ATM-15
ATM-15
    EATON(伊顿)
ATM-15 数据手册
Effective December 2015 Supersedes February 2015 Technical Data 2048 BUSSMANN SERIES ATM blade fuses Catalog symbol: • Dimensions - in 0.43 (10.92) ATM 0.15 (3.81) Description: A range of UL® Listed fast-acting miniature blade fuses for automotive and low-voltage circuits. 0.344 ± 0.006 (8.75 ± 0.15) Ratings: • • • 0.295 ± 0.012 (7.5 ± 0.3) Volts – 32Vac/dc Amps – 2 to 30A Interrupting rating – 1kA Electrical characteristics (@ 23°C)* Agency information: • UL Listed • HALOGEN HF FREE • UL 275A Guide FHXT, File AU169 ISO 8820 / JASO D612 / SAE J2077 and J1171 ignition protection Materials: • Terminals and element • • Silver-plated zinc Polyamide, UL 94 HB flammability rating Environmental: • Operating temperature range -40°C to +100°C, 95% RH non-condensing • Storage temperature range -5°C to +35°C or lower, 85% RH non-condensing Basic part numbers Part number (amp) ATM-2 ATM-3 ATM-4 ATM-5 ATM-7½ Color Gray Part number (amp) ATM-10 Color Red Violet Pink Tan Brown ATM-15 ATM-20 ATM-25 ATM-30 Blue Yellow Clear Green Packaging codes ATM-(amp) ATM-(amp)RLD* BP/ATM-(amp)-RP VP/ATM-(amp)-RP BK/ATM-(amp) Five fuses packed in a tin 10 fuses in a polybag Five fuses in a retail blister card pack 25 fuses in a clamshell pack 500 fuses in a carton * Not available for the 4 amp ATM fuses. Operating time (sec) Min Max 110% 100 hrs. — 135% 0.75 sec. 600 sec. 160% 0.25 sec. 50 sec. 200% 0.15 sec. 5 sec. 350% 0.04 sec. 0.5 sec. 600% 0.02 sec. 0.1 sec. * Fuse characteristics may vary according to the conditions under which they are used. Fuse derating with change in ambient temperature: -0.15% / 1°C. Housing • % of fuse amp rating Features • Halogen free and RoHS compliant • Test points on fuses to speed troubleshooting • Industry standard color coded by amp rating Typical applications • Automotive • Low voltage control circuits Recommended fuse holders, add-a-circuit and fuseclips Part number Max volts/ amps Leadwire HHH Add-a-circuit for additional fused circuit on a block 32V/10A 5”/#16 HHL Inline fuse holder with cover 32V/20A 2x4”/#16 HHM Inline fuse holder with cover 32V/30A 2x4”/#12 HHU Water resistant inline fuse holder with cover 32V/30A 2x4”/#12 ATMFHID Indicating inline fuse holder with cover 32V/20A 2x4”/#16 1A5778** PCB fuse clip 32V/15A — PCB fuse clip with 1A5779** nylon base 32V/15A — Description ** See data sheet no. 2131 for details. ATM blade fuses Techncial Data 2048 Effective December 2015 Time in seconds Time-current characteristic curves – average melt Current in amps Cold resistance (mΩ) MAX MIN AVG 2A 3A 4A 5A 51.11 30.76 23.91 17.19 47.49 29.20 23.77 16.20 49.25 29.81 23.84 16.66 7.5A 11.39 10.74 11.09 10A 8.12 7.60 7.85 15A 5.15 4.68 4.89 20A 3.62 3.32 3.49 25A 2.63 2.45 2.56 30A 2.17 2.00 2.09 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 2048 – BU-SB15054 December 2015 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
ATM-15 价格&库存
很抱歉,暂时无法提供与“ATM-15”相匹配的价格&库存,您可以联系我们找货
ATM-15
    • 1+8.71560
    • 200+3.36960
    • 500+3.25080
    • 1000+3.19680
