BK/AGC-V-25-R
BK/AGC-V-25-R
    EATON(伊顿)
    插件,D6.76xL32.82mm
    一次性保险丝(熔断) 25A 32V
BK/AGC-V-25-R 数据手册
Technical Data 2543 Effective April 2020 Supersedes May 2017 AGC 1/4” x 1-1⁄4” Fast-acting glass tube fuses Applications Primary circuit protection • Power supplies • Battery chargers • Monitors • Consumer electronics • Test equipment Agency information Product features • Fast-acting • Optional axial leads available • 1⁄4” x 1-1⁄4” (6.3 mm x 32 mm) physical size • Glass tube, nickel-plated brass end cap construction • UL Listed product meets standard 248-14 • UL Listed card: File E19180, Guide JDYX (AGC 1⁄10 A - 10 A) • UL Recognition card: File E19180, Guide JDYX2 (AGC 11 A - 40 A) • CSA Component acceptance card (Class No. 1422-30) • CSA Certification acceptance card (Class No. 1422--01) Ordering code The ordering code is the part number replacing the “/” with a “-” plus adding the packaging prefix and option code. BK- AGC- V- 1-10- R Packaging prefix Product code Option code Ampere rating RoHS compliant Packaging prefix • Blank (5 ferrule/cartridge parts in a 5 inch tin, 4 axial lead parts in a 5 inch tin) • BK- (100 parts packed into a cardboard carton with flaps folded) Option code • -B- (Board washable - Hermetically sealed to withstand aqueous cleaning) • -V- (Axial leads - copper tinned wire with nickel-plated brass end caps) AGC 1/4” x 1-1⁄4” Fast-acting glass tube fuses  Technical Data 2543 Effective April 2020 Electrical characteristics Amp Rating % of Amp Rating Opening Time 1/10 A – 40 A 100% 4 hours minimum 1/10 A – 40 A 135% 60 minutes maximum 1/10 A – 40 A 200% 120 seconds maximum Product specifications AC Interrupting rating (A) Current rating (A) Voltage rating (Vac) 250 V 125 V 32 V Typical DC cold resistance1 (Ω) Typical melting2 I²t (A2s) Typical voltage drop3 (V) AGC-1⁄10-R 0.1 250 35 10,000 1000 17.55 0.0010 15.168 AGC-1⁄8-R 0.125 250 35 10,000 1000 10.825 0.0020 10.854 AGC-3⁄16-R 0.1875 250 35 10,000 1000 6.050 0.0070 7.652 AGC-2⁄10-R 0.5 250 35 10,000 1000 4.800 0.0080 6.105 AGC-1⁄4-R 0.25 250 35 10,000 1000 1.550 0.0160 0.984 AGC-3⁄10-R 0.3 250 35 10,000 1000 1.084 0.0270 0.886 AGC-3⁄8-R 0.375 250 35 10,000 1000 0.703 0.0900 0.548 AGC-1⁄2-R 0.5 250 35 10,000 1000 0.483 0.3850 0.324 AGC-3⁄4-R 0.75 250 35 10,000 1000 0.272 1.7160 0.309 AGC-1-R 1.0 250 35 10,000 1000 0.167 3.2400 0.256 AGC-1-1⁄4-R 1.25 250 100 10,000 1000 0.122 5.0940 0.222 AGC-1-1⁄2-R 1.5 250 100 10,000 1000 0.077 9.0230 0.218 AGC-2-R 2.0 250 100 10,000 1000 0.063 17.520 0.199 AGC-2-1⁄4-R 2.25 250 100 10,000 1000 0.052 22.832 0.194 AGC-2-1⁄2-R 2.5 250 100 10,000 1000 0.045 28.688 0.193 AGC-3-R 3.0 250 100 10,000 1000 0.035 45.900 0.191 AGC-4-R 4.0 250 200 10,000 1000 0.024 86.560 0.179 AGC-5-R 5.0 250 200 10,000 1000 0.019 131.500 0.170 AGC-6-R 6.0 250 200 10,000 1000 0.015 144.360 0.165 AGC-7-R 7.0 250 200 10,000 1000 0.012 195.02 0.159 AGC-7-1⁄2-R 7.5 250 200 10,000 1000 0.012 216.00 0.155 AGC-8-R 8.0 250 200 10,000 1000 0.009 256.00 0.152 AGC-9-R 9.0 250 200 10,000 1000 0.009 395.28 0.148 AGC-10-R 10 250 200 10,000 1000 0.008 486.00 0.141 AGC-12-R 12 32 — — 1000 0.006 696.96 0.138 AGC-14-R 14 32 — — 1000 0.005 776.16 0.132 AGC-15-R 15 32 — — 1000 0.005 807.75 0.128 AGC-20-R 20 32 — — 1000 0.0034 2440.00 0.125 AGC-25-R 25 32 — — 1000 0.0027 3875.00 0.120 AGC-30-R 30 32 — — 1000 0.0024 4950.00 0.135 AGC-35-R 35 32 — — 1000 0.0021 7350.00 0.130 AGC-40-R 40 32 — — 1000 0.0016 11360.00 0.125 Part Number 1. DC cold resistance measured at
BK/AGC-V-25-R
物料型号:BUSSMANN AGC 1/4” x 1-1⁄4” 快速作用玻璃管保险丝。
器件简介:这是一种快速作用的玻璃管保险丝,具有可选的轴向引线,物理尺寸为1⁄4” x 1-1⁄4” (6.3 mm x 32 mm),由玻璃管和镀镍黄铜端盖构成。
引脚分配:文档中提到了两种引脚选项,一种是无引脚的,另一种是带有轴向引线(-V-)的,使用铜镀锡线和镀镍黄铜端盖。
参数特性:保险丝的电气特性包括在不同额定电流下的断开时间,例如在100%额定电流下至少4小时,在135%额定电流下最多60分钟,在200%额定电流下最多120秒。
功能详解:主要用于一次电路保护,如电源、电池充电器、监视器和消费电子产品以及测试设备。
应用信息:适用于电源电路保护,电池充电器,监视器,消费电子产品和测试设备。
封装信息:保险丝的订购代码是将部件编号中的“/”替换为“-”,并添加包装前缀和选项代码。例如,BK- AGC- V- 1-10- R,其中BK- 是包装前缀,AGC 是产品代码,V- 是选项代码表示轴向引线,1-10 是额定电流范围,R 表示符合RoHS标准。
BK/AGC-V-25-R 价格&库存
很抱歉,暂时无法提供与“BK/AGC-V-25-R”相匹配的价格&库存,您可以联系我们找货
BK/AGC-V-25-R
  • 65+14.29157
  • 100+13.21547
库存:300
