ATM-30LP
ATM-30LP
    EATON(伊顿)
ATM-30LP 数据手册
Low-Profile ATM Fuses 32Vdc, 5 to 30A Fast-Acting Automotive Blade Fuse Dimensions - mm (in) Catalog Symbol: ATM_LP Fast-Acting Volts: 32Vdc Amps: 5 to 30A IR: 1kA Operating Temperature Range: -40ºC to 125ºC Features • Similar performance characteristics as the standard MINI fuse. • Lower overall height allows for more space and weight savings. • Designed to mate with tuning-fork terminals for additional weight and material savings in fuse panel designs (eliminates the need for female box terminals). Catalog Numbers (amps): ATM-5LP ATM-10LP ATM-20LP ATM-7-1/2LP ATM-15LP ATM-25LP ATM-30LP Time-Current Characteristics % of Rating 110 135 200 350 600 08-08 BU-SB07465 Opening Time Minimum/Maximum 100 hr / – 750 m-sec / 1800 sec 150 m-sec / 5 sec 80 m-sec / 250 m-sec 30 m-sec / 100 m-sec Page 1 of 2 Data Sheet 2050 Time-Current Curves - Average Melt The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. © 2008 Cooper Bussmann St. Louis, MO 63178 636-394-2877 w w w. c o o p e r b u s s m a n n . c o m 08-08 BU-SB07465 Page 2 of 2 Data Sheet 2050
ATM-30LP 价格&库存
很抱歉,暂时无法提供与“ATM-30LP”相匹配的价格&库存,您可以联系我们找货
ATM-30LP
    • 1+10.23840
    • 200+3.96360
    • 500+3.82320
    • 1000+3.75840
