BK/GFA-12
BK/GFA-12
    EATON(伊顿)
    轴向
    FUSE BOARD MOUNT 12A 32VAC AXIAL
BK/GFA-12 数据手册
™ PC Board Fuses - Sub Miniature with Leads GFA, GLN and GLX Series Catalog Symbol: GFA Sub Miniature with Axial Leads Non Time-Delay 0.145˝ x 0.300˝ (3.7mm x 7.6mm) Interrupting Rating: 50 AIC Agency Approvals: UL Recognized, (1⁄2-5A) Guide JDYZ2, File 19180 CSA Certified, (1⁄2-5A) File 53787, Class 1425-01 Catalog Symbol: GLN Sub Miniature with Radial Leads Non Time-Delay 0.145˝ x 0.300˝ (3.7mm x 7.6mm) Interrupting Rating: 50 AIC Electrical Ratings (Catalog Symbol and Amps) 125 Volts AC Electrical Ratings (Catalog Symbol and Amps) 125 Volts AC Amps Test Spec. Color Code (Opp. Ends) Amps Test Spec. Color Code (Opp. Ends) GLN-1⁄100 A Red Orn GLN-1⁄10 A Red Red GLN- ⁄32 A Red Brn GLN-3⁄10 A Grn Grn GLN-1⁄20 A Yel Yel GLN-4⁄10 A Blu Blu GLN-1⁄16 A Brn Brn — Amps Test Spec. Color Code (Opp. Ends) Grn GLN-10 A Yel Blk — Amps Test Spec. Color Code (Opp. Ends) Amps Test Spec. Color Code (Opp. Ends) GFA-1⁄200 A Red Blk GFA-3⁄10 A Grn Grn GFA- ⁄100 A Red Orn GFA- ⁄10 A Blu Blu GFA- ⁄64 A Red Grn GFA- ⁄2 B Orn Grn GFA-1⁄50 A Red Wht GFA-6⁄10 B Orn Blu GFA-1⁄32 A Red Brn GFA-3⁄4 B Orn Pur 32 Volts AC GFA- ⁄20 A Yel Yel GFA-1 B Yel Grn Amps GFA- ⁄16 A Brn Brn GFA-1 ⁄2 B Yel Pur Test Spec. Color Code (Opp. Ends) GFA-1⁄10 A Red Red GFA-2 B Grn Blu GLN-7 A Pur GFA-1⁄8 A Orn Orn GFA-2 1⁄2 B Grn Brn GLN-8 A Grn GFA-15⁄100 B Red Yel GFA-3 B Blu Pur GFA-2⁄10 B Red Blu GFA-4 B Pur Brn GFA-1⁄4 B Red Pur GFA-5 B Brn Blk Test Spec. Color Code (Opp. Ends) Amps Test Spec. Color Code (Opp. Ends) GFA-7 A Pur Grn GFA-12 A Blk Blu GFA-8 A Grn Blk GFA-15 A Blk Pur GFA-10 A Yel Brn — 1 1 1 1 4 1 1 32 Volts AC Amps Test Specifications Wire Lead Size Load “A” 100% 4 hrs. (min.) — 24 1 150% — 10 sec. (max.) 18 6 to 12A 200% 10 sec. — 16 15A “B” No. Fuse ⁄200 to 5A Carton Quantity and Weight ⁄200–15 *Weight per carton. 1 Test Specifications Weight* Carton Qty. Lbs. Kg. 100 0.171 52.6 Wire Lead Size Load “A” “B” No. Fuse 110% 4 hrs. (min.) — 24 1 150% — *10 sec. (max.) 18 6A to 10A 200% *10 sec. — — BU-SB12568 ⁄200 to 5A *Maximum time. Carton Quantity and Weight ⁄100–10 *Weight per carton. 1 Weight* Carton Qty. Lbs. Kg. 100 0.171 52.6 General Information: • Glass tube fuses for protection of subminiature devices. • Tinned radial leads spaced for easy assembly on printed circuit chassis. • Withstand high-shock and vibration. • Color-coded for amp rating. • Radial leads (1 1⁄2˝ ) can be fed through wire forming machine. General Information: • Glass tube fuses for protection of subminiature devices. • Tinned wire leads solder into circuit. • Withstand high-shock and vibration. • Color-coded for amp rating. • Axial leads (1 1⁄2˝ ) can be fed through wire forming machine. 0712 Brn Opening Time Amp Ratings Opening Time Amp Ratings 1 Page 1 of 2 Data Sheet 2035 ™ PC Board Fuses - Sub Miniature with Leads GFA, GLN and GLX Series 15 AMP RATING ATING 1-⁄Ω™ 2 3 4 5 7 8 10 ‹Ω¢ 1 flΩ¡º ⁄Ω¢ ‹Ω¡º ›Ω¡º ⁄Ω¡º ⁄Ω• ⁄Ω£™ ⁄Ω™º ⁄Ω™ Time-Current Characteristics–Total Clear 100 Catalog Symbol: GLX Sub Miniature with Radial Leads Non-Time-Delay 0.145˝ x 0.300˝ (3.7mm x 7.6mm) Interrupting Rating: 50 AIC 10 Amps Test Spec. Color Code (Opp. Ends) Amps Test Spec. Color Code (Opp. Ends) GLX-1⁄4 B Red Pur GLX-2 B Grn Blu GLX-1⁄2 B Orn Grn GLX-3 B Blu Pur GLX-3⁄4 B Orn Pur GLX-4 B Pur Brn GLX-1 B Yel Grn GLX-5 B Brn Blk GLX-1 1⁄2 B Yel Pur — TIME IN SECONDS Electrical Ratings (Catalog Symbol and Amps) 125 Volts AC 1 Wire Lead Size No. Fuse 24 1 ⁄200 to 5A .1 Carton Quantity and Weight 52.6 .01 General Information: • Glass tube fuses for protection of subminiature devices. • Tinned radial leads spaced for easy assembly on printed circuit chassis. • Withstand high-shock and vibration. • Color-coded for ampere rating. • Radial leads (1 1⁄2˝ ) can be fed through wire forming machine. 30 0.171 10 Kg. 100 1 Lbs. .1 ⁄4–5 *Weight per carton. 1 Weight* Carton Qty. .04 Amp Ratings CURRENT IN AMPS The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled.This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 0712 BU-SB12568 Page 2 of 2 Data Sheet 2035
BK/GFA-12 价格&库存
很抱歉,暂时无法提供与“BK/GFA-12”相匹配的价格&库存,您可以联系我们找货
