Effective December 2019
Supersedes October 2015
Technical Data 4416
SS-5H
250/300 V Subminiature, radial leaded, time-delay fuses
HALOGEN
Pb HF
FREE
Product features
Applications
Primary and secondary circuit protection:
Power supplies
Notebooks and laptops
Appliances and white goods
Lighting ballasts
Power adapters
Set top boxes
LED/LCD televisions and displays
Air conditioners
Battery chargers
Radial leaded, time delay with high breaking
capacity
Agency information
Designed to IEC60127-3
Plastic cap and base, flammability UL 94V0
UL Recognition: File E19180, Guide JDYX2/
JDYX8
Protects against harmful overcurrents in primary
and secondary applications
VDE: 40031800
Small rectangular-leaded design utilizes less
board space
TUV: J50190080
CCC: 2019010207246962
PSE: JET 1641-31007-1006 (1 A - 5 A); JET 164131007-1007 (6.3 A)
KC: SU05011-11001 (1 A ~ 2.5 A); SU05011-11002
(3.15 A ~ 6.3 A)
High frequency vibration: MIL-STD-202F, Method
201A
Ordering
The ordering code is the part number replacing
the “.” with a “-” plus adding the packaging suffix
(i.e. SS-5H-1.25A; SS-5H-1-25A-BK)
Packaging suffixes
250 V Version
-AP (1000 parts Ammo pack, Pitch =12.7 mm)
-BK (200 parts in a polybag, Lead L=4.3 ±0.3
mm)
-BK2 (200 parts in a polybag, Lead L=21 ±3.0
mm)
300 V Version
-APH (1000 parts Ammo pack, Pitch =12.7 mm)
-BKH (200 parts in a polybag, Lead L=4.3 ±0.3
mm)
-BK2H (200 parts in a polybag, Lead L=21 ±3.0
mm
SS-5H
Technical Data 4416
Electrical characteristics
ln
1.5ln
min
minute
2.1ln
max
minute
2.75ln
min ms
2.75ln
max s
4ln
min
ms
4ln
max
s
10ln
min
ms
10ln
max
ms
1A - 6.3A
60
2
400
10
150
3
Typical melting3
I2t (A2s)
Typical
voltage drop4
(mV)
Product specifications
Interrupting
rating at rated
voltage (50Hz)
AC (A)
Current
rating
(A)
Voltage
rating1 (Vac)
SS-5H-1A
1.0
250/300
100
78
7.4
SS-5H-1.25A
1.25
250/300
100
57
12.8
SS-5H-1.6A
1.6
250/300
100
43
SS-5H-2A
2.0
250/300
100
SS-5H-2.5A
2.5
250/300
100
SS-5H-3.15A
3.15
250/300
SS-5H-4A
4.0
250/300
SS-5H-5A
5.0
SS-5H-6.3A
6.3
Part number
Typical DC cold
resistance2 (mΩ)
KC1
PSE+
JET1
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
62.5
X
X
X
X
X
X
60.5
X
X
X
X
X
X
120
43
X
X
X
X
X
X
176
59
X
X
X
X
X
X
TUV1
94.5
X
X
87
X
X
23
79
X
31.2
29.8
75
23.0
40.3
73.5
100
17.5
67
100
12
87
250/300
100
7.35
250/300
100
7.4
1. CCC and KC-Mark voltage rating only 250 Vac. VDE, TUV, cURus and PSE voltage ratings given at
both 250 Vac and 300 Vac
2. Typical cold resistance (measured at
很抱歉,暂时无法提供与“SR-5H-4A-APH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+8.955161000+1.16390
- 5000+8.346565000+1.08480
- 国内价格
- 250+10.18063
- 500+8.57252
- 1000+7.23042
- 5000+4.54622
- 10000+3.13157
- 国内价格
- 1+2.27740
- 200+0.88139
- 500+0.85040
- 1000+0.83506
