than 50 microseconds, battery source) ** DC Cold resistance (Measured at ≤10% of rated current) ***Typical melting I 2t (Measured with a battery bank at rated DC voltage, 10x-rated current, not to exceed IR, time constant of calibrated circuit less than 50 microseconds) (0603FA4A and 5A measured at interrupting rating) † Typical voltage drop (Measured at rated current after temperature stabilizes) ‡ Alpha code to be marked on the top of fuse body for all ratings A lpha C ode Marking‡ D E F G H J K N O P R S T 0603FA Fast-acting Chip™ surface mount fuse Technical Data 4336 Effective January 2019 T ime C urrent C urve Dimensions – mm/inches Drawing Not to Scale Recommended Pad Layout – mm/inches 0.50 (0.02) T ime in seconds 1.25 (0.05) 0.90 (0.035) Current (A) Packaging C ode P refix TR Packaging C ode Des cription 5,000 fuses on paper tape and reeled on a 178 mm (7 inch) diameter reel per EIA Standard 481-1 Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 4336 BU-SB10140 January 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners.
TR/0603FA375-R 价格&库存
很抱歉,暂时无法提供与“TR/0603FA375-R”相匹配的价格&库存,您可以联系我们找货
TR/0603FA375-R
