BK/S501-2.5A
BK/S501-2.5A
    EATON(伊顿)
    D5.2xL20mm
    一次性保险丝(熔断) 2.5A 250V
BK/S501-2.5A 数据手册
5mm x 20mm Fuses S501 Series, Fast Acting, Ceramic Tube Description • Fast acting • Optional axial leads available • 5mm x 20mm physical size • Ceramic tube, nickel brass endcap construction • Designed to IEC 60127-2 RoHS 2002/95/EC ELECTRICAL CHARACTERISTICS 1.5 In 2.1 In 2.75 In 4 In 10 In In min max min max min max max 50mA-3.15A 60 min 30 min 10 ms 2 sec 3 ms 300 ms 20 ms 4A-10A 60 min 30 min 10 ms 3 sec 3 ms 300 ms 20 ms Dimensions Drawing Not to Scale Agency Information • UL Recognized Card: (50mA-10A) Guide JDYX2, File E19180 • CSA Component Acceptance: File 53787 • cURus Recognition: Guide JDYX8, File E19180 • SEMKO Approval 50mA, 160mA-10A • VDE Approval 160mA-10A • IMQ Approval 50mA-10A • CCC Approval 160mA-10A Ordering • Specify packaging, product, and option code • For -R option, drop mA or A from product code (i.e. S501-2-R) • Ratings above 6.3A have a 0.8mm diameter lead • With TR2 packaging code, lead wire length is 19.05mm SPECIFICATIONS Product Code S501-50mA S501-63mA S501-80mA S501-100mA S501-125mA S501-160mA S501-200mA S501-250mA S501-315mA S501-400mA S501-500mA S501-630mA S501-800mA S501-1A S501-1.25A S501-1.6A S501-2A S501-2.5A S501-3.15A S501-4A S501-5A S501-6.3A S501-8A S501-10A Voltage Rating AC 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V 250V Interrupting Rating at Rated Voltage AC 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A 1500A ‡ Typical Voltage Drop (Voltage drop was measured at 20°C ambient temperature at rated current) Typical Melting I2t (A2Sec) AC 0.0017 0.0005 0.0011 0.0018 0.0037 0.008 0.020 0.027 0.010 0.018 0.038 0.064 0.097 0.480 0.9 1.9 2.0 3.9 8.1 14 25 48 N/A N/A Typical Voltage Drop (mV)‡ 9000 3300 2600 2300 1900 1600 1350 1300 1400 1200 1050 1200 490 230 200 180 205 190 160 160 155 150 N/A N/A 5mm x 20mm Fuses S501 Series, Fast Acting, Ceramic Tube TIME CURRENT CURVE PACKAGING CODE Packaging Code BK BK1 TR2 Description 100 pieces of fuses packed into a cardboard carton 1,000 pieces of fuses packed into a poly bag 1,500 pieces of fuses packed into tape on a reel (19.05mm lead wire length) OPTION CODE Option Code V -R Visit us on the web at: www.cooperbussmann.com OC-2568 3/07 © Cooper Electronic Technologies 2007 Description Axial leads - copper tinned wire with nickel plated brass overcaps RoHS compliant version North America Cooper Electronic Technologies Cooper Bussmann 1225 Broken Sound Parkway NW P.O. Box 14460 Suite F St. Louis, MO 63178-4460 Boca Raton, FL 33487-3533 Tel: 1-636-394-2877 Tel: 1-561-998-4100 Fax: 1-800-544-2570 Fax: 1-561-241-6640 Toll Free: 1-888-414-2645 Europe Cooper Electronic Technologies Cooper Electronic Technologies Cooper (UK) Limited Avda. Santa Eulalia, 290 Burton-on-the-Wolds 08223 Leicestershire • LE12 5TH UK Terrassa, (Barcelona), Spain Tel: +44 (0) 1509 882 737 Tel: +34 937 362 812 Fax: +44 (0) 1509 882 786 +34 937 362 813 Fax: +34 937 362 719 Asia Pacific Cooper Electronic Technologies 1 Jalan Kilang Timor #06-01 Pacific Tech Centre Singapore 159303 Tel: +65 278 6151 Fax: +65 270 4160
BK/S501-2.5A 价格&库存
很抱歉,暂时无法提供与“BK/S501-2.5A”相匹配的价格&库存,您可以联系我们找货
