BK/C520-3.5A
BK/C520-3.5A
    EATON(伊顿)
    FUSE_D4.5X14.48MM
    FUSE GLASS 3.5A 250VAC 2AG
BK/C520-3.5A 数据手册
5mm x 15mm Fuses C520 Series, Fast Acting, Glass Tube Description • Fast acting • 5mm x 15mm physical size • Glass tube, nickel-plated brass endcap construction • Optional sleeve is flexible flouropolymer (U.L. flammability rating VW-1). • UL Listed product meets standard UL 248-14 ELECTRICAL CHARACTERISTICS Rated Current Amp Rating Opening Time 100% None 100mA - 5A 135% 1 hours max. 200% 2 seconds max. RoHS 2002/95/EC Dimensions Drawing Not to Scale Agency Information • UL Listed Card: Guide JDYX, File E19180 • CSA Certification Card: Class 1422-01, LR65063 Ordering • Specify packaging, product, and option code • For -R option, drop mA or A from product code (i.e. C520-3-R) SPECIFICATIONS Product Code C520-100mA C520-125mA C520-250mA C520-375mA C520-500mA C520-750mA C520-1.5A C520-2A C520-2.5A C520-3A C520-3.5A C520-4A C520-5A Voltage Rating AC 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V Interrupting Rating at Rated Voltage 250VAC 125VAC 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 35A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 100A 10,000A 200A 10,000A 10,000A 200A Typical DC Cold Resistance* (ohms) 22.30 15.20 5.60 2.53 1.66 0.91 0.900 0.064 0.046 0.038 0.032 0.022 0.018 * DC Cold Resistance (Measured at
BK/C520-3.5A 价格&库存
很抱歉,暂时无法提供与“BK/C520-3.5A”相匹配的价格&库存,您可以联系我们找货
