SS-5-1A-BK
SS-5-1A-BK
    EATON(伊顿)
    插件,P=5.08mm
    一次性保险丝(熔断) 1A 250V
SS-5-1A-BK 数据手册
Effective December 2019 Supersedes January 2016 Technical Data 2621 SS-5 250 V Subminiature, radial leaded, time-delay fuses HALOGEN Pb HF FREE Product features Applications Primary and secondary circuit protection: • Power supplies • Notebooks and laptops • Appliances and white goods • Lighting ballasts • Power adapters • Set top boxes • LED/LCD televisions and displays • Air conditioners • Battery chargers • Radial leaded, time delay with low breaking capacity Agency information • Designed to IEC60127-3 Sheet 4 • • Plastic cap and base, flammability UL 94V0 UL Recognition: File E19180, Guide JDYX2/ JDYX8 (200 mA - 6.3 A) • Protects against harmful overcurrents in primary and secondary applications • VDE: 40015513 (200 mA - 6.3 A) • Small rectangular-leaded design utilizes less board space CCC: 2019010207246964 (200 mA - 6.3 A) • • • High frequency vibration: MIL-STD-202F, Method 201A PSE: JET 1641-31007-1008 (1 A – 5 A) JET 1641-31007-1009 (6.3 A) • KC: SU05011-8001 (400 mA – 800 mA) SU05011-8002 (1 A – 2.5 A) SU05011-8003 (3.15 A – 6.3 A) • Semko: 1516697 (630 mA, 1 A – 4 A) 1124941 (500 mA, 800 mA, 5 A, 6.3 A) Ordering • Use ordering number (see page 6 for details) Packaging suffixes • -AP (1 000 parts Ammo pack, Pitch = 12.7) • -BK (200 parts in a polybag, Lead L = 4.3 ± 0.3) • -BK2 (200 parts in a polybag, Lead L = 21 ± 3.0) SS-5 250 V Subminiature, radial leaded, time-delay fuses  Technical Data 2621 Effective December 2019 Electrical characteristics ln 1.5ln minimum minute 2.1ln maximum minute 2.75ln minimum ms 2.75ln maximum s 4ln minimum ms 4ln maximum s 10ln minimum ms 10ln maximum ms 200 mA – 6.3 A 60 2 400 10 150 3 20 150 Product specifications Part number Current rating (A) Voltage rating (Vac ) SS-5-200mA 0.2 250 Interrupting rating at rated voltage¹ Typical DC cold (50 Hz) (Aac) resistance2 (mΩ) 35 960 Typical melting3 Typical voltage I2t (A2s) drop4 (mV) cURus 0.35 212 KC X VDE CCC X X PSE+ SEMKO JET1 SS-5-400mA 0.4 250 35 330 1.67 147 X X X X SS-5-500mA 0.5 250 35 258 1.79 152 X X X X X SS-5-630mA 0.63 250 35 140 1.51 101 X X X X X SS-5-800mA 0.8 250 35 118 4.21 111 X X X X X SS-5-1A 1.0 250 35 80.8 7.40 94.5 X X X X X X SS-5-1.25A 1.25 250 35 62.4 12.8 93.5 X X X X X X SS-5-1.6A 1.6 250 35 41 23 71.5 X X X X X X SS-5-2A 2.0 250 35 31.2 29.8 75 X X X X X X SS-5-2.5A 2.5 250 35 24.3 40.3 74.5 X X X X X X SS-5-3.15A 3.15 250 35 16.8 67 62.5 X X X X X X SS-5-4A 4.0 250 40 12.8 87 65.4 X X X X X X SS-5-5A 5.0 250 50 7.35 120 43 X X X X X X SS-5-6.3A 6.3 250 63 7.4 176 59 X X X X X X 1. 200 mA to 3.15 A measured at 35 A, 95% - 100% of PF on AC. 4 A – 6.3 A measured at 10 times of rating current 95% - 100% of PF on AC. 2. Typical cold resistance measured at < 10% of rated current 3. I2t value is measured at 10In DC 4. Typical voltage drop measured at +20 °C ambient temperature and rated current Dimensions and packaging – mm [in] 2 www.eaton.com/electronics SS-5 250 V Subminiature, radial leaded, time-delay fuses Technical Data 2621 Effective December 2019  Time (s) Time vs. current curve www.eaton.com/electronics 3 Technical