5mm x 20mm Fuses
S501 Series, Fast Acting, Ceramic Tube
Description
• Fast acting
• Optional axial leads available
• 5mm x 20mm physical size
• Ceramic tube, nickel brass endcap construction
• Designed to IEC 60127-2
RoHS
2002/95/EC
ELECTRICAL CHARACTERISTICS
1.5 In 2.1 In
2.75 In
4 In
10 In
In
min
max
min
max
min
max
max
50mA-3.15A 60 min 30 min 10 ms 2 sec 3 ms 300 ms 20 ms
4A-10A
60 min 30 min 10 ms 3 sec 3 ms 300 ms 20 ms
Dimensions
Drawing Not to Scale
Agency Information
• UL Recognized Card: (50mA-10A) Guide JDYX2,
File E19180
• CSA Component Acceptance: File 53787
• cURus Recognition: Guide JDYX8, File E19180
• SEMKO Approval 50mA, 160mA-10A
• VDE Approval 160mA-10A
• IMQ Approval 50mA-10A
• CCC Approval 160mA-10A
Ordering
• Specify packaging, product, and option code
• For -R option, drop mA or A from product code
(i.e. S501-2-R)
• Ratings above 6.3A have a 0.8mm diameter lead
• With TR2 packaging code, lead wire length is 19.05mm
SPECIFICATIONS
Product Code
S501-50mA
S501-63mA
S501-80mA
S501-100mA
S501-125mA
S501-160mA
S501-200mA
S501-250mA
S501-315mA
S501-400mA
S501-500mA
S501-630mA
S501-800mA
S501-1A
S501-1.25A
S501-1.6A
S501-2A
S501-2.5A
S501-3.15A
S501-4A
S501-5A
S501-6.3A
S501-8A
S501-10A
Voltage
Rating
AC
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
250V
Interrupting Rating
at Rated Voltage
AC
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
1500A
‡ Typical Voltage Drop (Voltage drop was measured at 20°C ambient temperature at rated current)
Typical
Melting I2t (A2Sec)
AC
0.0017
0.0005
0.0011
0.0018
0.0037
0.008
0.020
0.027
0.010
0.018
0.038
0.064
0.097
0.480
0.9
1.9
2.0
3.9
8.1
14
25
48
N/A
N/A
Typical
Voltage
Drop (mV)‡
9000
3300
2600
2300
1900
1600
1350
1300
1400
1200
1050
1200
490
230
200
180
205
190
160
160
155
150
N/A
N/A
5mm x 20mm Fuses
TIME CURRENT CURVE
PACKAGING CODE
Packaging Code
BK
BK1
TR2
Description
100 pieces of fuses packed into a cardboard carton
1,000 pieces of fuses packed into a poly bag
1,500 pieces of fuses packed into tape on a reel (19.05mm lead wire length)
OPTION CODE
Option Code
V
-R
Visit us on the web at:
www.cooperbussmann.com
OC-2568 3/07
© Cooper Electronic
Technologies 2007
Description
Axial leads - copper tinned wire with nickel plated brass overcaps
RoHS compliant version
North America
Cooper Electronic Technologies Cooper Bussmann
1225 Broken Sound Parkway NW P.O. Box 14460
Suite F
St. Louis, MO 63178-4460
Boca Raton, FL 33487-3533
Tel: 1-636-394-2877
Tel: 1-561-998-4100
Fax: 1-800-544-2570
Fax: 1-561-241-6640
Toll Free: 1-888-414-2645
Europe
Cooper Electronic Technologies Cooper Electronic Technologies
Cooper (UK) Limited
Avda. Santa Eulalia, 290
Burton-on-the-Wolds
08223
Leicestershire • LE12 5TH UK
Terrassa, (Barcelona), Spain
Tel: +44 (0) 1509 882 737
Tel: +34 937 362 812
Fax: +44 (0) 1509 882 786
+34 937 362 813
Fax: +34 937 362 719
Asia Pacific
1 Jalan Kilang Timor
#06-01 Pacific Tech Centre
Singapore 159303
Tel: +65 278 6151
Fax: +65 270 4160
很抱歉,暂时无法提供与“BK/S501-2A”相匹配的价格&库存,您可以联系我们找货
