Fast-Acting 1/4” x 1 1⁄4” Glass Tube Fuses
AGC Series
Dimensions - in
Description
Fast-acting
Optional axial leads available
1
⁄4” x 1 1⁄4” (6.3 x 32mm) physical size
Glass tube, nickel-plated brass endcap construction
UL Listed product meets standard 248-14
Agency Information
UL Listed Card: AGC 1⁄20-10
UL Recognition Card: AGC 11-40
CSA Component Acceptance Card (Class No. 1422 30)
CSA Certification Card (Class No. 1422 01)
Environmental Data
• Shock: 1⁄20 - 3⁄4A – MIL-STD-202, Method 213, Test Condition I; 1 - 30A –
MIL-STD-202, Method 207, (HI Shock)
• Vibration: 1⁄20 - 30A – MIL-STD-202,Method 204, Test Condition A
(Except 5g, 500Hz)
Ordering
• Specify packaging code prefix, part number and option code suffix
(if applicable)
Specifications
• See page 2
1116
Page 1 of 3
Data Sheet 2543
Part Number
AGC-1⁄20-R
AGC-1⁄10-R
AGC-1⁄8-R
AGC-3⁄16-R
AGC-2⁄10-R
AGC-1⁄4-R
AGC-3⁄10-R
AGC-3⁄8-R
AGC-1⁄2-R
AGC-3⁄4-R
AGC-1-R
AGC-1-1⁄4-R
AGC-1-1⁄2-R
AGC-2-R
AGC-2-1⁄4-R
AGC-2-1⁄2-R
AGC-3-R
AGC-4-R
AGC-5-R
AGC-6-R
AGC-7-R
AGC-7-1⁄2-R
AGC-8-R
AGC-9-R
AGC-10-R
AGC-12-R
AGC-14-R
AGC-15-R
AGC-20-R
AGC-25-R
AGC-30-R
AGC-35-R
AGC-40-R
AC Voltage
Rating
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
32
32
32
32
32
32
32
32
SPECIFICATIONS
AC Interrupting Rating (amps)
250
125
32
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
35
10,000
100
10,000
100
10,000
100
10,000
100
10,000
100
10,000
100
10,000
200
10,000
200
10,000
200
10,000
200
10,000
200
10,000
200
10,000
200
10,000
200
10,000
1000
1000
1000
1000
1000
1000
70
80
Typical DC Cold
Resistance* (Ω)
4.500
12.565
6.800
4.900
3.360
2.300
1.670
1.203
0.615
0.312
0.190
0.145
0.115
0.078
0.067
0.057
0.045
0.030
0.024
0.020
0.017
0.0146
0.014
0.012
0.008
0.0070
0.0062
0.006
0.004
0.003
0.002
0.0014
0.0019
Typical Melting
I2t† AC
0.00773
0.000787
0.00131
0.00637
0.00435
0.0148
0.0208
0.0321
0.269
0.815
1.615
0.018
0.0149
0.00509
0.00588
0.00879
0.0167
0.0305
0.045
0.071
0.105
0.152
0.21
0.492
0.566
1.438
2.109
3.807
* DC Cold Resistance (Measured at ≤10% of rated current)
† Typical Melting I2t (A2Sec) (I2t was measured at listed interrupting rating and rated voltage.)
‡ Typical Voltage Drop (Voltage drop was measured at 25°C ambient temperature at rated current)
1116
Page 2 of 3
Data Sheet 2543
Typical Voltage
Drop‡
0.67
6.00
4.67
4.12
4.51
0.89
2.88
4.59
0.59
0.37
0.31
0.35
0.27
0.28
0.26
0.31
0.25
0.22
0.23
0.23
0.23
0.19
0.18
0.20
0.14
0.12
0.11
0.12
Time-Current Curves
CURRENT IN AMPERES
1-1/2
2
2-1/2
3
4
3/4
1
2/10
1/4
3/10
3/8
1/2
CURRENT IN AMPERES
TIME IN SECONDS
1/10
1/8
1/16
TIME IN SECONDS
Packaging Code Prefix
Code
BK
BK1
Description
100 pieces of fuses packed into a cardboard carton with flaps folded
1000 pieces of fuses packed into a cardboard carton with flaps folded
Code
B
V
-R
Description
Board Washable - Hermetically sealed to withstand aqueous cleaning
Axial leads - copper tinned wire with nickel-plated brass overcaps
RoHS Compliant
Option Code Suffix
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended
to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or
construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin.
Once a product has been selected, it should be tested by the user in all possible applications.
Life Support Policy: Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems
are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant
injury to the user.
© 2013 Cooper Bussmann
www.cooperbussmann.com
1116
Page 2 of 3
Data Sheet 2543
很抱歉,暂时无法提供与“AGC-20-R”相匹配的价格&库存,您可以联系我们找货
