ATC-4
ATC-4
    EATON(伊顿)
    FUSE AUTO 4A 32VDC BLADE ATO/ATC
ATC-4 数据手册
Technical Data 2009 Effective May 2021 Supersedes December 2019 BUSSMANN SERIES ATC blade fuses Catalog symbol • ATC-_ Applications • Automotive and low-voltage control circuits. Ratings Volts: 32 V Amps: 1-40 A Interrupting Rating: 1 kA Agency information • UL Recognized File E56412, Guide JFHR2, UL 248-1 (1-40 A). Product description: • The Bussmann™ series ATC fuses are a range of UL® Recognized fast-acting blade fuses for automotive and low-voltage control circuits. ISO 8820-3 / SAE® J1284 / JASO 612 (1-40A). • SAE J1171 (Ignition Protection) see catalog number tables for specific orderable product. • RoHS complaint All catalog numbers for these fuses feature the same form, fit and electrical performance characteristics regardless of their housing materials. Features and benefits: Materials • Tin-plated zinc terminals • Tin-plated zinc element • Housing (see catalog number tables for specific housing materials) Housing flammability rating — UL 94 • Industry standard color coding for quick identification of amp rating. • • Tin-plated zinc terminals for corrosion resistance and enhanced conductivity. Environmental • UL Recognized for use in low voltage control circuits. • Wide -40°C to +100°C operating temperature range meets the needs of extreme environments. • Lead free, halogen free and RoHS complaint. • Test points on specific part/package numbers may speed up circuit troubleshooting. • Operating Temperature Range -40°C to 100°C, 95% RH non-condensing. • Storage Temperature Range -5°C to 35°C or lower, 85% RH non-condensing. Technical Data 2009 ATC blade fuses Effective May 2021 Basic catalog numbers* Basic catalog number (amp) ATC-1 ATC-2 ATC-3 ATC-4 ATC-5 ATC-7½ ATC-10 Color code Black Gray Violet Pink Tan Brown Red Basic catalog number (amp) ATC-15 ATC-20 ATC-25 ATC-30 ATC-35 ATC-40 Color code Blue Yellow Clear Green Blue/Green Orange * See catalog number tables on page four for specific construction, housing material and package availability. Electrical Characteristics** % of fuse amp rating 110 135 160 200 350 600 Operating time (sec) Min Max 100 Hrs 0.75 0.25 0.15 0.04 0.02 — 120 (240***) 50 5 0.5 0.1 ** At 23°C for all available catalog numbers., Fuse derating with change in ambient temperature = -0.15% / 1°C *** 135% Operating time of less than 4 amps. Dimensions — mm: 19.10 Test points on select constructions. See catalog number tables for details. 5.10 4.0 2.29 Recommended fuse panels, holders and fuseclips: Catalog No. Description easyID fuse panel with FP-ATC-(poles)ID cover, 4-, 6- and 10-pole versions Splash-proof fuse block with BP/FB(poles)-ATC cover, 4-, 6-, 8- and 10-pole versions Fuse panel in 4- to 15600-(poles)-20 ATC 20-poles Yellow, water resistant HHC in-line fuse holder Black, heavy-duty in-line HHD fuse holder Black, in-line fuse holder HHF w/cover Black, heavy-duty in-line HHG fuse holder w/cover Heavy-duty, water resistant HHR in-line fuse holder Self-stripping in-line fuse BP/HHS-RP holder BP/HHA-RP Add-a-Fuse Illuminating in-line fuse ATC-FHID holder 1A5600† PCB fuseclip 1A5780† PCB fuseclip † See data sheet no. 2131 for details. 