Low-Profile ATM Fuses
32Vdc, 5 to 30A
Fast-Acting Automotive Blade Fuse
Dimensions - mm (in)
Catalog Symbol: ATM_LP
Fast-Acting
Volts: 32Vdc
Amps: 5 to 30A
IR: 1kA
Operating Temperature Range:
-40ºC to 125ºC
Features
• Similar performance characteristics as the standard MINI
fuse.
• Lower overall height allows for more space and weight
savings.
• Designed to mate with tuning-fork terminals for additional
weight and material savings in fuse panel designs
(eliminates the need for female box terminals).
Catalog Numbers (amps):
ATM-5LP
ATM-10LP
ATM-20LP
ATM-7-1/2LP
ATM-15LP
ATM-25LP
ATM-30LP
Time-Current Characteristics
% of Rating
110
135
200
350
600
08-08
BU-SB07465
Opening Time Minimum/Maximum
100 hr / –
750 m-sec / 1800 sec
150 m-sec / 5 sec
80 m-sec / 250 m-sec
30 m-sec / 100 m-sec
Page 1 of 2
Data Sheet 2050
Time-Current Curves - Average Melt
The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with
design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of
any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has
been selected, it should be tested by the user in all possible applications.
© 2008 Cooper Bussmann
St. Louis, MO 63178
636-394-2877
w w w. c o o p e r b u s s m a n n . c o m
08-08
BU-SB07465
Page 2 of 2
Data Sheet 2050
很抱歉,暂时无法提供与“ATM-20LP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+10.23840
- 200+3.96360
- 500+3.82320
- 1000+3.75840
