Effective December 2019
Supersedes January 2016
Technical Data 2621
SS-5
250 V Subminiature, radial leaded, time-delay fuses
HALOGEN
Pb HF
FREE
Product features
Applications
Primary and secondary circuit protection:
Power supplies
Notebooks and laptops
Appliances and white goods
Lighting ballasts
Power adapters
Set top boxes
LED/LCD televisions and displays
Air conditioners
Battery chargers
Radial leaded, time delay with low breaking
capacity
Agency information
Designed to IEC60127-3 Sheet 4
Plastic cap and base, flammability UL 94V0
UL Recognition: File E19180, Guide JDYX2/
JDYX8 (200 mA - 6.3 A)
Protects against harmful overcurrents in primary
and secondary applications
VDE: 40015513 (200 mA - 6.3 A)
Small rectangular-leaded design utilizes less
board space
CCC: 2019010207246964 (200 mA - 6.3 A)
High frequency vibration: MIL-STD-202F, Method
201A
PSE:
JET 1641-31007-1008 (1 A – 5 A)
JET 1641-31007-1009 (6.3 A)
KC:
SU05011-8001 (400 mA – 800 mA)
SU05011-8002 (1 A – 2.5 A)
SU05011-8003 (3.15 A – 6.3 A)
Semko:
1516697 (630 mA, 1 A – 4 A)
1124941 (500 mA, 800 mA, 5 A, 6.3 A)
Ordering
Use ordering number (see page 6 for details)
Packaging suffixes
-AP (1 000 parts Ammo pack, Pitch = 12.7)
-BK (200 parts in a polybag, Lead L = 4.3 ± 0.3)
-BK2 (200 parts in a polybag, Lead L = 21 ± 3.0)
SS-5
Technical Data 2621
Electrical characteristics
ln
1.5ln
minimum
minute
2.1ln
maximum
minute
2.75ln
minimum
ms
2.75ln
maximum
s
4ln
minimum
ms
4ln
maximum
s
10ln
minimum
ms
10ln
maximum
ms
200 mA – 6.3 A
60
2
400
10
150
3
Product specifications
Part number
Current
rating
(A)
Voltage
rating
(Vac )
SS-5-200mA
0.2
250
Interrupting rating at
rated voltage¹
Typical DC cold
(50 Hz) (Aac)
resistance2 (mΩ)
35
960
Typical melting3 Typical voltage
I2t (A2s)
drop4 (mV)
cURus
0.35
212
KC
X
VDE
CCC
X
X
PSE+
SEMKO JET1
SS-5-400mA
0.4
250
35
330
1.67
147
X
X
X
X
SS-5-500mA
0.5
250
35
258
1.79
152
X
X
X
X
X
SS-5-630mA
0.63
250
35
140
1.51
101
X
X
X
X
X
SS-5-800mA
0.8
250
35
118
4.21
111
X
X
X
X
X
SS-5-1A
1.0
250
35
80.8
7.40
94.5
X
X
X
X
X
X
SS-5-1.25A
1.25
250
35
62.4
12.8
93.5
X
X
X
X
X
X
SS-5-1.6A
1.6
250
35
41
23
71.5
X
X
X
X
X
X
SS-5-2A
2.0
250
35
31.2
29.8
75
X
X
X
X
X
X
SS-5-2.5A
2.5
250
35
24.3
40.3
74.5
X
X
X
X
X
X
SS-5-3.15A
3.15
250
35
16.8
67
62.5
X
X
X
X
X
X
SS-5-4A
4.0
250
40
12.8
87
65.4
X
X
X
X
X
X
SS-5-5A
5.0
250
50
7.35
120
43
X
X
X
X
X
X
SS-5-6.3A
6.3
250
63
7.4
176
59
X
X
X
X
X
X
1. 200 mA to 3.15 A measured at 35 A, 95% - 100% of PF on AC. 4 A – 6.3 A measured at 10 times of
rating current 95% - 100% of PF on AC.