2 Eaton.com/bussmannseries Max amps Lead wire length/size 100 1/4” quickconnect 20 per pole 1/4” quickconnect 20 — 18.70 6.42 0.65 20 2x4”/#16 30 2x4”/#12 20 2x4”/#14 30 2x4”/#12 30 2x5”/#12 20 #18 to #14 10 N/A 20 2x6”/#16 20 15 — — 4.0 3.65 14.5 Dimensions shown are basic for all ampacities, constructions and housing materials. ATC blade fuses 2009 Technical Data Effective May 2021 Time-current characteristic curves — average melt - for all fuse constructions/housing materials Temperature rerating curve RERATING FACTOR (% RATED CURRENT) 120 115 110 105 100 95 90 85 80 75 70 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 130 AMBIENT TEMPERATURE (˚C) Eaton.com/bussmannseries 3 Technical Data 2009 ATC blade fuses Effective May 2021 ATC fuse construction and housing material availability by catalog number ATC fuse catalog number availability for closed body housing with test points and SAE J1171 ignition protected Reload — — ATC-3RLD ATC-4RLD ATC-5RLD ATC-7½RLD ATC-10RLD ATC-15RLD ATC-20RLD ATC-25RLD ATC-30RLD — — — — Bulk packs* BK/ATC-1 BK/ATC-2 BK/ATC-3 BK/ATC-4 BK/ATC-5 BK/ATC-7½ BK/ATC-10 BK/ATC-15 BK/ATC-20 BK/ATC-25 BK/ATC-30 BK/ATC-35 BK/ATC-40 — — Blister packs BP/ATC-1-RP BP/ATC-2-RP BP/ATC-3-RP BP/ATC-4-RP BP/ATC-5-RP BP/ATC-7½-RP BP/ATC-10-RP BP/ATC-15-RP BP/ATC-20-RP BP/ATC-25-RP BP/ATC-30-RP — BP/ATC-40-RP — — 5-in tins** ATC-1 ATC-2 ATC-3 ATC-4 ATC-5 ATC-7½ ATC-10 ATC-15 ATC-20 ATC-25 ATC-30 ATC-35 ATC-40 — — Value packs — — — — VP/ATC-5RP VP/ATC-7½-RP VP/ATC-10-RP VP/ATC-15-RP VP/ATC-20-RP VP/ATC-25-RP VP/ATC-30-RP — — — — Assortments BP/ATC-A5-RP (fuse assortment) BP/ATC-AH8-RPP (fuse emergency kit) BP/ATC-AL8-RP (low amp assortment) DIA-1 (diagnostic kit) NO.44 (fuse emergency kit) NO.80 (bulk assortment) NO.95BK (ATC/ATM bulk assortment) NO.53 (ATC/MAX fuse emergency kit) NO.160BK (bulk assortment) NO.225 (tilt bin assortment) — — — CDY10TRY-ATC (fuse tray)*** NO.290† Housing material Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polycarbonate Polyamide Polyamide Polyamide Polyethersulfone Polyethersulfone — — * 2000 fuses per pack. ** 5 fuses per tin. *** Contains (5 each) – ATC 3, 4, 5, and 7½A (10 each) – ATC 10, 15, 20, 25, 30, 35 and 40A † Contains one 5-in tin each of ATC 3, 4, 5, 7-1/2, 10, 15, 20, 25, 30, 35 and 40A. See poly material column for details on the fuses in each tin of this assortment. The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2021 Eaton All Rights Reserved Printed in USA Publication No. 2009 — BU-MC19152 May 2021 4 Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. SAE is a registered trademark of the Society of Automotive Engineers. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
ATC-4
1. 物料型号:文档中列出了不同电流等级的ATC刀片式保险丝的基本目录编号和颜色代码,例如ATC-1(黑色)、ATC-15(蓝色)等。
2. 器件简介:Bussmann系列ATC保险丝是用于汽车和低电压控制电路的UL®认可的快速作用刀片式保险丝。所有型号具有相同的外形、适配性和电气性能。
3. 引脚分配:文档未明确提供引脚分配信息,但提到了保险丝的端子材料为镀锡锌。
4. 参数特性:包括额定电压32V、电流范围1-40A、中断额定值1kA。还提供了UL认证信息、产品描述、材料、特点和优势。
5. 功能详解:介绍了保险丝的工作环境温度范围(-40°C至100°C)、存储温度范围(-5°C至35°C)、无铅、无卤素和符合RoHS标准。
6. 应用信息:适用于汽车和低电压控制电路,符合ISO 8820-3 / SAE® J1284 / JASO 612标准。
7. 封装信息:提供了不同电流等级的保险丝的物理尺寸,以及推荐使用的保险丝面板、夹具和保险丝剪。
8. 电气特性:提供了不同熔断电流下的最小和最大操作时间。
9. 环境信息:强调了保险丝的环保特性,如无铅、无卤素和符合RoHS标准。
10. 测试点:特定部件/包装编号上可能有测试点,以加快电路故障排除。
ATC-4 价格&库存
很抱歉,暂时无法提供与“ATC-4”相匹配的价格&库存,您可以联系我们找货
ATC-4
    • 1+8.00280
    • 200+3.09960
    • 500+2.99160
    • 1000+2.93760
