Chip™ Fuses
0603FA Series, Fast Acting
Description
• Rapid interruption of excessive current
• Compatible with reflow and wave solder
• Rugged ceramic and glass construction
• Excellent environmental integrity
• One time positive disconnect
• 100% tin (lead free) plating option available
• Compatible with lead free solders and higher
temperature profiles
ELECTRICAL CHARACTERISTICS
% of Amp Rating
Opening Time
100%
4 Hours Minimum
200%
60 Seconds Maximum
Dimensions
mm
⁄(inches)
Drawing Not to Scale
Agency Information
• UL Recognition Card: JDYX2, E19180
• CSA Component Acceptance Card: 053787 C 000,
Class Number 1422 30
Environmental Data
• Life Test: MIL-STD-202, Method 108A
• Load Humidity Test: MIL-STD-202, Method 103B
• Moisture Resistance Test: MIL-STD-202, Method 106E
• Terminal Strength Test: Downward force is applied to
cause a 1mm deflection for 1 minute
• Thermal Shock Test: MIL-STD-202, Method 107D
• Solderability: ANSI/J-STD-002
• Mechanical Shock Test: MIL-STD-202, Method 213B
• High Frequency Vibration Test: MIL-STD-202,
Method 204D
• Resistance to Solvents Test: MIL-STD-202, Method 215A
Ordering
• Specify product code and packaging code
• Specify “-T” for lead free plating
Land Pattern
1.25
(0.05)
0.50
(0.02)
0.90
(0.035)
Soldering Method
• Wave Solder: 260°C, 10 sec max.
• Infrared Reflow: 260°C, 30 sec max.
SPECIFICATIONS
Product Code
0603FA250mA
0603FA375mA
0603FA500mA
0603FA750mA
0603FA1A
0603FA1.25A
0603FA1.5A
0603FA2A
0603FA2.5A
0603FA3A
0603FA3.5A
0603FA4A
0603FA5A
Voltage
Rating
DC
32V
32V
32V
32V
32V
32V
32V
32V
24V
24V
24V
24V
24V
Interrupting
Rating at
Rated Voltage*
50A
50A
50A
50A
50A
35A
35A
35A
35A
35A
35A
35A
35A
DC Cold
Resistance** (ohms)
Typical
3.100
1.250
1.025
0.450
0.150
0.108
0.086
0.051
0.037
0.028
0.022
0.017
0.011
Typical
Melting
I2t***
0.0004
0.0009
0.00193
0.0090
0.0025
0.0130
0.0319
0.0491
0.0625
0.0699
0.1200
0.2430
0.6950
Typical
Voltage
Drop†
0.921
0.605
0.600
0.440
0.211
0.151
0.138
0.116
0.113
0.110
0.103
0.097
0.090
Alpha
Code
Marking‡
D
E
F
G
H
J
K
N
O
P
R
S
T
* DC Interrupting Rating (Measured at designated voltage, time constant of less than 50 microseconds, battery source)
** DC Cold Resistance (Measured at ≤10% of rated current)
*** Typical Melting I2t (Measured with a battery bank at rated DC voltage, 10x-rated current, not to exceed IR, time constant of calibrated circuit less than 50
microseconds) (0603FA4A and 5A measured at interrupting rating)
† Typical Voltage Drop (Measured at rated current after temperature stabilizes)
‡ Alpha code to be marked on the top of fuse body for all ratings
• Device designed to carry rated current for four hours minimum. An operating current of 80% or less of rated current is recommended, with
further derating required at elevated ambient temperatures.
Chip™ Fuses
TIME CURRENT CURVE
OPTION CODE
Option Code
T
Description
Lead free plating
PACKAGING CODE
Packaging Code
SP
TR
OC-2547 Rev. XJ 5/03
© Cooper Electronic
Technologies 2003
Description
50 piece sample pack
5,000 pieces of fuses in paper tape and reeled on a 178mm (7 inch) reel per EIA Standard 481-1
Visit us on the Web at www.cooperET.com
3601 Quantum Boulevard Boynton Beach, Florida 33426-8638
Tel: +1-561-752-5000 Toll Free: +1-888-414-2645 Fax: +1-561-742-1178
This bulletin is intended to present product design solutions and technical information that will help the end user with design applications. Cooper
Electronic Technologies reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of
any products. Cooper Electronic Technologies also reserves the right to change or update, without notice, any technical information contained in this
bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
很抱歉,暂时无法提供与“TR/0603FA3.5A”相匹配的价格&库存,您可以联系我们找货
