SR-5H-1A-APH
SR-5H-1A-APH
    EATON(伊顿)
    插件,P=5.08mm
    一次性保险丝(熔断) 1A 250V
SR-5H-1A-APH 数据手册
Effective December 2019 Supersedes October 2015 Technical Data 4416 SS-5H 250/300 V Subminiature, radial leaded, time-delay fuses HALOGEN Pb HF FREE Product features Applications Primary and secondary circuit protection: • Power supplies • Notebooks and laptops • Appliances and white goods • Lighting ballasts • Power adapters • Set top boxes • LED/LCD televisions and displays • Air conditioners • Battery chargers • Radial leaded, time delay with high breaking capacity Agency information • Designed to IEC60127-3 • • Plastic cap and base, flammability UL 94V0 UL Recognition: File E19180, Guide JDYX2/ JDYX8 • Protects against harmful overcurrents in primary and secondary applications • VDE: 40031800 • Small rectangular-leaded design utilizes less board space TUV: J50190080 • • CCC: 2019010207246962 • PSE: JET 1641-31007-1006 (1 A - 5 A); JET 164131007-1007 (6.3 A) • KC: SU05011-11001 (1 A ~ 2.5 A); SU05011-11002 (3.15 A ~ 6.3 A) • High frequency vibration: MIL-STD-202F, Method 201A Ordering • The ordering code is the part number replacing the “.” with a “-” plus adding the packaging suffix (i.e. SS-5H-1.25A; SS-5H-1-25A-BK) Packaging suffixes 250 V Version • -AP (1000 parts Ammo pack, Pitch =12.7 mm) • -BK (200 parts in a polybag, Lead L=4.3 ±0.3 mm) • -BK2 (200 parts in a polybag, Lead L=21 ±3.0 mm) 300 V Version • -APH (1000 parts Ammo pack, Pitch =12.7 mm) • -BKH (200 parts in a polybag, Lead L=4.3 ±0.3 mm) • -BK2H (200 parts in a polybag, Lead L=21 ±3.0 mm SS-5H 250/300 V Subminiature, radial leaded, time-delay fuses  Technical Data 4416 Effective December 2019 Electrical characteristics ln 1.5ln min minute 2.1ln max minute 2.75ln min ms 2.75ln max s 4ln min ms 4ln max s 10ln min ms 10ln max ms 1A - 6.3A 60 2 400 10 150 3 20 150 Typical melting3 I2t (A2s) Typical voltage drop4 (mV) Product specifications Interrupting rating at rated voltage (50Hz) AC (A) Current rating (A) Voltage rating1 (Vac) SS-5H-1A 1.0 250/300 100 78 7.4 SS-5H-1.25A 1.25 250/300 100 57 12.8 SS-5H-1.6A 1.6 250/300 100 43 SS-5H-2A 2.0 250/300 100 SS-5H-2.5A 2.5 250/300 100 SS-5H-3.15A 3.15 250/300 SS-5H-4A 4.0 250/300 SS-5H-5A 5.0 SS-5H-6.3A 6.3 Part number Typical DC cold resistance2 (mΩ) KC1 PSE+ JET1 X X X X X X X X X X X X X X X X X X X X X X X X X 62.5 X X X X X X 60.5 X X X X X X 120 43 X X X X X X 176 59 X X X X X X TUV1 94.5 X X 87 X X 23 79 X 31.2 29.8 75 23.0 40.3 73.5 100 17.5 67 100 12 87 250/300 100 7.35 250/300 100 7.4 1. CCC and KC-Mark voltage rating only 250 Vac. VDE, TUV, cURus and PSE voltage ratings given at both 250 Vac and 300 Vac 2. Typical cold resistance (measured at
SR-5H-1A-APH 价格&库存
很抱歉,暂时无法提供与“SR-5H-1A-APH”相匹配的价格&库存,您可以联系我们找货
SR-5H-1A-APH
  • 250+10.18063
  • 500+8.57252
  • 1000+7.23042
  • 5000+4.54622
  • 10000+3.13157
库存:153
SR-5H-1A-APH
  • 1000+8.956751000+1.16390
  • 5000+8.348045000+1.08480
SR-5H-1A-APH
    • 1+2.27740
    • 200+0.88139
    • 500+0.85040
    • 1000+0.83506
