TR2-S505SC-2-R
TR2-S505SC-2-R
    EATON(伊顿)
    插件,D5.2xL20mm
    一次性保险丝(熔断) 2A 250V
TR2-S505SC-2-R 数据手册
Technical Data 10132 Effective January 2021 Supersedes December 2019 S505SC 5 mm x 20 mm Time-delay, axial lead ceramic tube fuses HALOGEN Pb HF FREE Applications Primary circuit protection: • Power supplies • LED lighting • LED/LCD televisions • Appliances and white goods • Printers Agency information Product features • Time-delay, high breaking capacity • Designed to IEC 60127-2 • Nickel-plated brass end cap construction • 5 mm x 20 mm physical size • cURus Recognition file number: E19180, Guide JDYX2/JDYX8 • SEMKO: File 1219335, 1310139 • VDE: File 40024252, 40037710 (1 A - 8 A) • BSI: File KM55676 • IMQ: File CA03.00529 • PSE/JET: JET1641-31003-1010, JET1641-310032002, JET7042-31003-2001 • CCC self declaration: 2020970207000210 • KC-Mark: File SU05011-12003, SU05011-12004, SU05011-12005A; SU05030-13003A, SU0503013004, SU05030-13005 • TUV: J50233218 Ordering • The ordering code is the part number replacing the “.” with a “-” plus adding the packaging prefix (i.e. S505SC-1.25-R; BK-S505SC1-25-R) Packaging prefixes • BK- (20 parts in a carrier, 5 carriers in a box) • TR2- (1500 parts per reel, tape width 52 mm) • TR3- (1500 parts per reel, tape width 54 mm) S505SC 5 mm x 20 mm Time-delay, axial lead ceramic tube fuses  Technical Data 10132 Effective January 2021 Electrical characteristics ln 1.5ln min minute 2.1ln max minute 2.75ln min ms max s 4ln min ms max s 10ln min ms max ms 1 A-3.15 A 60 30 750 80 95 5 10 150 4 A-6.3 A 60 30 750 80 150 5 10 150 8 A-10 A 30 30 750 80 150 5 10 150 Product specifications Part number5 Current rating (A) Voltage rating (Vac) Interrupting rating at rated voltage (50 Hz) (A) Typical DC cold resistance (Ω)2 Typical pre-arcing l2t (A2s)3 Typical voltage drop (mV)4 IMQ VDE SEMKO cURus PSE/ JET CCC KC BSI TUV S505SC-1-R 1.0 250 1500 0.169 1.38 180 x x x x x x x x x S505SC-1.25-R 1.25 250 1500 0.108 2.14 151 x x x x x x x x x S505SC-1.6-R 1.6 250 1500 0.070 7.35 130 x x x x x x x x x S505SC-2-R 2.0 250 1500 0.055 9.83 123.5 x x x x x x x x x S505SC-2.5-R 2.5 250 1500 0.040 19.9 119 x x x x x x x x x S505SC-3.15-R 3.15 250 1500 0.031 40.4 110 x x x x x x x x x S505SC-4-R 4.0 250 1500 0.018 41.0 89.8 x x x x x x x x x S505SC-5-R 5.0 250 1500 0.013 71.2 88 x x x x x x x x x S505SC-6.3-R 6.3 250 1500 0.010 152 72.5 x x x x x x x x x S505SC-8-R 8.0 250 1500 0.007 237 82.5 x x x x x x x x x S505SC-10-R 10 250 1500 0.005 353 70 x x x x x x x x 1 Interrupting ratings 1 A to 10 A were measured at 70% to 80% PF on AC. 2 Typical DC cold resistance measured at
TR2-S505SC-2-R 价格&库存
很抱歉,暂时无法提供与“TR2-S505SC-2-R”相匹配的价格&库存,您可以联系我们找货
