BK/GDA-63MA
BK/GDA-63MA
    EATON(伊顿)
    D5.2xL20mm
    一次性保险丝(熔断) 63mA 250V
BK/GDA-63MA 数据手册
Effective May 2017 Supersedes February 2009 Technical Data 2014 GDA 5 mm x 20 mm Fast-acting ceramic tube fuses Agency information • UL Recognized Card: Guide JDYX2, File E19180 • CSA Component Acceptance: File 53787 • Semko Approval: File 413779, File 512433 • IMQ Approval: File EB405 • CCC: File 2005010207155691 Product features Ordering • Fast-acting, high breaking capacity • 5 x 20mm physical size • Ceramic tube, nickel-plated brass endcap construction • Silver-plated endcap construction (50mA-400mA) • Optional axial leads are 0.032" x 1.5" copper tinned • Designed to IEC 60127-2 Part Number GDA-50mA GDA-63mA GDA-80mA GDA-100mA GDA-125mA GDA-160mA GDA-200mA GDA-250mA GDA-315mA GDA-400mA GDA-500mA GDA-630mA GDA-800mA GDA-1A GDA-1.25A GDA-1.6A GDA-2A GDA-2.5A GDA-3.15A GDA-4A GDA-5A GDA-6.3A Voltage Interrupting Rating (amps) Rating at Rated Voltage (50Hz) Vac Vac 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 250 1500 • Specify product code: Insert packaging code prefix before part number. E.g. BK/GDA-250mA • Specify option code if desired: For axial leads, insert “V” between catalog series and amp rating. E.g. BK/GDA-V-250mA In 50mA-3.15A 4A-10A Electrical Characteristics 1.5 I n 2.1 I n 2.75 I n min max min max 60 min 30 min 10 ms 2 sec 60 min 30 min 10 ms 3 sec Specifications Typical DC Cold Resistance (Ω)* 157.5 39.0 27.9 20.0 12.3 8.5 6.0 4.4 3.3 2.2 0.460 0.340 0.245 0.231 0.176 0.113 0.073 0.053 0.037 0.027 0.019 0.014 Typical Typical Melting I 2t Voltage (amps) Drop (mV)‡ 0.0017 9000 0.0005 3300 0.0011 2600 0.0018 2300 0.0037 1900 0.008 1600 0.020 1350 0.027 1300 0.010 1400 0.018 1200 0.038 1050 0.064 1200 0.097 490 0.146* 330 0.313* 297 0.748* 239 2.0 205 3.9 190 8.1 160 14 160 25 155 48 150 ‡ Typical Voltage Drop (Voltage drop was measured at 20ºC ambient temperature at rated current) *I2t of 1A, 1.25A, 1.6A is measured at 10I n DC. **CSA Approvals on these ratings will not be marked on the fuse cap. IMQ X Agency Approvals SEMKO UR CCC X X X X X X X X X X X X X X X X X X X X X X X X X X X X X min 3 ms 3 ms X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X 4 In 10 I n max max 300 ms 20 ms 300 ms 20 ms CSA X X X X X X X X X X X X X** X** X** X** X** X  Technical Data 2014 Effective May 2017  Time-Current Curve Dimensions - mm Drawing Not to Scale Amp Rating Time In Seconds • With TR2 packaging code, lead wire length is 19.05mm Current In Amps Option Code Option Code V Description Axial leads - copper tinned wire with nickel-plated brass endcaps Packaging Code BK BK1 TR2 Description 100 fuses packed into a cardboard carton 1,000 fuses packed into a poly bag 1,500 fuses packed into tape on a reel (19.05mm lead wire length) Packaging Code Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 2014 BU-SB08725 May 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
BK/GDA-63MA 价格&库存
很抱歉,暂时无法提供与“BK/GDA-63MA”相匹配的价格&库存,您可以联系我们找货
BK/GDA-63MA