2. Typical cold resistance measured at < 10% of rated current
3. I2t value is measured at 10In DC
4. Typical voltage drop measured at +20 °C ambient temperature and rated current
Dimensions and packaging – mm [in]
2
www.eaton.com/electronics
SS-5
Technical Data 2621
Time (s)
Time vs. current curve
3
Technical Data 2621
I2t (A2s)
I2t vs. time curve
4
SS-5
SS-5
Technical Data 2621
Temperature derating curve
Normal Operating Temperature: +25 °C ±2 °C
General specifications
Operating temperature: -40 °C to +125 °C with proper correction factor applied
Storage temperature: -10 °C to 40 °C
Solderability: EIA-186-9E Method 9
High frequency vibration test: Withstands 10-55 Hz per MIL-STD-202F, Method 201A
Endurance test: IEC60127-3/4
5
SS-5
Technical Data 2621
Ordering codes
The ordering code is the part number replacing the “.” with a
“-” plus adding the packaging suffix.
Packaging suffixes
Ordering codes
Part number
-AP option
-BK option
-BK2 option
SS-5-200mA
SS-5-200mA-AP
SS-5-200mA-BK
SS-5-200mA-BK2
SS-5-400mA
SS-5-400mA-AP
SS-5-400mA-BK
SS-5-400mA-BK2
SS-5-500mA
SS-5-500mA-AP
SS-5-500mA-BK
SS-5-500mA-BK2
SS-5-630mA
SS-5-630mA-AP
SS-5-630mA-BK
SS-5-630mA-BK2
SS-5-800mA
SS-5-800mA-AP
SS-5-800mA-BK
SS-5-800mA-BK2
SS-5-1A
SS-5-1A-AP
SS-5-1A-BK
SS-5-1A-BK2
SS-5-1.25A
SS-5-1-25A-AP
SS-5-1-25A-BK
SS-5-1-25A-BK2
SS-5-1.6A
SS-5-1-6A-AP
SS-5-1-6A-BK
SS-5-1-6A-BK2
SS-5-2A
SS-5-2A-AP
SS-5-2A-BK
SS-5-2A-BK2
SS-5-2.5A
SS-5-2-5A-AP
SS-5-2-5A-BK
SS-5-2-5A-BK2
SS-5-3.15A
SS-5-3-15A-AP
SS-5-3-15A-BK
SS-5-3-15A-BK2
SS-5-4A
SS-5-4A-AP
SS-5-4A-BK
SS-5-4A-BK2
SS-5-5A
SS-5-5A-AP
SS-5-5A-BK
SS-5-5A-BK2
SS-5-6.3A
SS-5-6-3A-AP
SS-5-6-3A-BK
SS-5-6-3A-BK2
6
SS-5
Technical Data 2621
Wave solder profile
tp
Tp
Temperature
First wave
Second wave
Tsmax
Tstyp
Tsmin
Preheat area
Cool down area
Time
Reference EN 61760-1:2006
Profile feature
Preheat
Standard SnPb solder
Lead (Pb) free solder
• Temperature min. (Tsmin)
100 °C
100 °C
• Temperature typ. (Tstyp)
120 °C
120 °C
• Temperature max. (Tsmax)
130 °C
130 °C
• Time (Tsmin to Tsmax) (ts)
70 seconds
70 seconds
D preheat to max Temperature
150 °C max.
150 °C max.
Peak temperature (TP)*
235 °C – 260 °C
250 °C – 260 °C
Time at peak temperature (tp)
10 seconds max
5 seconds max each wave
10 seconds max
Ramp-down rate
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
Time 25 °C to 25 °C
4 minutes
4 minutes
Manual solder
+350 °C (4-5 seconds by soldering iron), generally manual/hand soldering is not recommended
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2019 Eaton
All Rights Reserved
Printed in USA
Publication No. 2621 PCN19017M
December 2019
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“SS-5-1.6A-AP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.82618
- 200+0.70676
- 500+0.68192
- 1000+0.66960
- 国内价格 香港价格
- 1+14.490451+1.87043
- 5+12.032115+1.55311
- 10+11.1107710+1.43418
- 50+9.2170450+1.18974
- 100+8.50314100+1.09759
- 250+7.64229250+0.98647
- 500+7.04684500+0.90961
- 国内价格 香港价格
- 1000+11.818231000+1.52550
- 国内价格 香港价格
- 1000+9.282971000+1.19825
- 2000+8.549572000+1.10358
- 3000+8.145343000+1.05141
- 5000+7.660465000+0.98882
- 7000+7.355227000+0.94942
- 10000+7.3402510000+0.94749
