BK/PCC-2
BK/PCC-2
    EATON(伊顿)
    BK/PCC-2
BK/PCC-2 数据手册
Effective December 2017 Supersedes September 2014 Technical Data 2034 PC-Tron Subminiature radial leaded fast-acting fuses Agency information • UL Recognized: E19180 • CSA: 053787 Ordering information • Specify packaging code prefix, product and option code suffix BK 1/2 -R Packaging Code Prefix Fuse Series Amp Rating Option Code Suffix DC Application The PC-Tron subminiature fuse is UL Recognized for DC supplementary overcurrent protection to provide individual protection for components or internal circuits in equipment. Suitability for a specific application is dependent on time constants and capacitance values. It is the responsibility of the customer to evaluate the information provided for applicability to their particular application. Product features • • • • • PCB- Radial leaded, fast-acting thru-hole fuse Ideal for high voltage DC applications Board washable Optional mounting socket available (PCS) Available in different lead configurations AC Time-Current Characteristics % of Amp Rating Opening Time 100% 4 hours minimum 200% 10 second maximum • PCS Mounting Socket (RoHS compliant): Available as option. Specify catalog number BK/PCS (100 in a polybag) and short fuse lead length — PCC or PCE Specifications Catalog Number PCB-1/2, 3/4, 1, 1- 1/2, 2, 2- 1/2 PCB-3 PCB-4 PCC-1/2, 3/4, 1, 1- 1/2, 2, 2- 1/2 PCC-3 PCC-4 PCD-5 PCE-5 PCF-1/2, 3/4, 1, 1- 1/2, 2, 2- 1/2 PCF-3 PCG-5 PCH-1/2, 3/4, 1, 1- 1/2, 2, 2- 1/2 PCH-3 PCH-4 PCI-5 Lead Length Full - 0.750" (straight) Full - 0.750" (straight) Full - 0.750” (straight) Short 0.100" (straight) Short 0.100" (straight) Short 0.100" (straight) Full - 0.750" (straight) Short 0.100" (straight) 0.475" 0.475" 0.475" 0.125" 0.125" 0.125" 0.125" AC Voltage Rating 250V 250V 250V 250V 125V 125V 250V 250V 125V 250V 250V 125V AC Interrupting 50A@250V - 10kA@125V 50A@250V 50A@250V - 10kA@125V 50A@250V - 10kA@125V 10kA@125V 10kA@125V 50A@250V - 10kA@125V 50A@250V - 10kA@125V 10kA@125V 50A@250V - 10kA@125V 50A@250V - 10kA@125V 10kA@125V DC Voltage Rating 450V 450V 450V 450V 450V 450V 400V 400V 450V 450V 400V 450V 450V 450V 400V DC Interrupting Min. Max. 300 5900A 300 4400A 300 2500A 300 5900A 300 4400A 300 2500A 300 1000A 300 1000A 300 5900A 300 4400A 300 1000A 300 5900A 300 4400A 300 2500A 300 1000A Device designed to carry rated current for four hours minimum. An operating current of 80% or less of rated current is recommended, with further derating required ambient temperatures. PC-Tron Subminiature radial leaded fast-acting fuses Technical Data 2034 Effective December 2017 Dimensions- inches/mm 0.350" 1.5 2 2.5 3 4 5 10 0.184" 0.75 1 (PCB, PCD) 0.5 Time-Current Characteristic Curves–Average Melt Amp Rating (4.67mm) (8.89mm) 0.025" (0.64mm) 0.020" (0.51mm) 0.20" (5.08mm) 0.015" 0.750" Full (19.1mm) (0.38mm) 0.100" Short 1 Time In Seconds PC___ 0.320" (8.13mm) (2.54mm) .1 (PCH, PCI) 0.184" 0.350" (4.67mm) (8.89mm) 0.345" 0.020" Current In Amps (0.51mm) 0.200" ± 0.008 200 .01 10 (0.64mm) 100 0.025" (8.76mm) 1 PC___ 250V .4 BUSS 0.015" (0.51mm ± 0.127mm) (0.38mm) 0.075" 0.15" (1.91mm) (3.81mm) Max. Total Clearing I2t (Amps2 Sec.) (PCF, PCG) 0.184" 0.350" BUSS PC___ 125V 0.345" 0.025" 0.500" MIN. 0.020" 0.400" REF. 0.015" Amp Rating 1 /2A 3 /4A 1A 1-1/2A 2A 2-1/2A 3A 5A 125Vac 50A 0.006 0.016 0.020 0.090 0.200 0.300 0.750 5.0 1,000A 0.006 0.016 0.020 0.090 0.200 0.300 0.750 5.0 10,000A 0.006 0.016 0.020 0.090 0.200 0.300 0.750 5.0 250Vac 35A & 50A 0.006 0.016 0.020 0.090 0.200 0.300 0.750 — Note: Power Factor > 0.90. Packaging Code Prefix Blank BK TR* Packaging Code Description/Quantity 5 fuses 100 fuses in a carton 500 fuses on Tape-and-Reel Option Code Suffix -R -SD Option Code Description RoHS Compliant Solder Dipped * Only for PCB and PCD Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 2034 BU-SB11083 December 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
BK/PCC-2 价格&库存
很抱歉,暂时无法提供与“BK/PCC-2”相匹配的价格&库存,您可以联系我们找货