Data 2621 Effective December 2019 I2t (A2s) I2t vs. time curve 4 www.eaton.com/electronics SS-5 250 V Subminiature, radial leaded, time-delay fuses  SS-5 250 V Subminiature, radial leaded, time-delay fuses Technical Data 2621 Effective December 2019  Temperature derating curve Normal Operating Temperature: +25 °C ±2 °C General specifications Operating temperature: -40 °C to +125 °C with proper correction factor applied Storage temperature: -10 °C to 40 °C Solderability: EIA-186-9E Method 9 High frequency vibration test: Withstands 10-55 Hz per MIL-STD-202F, Method 201A Endurance test: IEC60127-3/4 www.eaton.com/electronics 5 SS-5 250 V Subminiature, radial leaded, time-delay fuses  Technical Data 2621 Effective December 2019 Ordering codes The ordering code is the part number replacing the “.” with a “-” plus adding the packaging suffix. Packaging suffixes • -AP (1 000 parts Ammo pack, Pitch = 12.7) • -BK (200 parts in a polybag, Lead L = 4.3 ± 0.3) • -BK2 (200 parts in a polybag, Lead L = 21 ± 3.0) Ordering codes Part number -AP option -BK option -BK2 option SS-5-200mA SS-5-200mA-AP SS-5-200mA-BK SS-5-200mA-BK2 SS-5-400mA SS-5-400mA-AP SS-5-400mA-BK SS-5-400mA-BK2 SS-5-500mA SS-5-500mA-AP SS-5-500mA-BK SS-5-500mA-BK2 SS-5-630mA SS-5-630mA-AP SS-5-630mA-BK SS-5-630mA-BK2 SS-5-800mA SS-5-800mA-AP SS-5-800mA-BK SS-5-800mA-BK2 SS-5-1A SS-5-1A-AP SS-5-1A-BK SS-5-1A-BK2 SS-5-1.25A SS-5-1-25A-AP SS-5-1-25A-BK SS-5-1-25A-BK2 SS-5-1.6A SS-5-1-6A-AP SS-5-1-6A-BK SS-5-1-6A-BK2 SS-5-2A SS-5-2A-AP SS-5-2A-BK SS-5-2A-BK2 SS-5-2.5A SS-5-2-5A-AP SS-5-2-5A-BK SS-5-2-5A-BK2 SS-5-3.15A SS-5-3-15A-AP SS-5-3-15A-BK SS-5-3-15A-BK2 SS-5-4A SS-5-4A-AP SS-5-4A-BK SS-5-4A-BK2 SS-5-5A SS-5-5A-AP SS-5-5A-BK SS-5-5A-BK2 SS-5-6.3A SS-5-6-3A-AP SS-5-6-3A-BK SS-5-6-3A-BK2 6 www.eaton.com/electronics SS-5 250 V Subminiature, radial leaded, time-delay fuses Technical Data 2621 Effective December 2019  Wave solder profile tp Tp Temperature First wave Second wave Tsmax Tstyp Tsmin Preheat area Cool down area Time Reference EN 61760-1:2006 Profile feature Preheat Standard SnPb solder Lead (Pb) free solder • Temperature min. (Tsmin) 100 °C 100 °C • Temperature typ. (Tstyp) 120 °C 120 °C • Temperature max. (Tsmax) 130 °C 130 °C • Time (Tsmin to Tsmax) (ts) 70 seconds 70 seconds D preheat to max Temperature 150 °C max. 150 °C max. Peak temperature (TP)* 235 °C – 260 °C 250 °C – 260 °C Time at peak temperature (tp) 10 seconds max 5 seconds max each wave 10 seconds max 5 seconds max each wave Ramp-down rate ~ 2 K/s min ~3.5 K/s typ ~5 K/s max ~ 2 K/s min ~3.5 K/s typ ~5 K/s max Time 25 °C to 25 °C 4 minutes 4 minutes Manual solder +350 °C (4-5 seconds by soldering iron), generally manual/hand soldering is not recommended Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2019 Eaton All Rights Reserved Printed in USA Publication No. 2621 PCN19017M December 2019 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
SS-5-1A-BK 价格&库存
很抱歉,暂时无法提供与“SS-5-1A-BK”相匹配的价格&库存,您可以联系我们找货
SS-5-1A-BK
  • 5+22.06276
  • 50+21.50874
  • 100+21.18383
库存:80
SS-5-1A-BK
  • 85+10.97863
  • 200+10.18063
  • 1000+6.96442
库存:5600
SS-5-1A-BK
  • 200+14.09434200+1.81930
SS-5-1A-BK
    SS-5-1A-BK
