BK/GDC-400MA
BK/GDC-400MA
    EATON(伊顿)
    FUSE_D5X20MM
    FUSE GLASS 400MA 250VAC 5X20MM
BK/GDC-400MA 数据手册
5 x 20mm Fuses GDC Series, Time-Delay, Glass Tube Description • Time-delay, low breaking capacity • Optional axial leads available • 5 x 20mm physical size • Glass tube, nickel-plated brass endcap construction • Designed to IEC 60127-2 (32mA-10A) Electrical Characteristics 2.1 In 2.75 In 4 In In max min max min max 32mA-100mA 2 min 200 ms 10 sec 40 ms 3 sec 125mA-6.3A 2 min 600 ms 10 sec 150 ms 3 sec 10 In min max 10 ms 300 ms 20 ms 300 ms Agency Information • cURus Recognition: Guide JDYX2/JDYX8, File E19180 • IMQ Approval: File E1921, CA03.00530 • MITI/JET: File JET1641-31003-1005 Ordering • Specify packaging, product, and option code • With TR2 packaging code, lead wire length is 19.05mm Dimensions - mm Drawing Not to Scale Specifications Voltage Interrupting Rating (amps) Typical DC Product Code Rating at Rated Voltage (50Hz) Cold Resistance Vac Vac (Ω)* GDC-32mA 250 35 21.0 GDC-40mA 250 35 13.90 GDC-50mA 250 35 9.24 GDC-63mA 250 35 6.96 GDC-80mA 250 35 4.42 GDC-100mA 250 35 2.80 GDC-125mA 250 35 1.97 GDC-160mA 250 35 1.27 GDC-200mA 250 35 1.00 GDC-250mA 250 35 0.640 GDC-315mA 250 35 0.450 GDC-400mA 250 35 0.31 GDC-500mA 250 35 0.183 GDC-630mA 250 35 0.186 GDC-800mA 250 35 0.129 GDC-1A 250 35 0.0757 GDC-1.25A 250 35 0.060 GDC-1.6A 250 35 0.0425 GDC-2A 250 35 0.03325 GDC-2.5A 250 35 0.0255 GDC-3.15A 250 35 0.0185 GDC-4A 250 40 0.0139 GDC-5A 250 50 0.00985 GDC-6.3A 250 63 0.0071 Typical Melting I2t (amps) 0.0051 0.0072 0.0095 0.021 0.038 0.045 0.063 0.093 0.114 0.265 0.621 0.872 0.827 1.33 2.78 6.45 10.05 21.7 31.6 59.4 96.4 71.8 142.5 237.6 Typical Agency Approvals Voltage Drop (mV)‡ cURus IMQ MITI/JET 1050 X X 920 X X 800 X X 760 X X 580 X X 490 X X 390 X X 320 X X 340 X X 270 X X 250 X X 210 X X 140 X X 150 X X 75 X X 87.5 X X X 86 X X X 82 X X X 77 X X X 72.5 X X X 68.5 X X X 67 X X X 60.5 X X X 54 X X X * DC Cold Resistance (measured at
BK/GDC-400MA 价格&库存
很抱歉,暂时无法提供与“BK/GDC-400MA”相匹配的价格&库存,您可以联系我们找货
