Effective January 2024
Supersedes September 2023
Technical Data 4332
S506
5 mm x 20 mm Time-delay glass tube fuses
Agency information
Product features
Time-delay, low breaking capacity
Optional axial leads available
5 x 20 mm physical size
Glass tube, nickel-plated brass endcap construction
Designed to IEC 60127-1 & 2 (32 mA-10 A) &
extensions: (12.5 A-15 A)
• Operating temperature: -40 °C to +125 °C
• cURus Recognition: Guide JDYX8, JDYX2, File E19180
• CSA Component acceptance: Class number 1422-30&90 File
053787
• SEMKO Approval: File 1518843, 1410180
• VDE Approval: File 40011926
• BSI Approval: File KM55676
• IMQ Approval: File E1921
• PSE/JET: File
JET1641-31003-1019,JET1641-31003-1020,JET1641-31003-1021, J
ET1641-31003-1022
• KC File number: SU05011-6001, SU05011-6002,
SU05011-5005, SU05011-5006, SU05011-5007
• CCC Approval: File 2020970207000244
• Ordering information
• The ordering code is the part number replacing the “.” with a
“-” plus adding the packaging prefix:
Cartridge: S506-3.15-R; BK-S506-3-15-R
Axial lead: S506-3.15-R; BK-S506-V-3-15-R
• Ratings above 4 A have a 0.81 mm diameter lead
S506 Electrical characteristics
2.1 In
2.75 In
4 In
10 In
In
max min
max min
max min
max
32 mA-100 mA 2 min 200 ms 10 sec 40 ms 3 sec 10 ms 300 ms
125 mA-6 A
2 min 600 ms 10 sec 150 ms 3 sec 20 ms 300 ms
8 A-15 A
Specifications
Current
Voltage
rating (Vac) rating (A)
Interrupting rating
(A) at rated Voltage
(50 Hz) Vac
Typical DC
Typical
cold resistance melting I2t
(Ω)*
(A2s)
S506-32-R
250
0.032
35
21.0
0.0051
S506-40-R
250
0.040
35
13.90
0.0072
S506-50-R
250
0.050
35
9.24
0.0095
S506-63-R
250
0.063
35
6.96
S506-80-R
250
0.080
35
S506-100-R
250
0.100
S506-125-R
250
S506-160-R
250
S506-200-R
Part number
Typical
voltage drop
(mV)‡
Agency approvals
IMQ
VDE
BSI
SEMKO
UR
CCC
1050
X
X
X
X
X
X
920
X
X
X
X
X
X
800
X
X
X
X
X
X
X
0.021
760
X
X
X
X
X
X
X
4.42
0.038
580
X
X
X
X
X
X
X
35
2.80
0.045
490
X
X
X
X
X
X
X
0.125
35
1.97
0.063
390
X
X
X
X
X
X
X
0.160
35
1.27
0.093
320
X
X
X
X
X
X
X
250
0.200
35
1.00
0.114
340
X
X
X
X
X
X
X
S506-250-R
250
0.250
35
0.640
0.265
270
X
X
X
X
X
X
X
S506-315-R
250
0.315
35
0.450
0.621
250
X
X
X
X
X
X
X
S506-400-R
250
0.400
35
0.31
0.872
210
X
X
X
X
X
X
X
S506-500-R
250
0.500
35
0.183
0.827
140
X
X
X
X
X
X
X
X
S506-630-R
250
0.630
35
0.186
1.33
150
X
X
X
X
X
X
X
X
S506-800-R
250
0.800
35
0.129
2.78
75
X
X
X
X
X
X
X
X
S506-1-R
250
1.0
35
0.0757
6.45
87.5
X
X
X
X
X
X
X
X
X
S506-1.25-R
250
1.25
35
0.060
10.05
86
X
X
X
X
X
X
X
X
X
S506-1.6-R
250
1.6
35
0.0425
21.7
82
X
X
X
X
X
X
X
X
X
S506-2-R
250
2.0
35
0.03325
31.6
77
X
X
X
X
X
X
X
X
X
S506-2.5-R
250
2.5
35
0.0255
59.4
72.5
X
X
X
X
X
X
X
X
X
S506-3.15-R
250
3.15
35
0.0185
96.4
68.5
X
X
X
X
X
X
X
X
X
S506-4-R
250
4.0
40
0.0139
71.8
67
X
X
X
X
X
X
X
X
X
S506-5-R
250
5.0
50
0.00985
142.5
60.5
X
X
X
X
X
X
X
X
X
S506-6.3-R
250
6.3
63
0.0071
237.6
54
X
X
X
X
X
X
X
X
X
S506-8-R
250
8.0
80
0.007
255.8
55
X
X
X
X
X
X
X
X
S506-10-R
250
10
100
0.005
450
54
X
X
X
X
X
X
X
X
S506-12.5-R
250
12.5
125
0.004
1019.5
45
X
X
X
S506-15-R
250
15
150
0.004
1091.7
65.5
X
X
X
* DC cold resistance (measured at
