BK/S506-V-1.25R
BK/S506-V-1.25R
    EATON(伊顿)
    插件,D5.54xL21.1mm
    一次性保险丝(熔断) 1.25A 250V
BK/S506-V-1.25R 数据手册
Effective June 2017 Supersedes July 2009 Technical Data 4332 S506 5 mm x 20 mm Time-delay glass tube fuses Agency information Product features • • • • • Time-delay, low breaking capacity Optional axial leads available 5 x 20mm physical size Glass tube, nickel-plated brass endcap construction Designed to IEC 60127-2/3 (32mA-10A) & extensions:12.5A-15A • UL Recognized Card: Guide JDYX2, File E19180 • CSA Component Acceptance: Class number 1422-30&90 File 053787 • cURus Recognition: Guide JDYX8, File E19180 • SEMKO Approval: File 1518843, 1410180 • VDE Approval: File 40011926 • BSI Approval: File KM55676 • IMQ Approval: File E1921 • PSE/JET: File JET1641-31003-1019, JET1641-31003-1020 • CCC Approval: File 2005010207155693, 2002010207011294 • Ordering information • Specify product code • Insert packaging code prefix before part number. E.g. BK/ S506-1-R • Ratings above 4A have a 0.81mm diameter lead S506 Electrical Characteristics 2.1 In 2.75 In 4 In 10 In In max min max min max min max 32mA-100mA 2 min 200 ms 10 sec 40 ms 3 sec 10 ms 300 ms 125mA-6.3A 2 min 600 ms 10 sec 150 ms 3 sec 20 ms 300 ms 8A-15A 2 min 600 ms 10 sec 150 ms 3 sec 20 ms 300 ms Product Code S506-32-R S506-40-R S506-50-R S506-63-R S506-80-R S506-100-R S506-125-R S506-160-R S506-200-R S506-250-R S506-315-R S506-400-R S506-500-R S506-630-R S506-800-R S506-1-R S506-1.25-R S506-1.6-R S506-2-R S506-2.5-R S506-3.15-R S506-4-R S506-5-R S506-6.3-R S506-8-R S506-10-R S506-12.5-R S506-15-R Voltage Interrupting Rating (amps) at Rated Rating Voltage (50Hz) Vac Vac 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 35 250 40 250 50 250 63 250 80 250 100 250 125 250 125 Typical DC Cold Resistance (Ω)* 21.0 13.90 9.24 6.96 4.42 2.80 1.97 1.27 1.00 0.640 0.450 0.31 0.183 0.186 0.129 0.0757 0.060 0.0425 0.03325 0.0255 0.0185 0.0139 0.00985 0.0071 0.007 0.005 0.004 0.004 Typical Typical Melting I2t Voltage (amps) Drop (mV)‡ 0.0051 1050 0.0072 920 0.0095 800 0.021 760 0.038 580 0.045 490 0.063 390 0.093 320 0.114 340 0.265 270 0.621 250 0.872 210 0.827 140 1.33 150 2.78 75 6.45 87.5 10.05 86 21.7 82 31.6 77 59.4 72.5 96.4 68.5 71.8 67 142.5 60.5 237.6 54 255.8 55 450 54 1019.5 45 1091.7 65.5 * DC Cold Resistance (measured at
BK/S506-V-1.25R 价格&库存
很抱歉,暂时无法提供与“BK/S506-V-1.25R”相匹配的价格&库存,您可以联系我们找货
