BK/C515-2.25A
BK/C515-2.25A
    EATON(伊顿)
    FUSE_D5X15MM_TM
    FUSE GLASS 2.25A 250VAC 2AG
BK/C515-2.25A 数据手册
5mm x 15mm Fuses C515 Series, Time Delay, Glass Tube Description • Axial leaded, time delay • 5mm x 15mm physical size • Glass tube, nickel-plated brass endcap construction • Leads are tin coated • Optional sleeve is flexible flouropolymer (U.L. flammability rating VW-1). • UL Listed product meets standard UL 248-14 ELECTRICAL CHARACTERISTICS Amp Rating Opening Time Rated Current 135% 60 minutes max. 125mA - 250mA 3 seconds min. 200% 120 seconds max. 100% 4 hours min. 470mA 30 minutes max. 350mA 600mA 90 seconds max. 2A 2 seconds max. 6A 500 milliseconds max. 135% 60 minutes max. 375mA - 7A 3 seconds min. 200% 120 seconds max. Agency Information • UL Listed Card: C515 125mA-250mA and 375mA-3A (Guide JDYX, File E19180) • UL Recognized Card: C515 350mA, and 3.5A-7A (Guide JDYX2, File E19180) • CSA Certification Card: C515 125mA-250mA and 375mA-3A (Class 1422-01, LR65063) RoHS 2002/95/EC Dimensions (mm) Drawing Not to Scale Ordering • Specify packaging, product, and option code • For -R option, drop mA or A from product code (i.e. C515-1-R) • With TR2 packaging code, lead wire length is 20.3mm SPECIFICATIONS Product Code C515-125mA C515-250mA C515-350mA C515-375mA C515-500mA C515-600mA C515-750mA C515-800mA C515-1A C515-1.25A C515-1.5A C515-1.6A C515-2A C515-2.25A C515-2.5A C515-3A C515-3.5A C515-4A C515-5A C515-6A C515-7A * † ‡ Voltage Rating AC 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 125V 125V 125V 125V 125V 600V 25A - AC Interrupting Rating 250V 35A 35A 35A 35A 35A 35A 35A 35A 35A 100A 100A 100A 100A 100A 100A 100A - 125V 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 10000A 400A 400A 400A 400A 400A Typical DC Cold Resistance* (ohms) 4.72 1.32 1.04 0.81 0.54 0.38 0.26 0.23 0.14 0.13 0.100 0.090 0.059 0.057 0.046 0.035 0.028 0.023 0.019 0.014 0.013 DC Cold Resistance (Measured at
BK/C515-2.25A 价格&库存
很抱歉,暂时无法提供与“BK/C515-2.25A”相匹配的价格&库存,您可以联系我们找货
