TR2/6125FA4A
TR2/6125FA4A
    EATON(伊顿)
    SMD2
    FUSE BRD MNT 4A 125VAC/VDC 2SMD
TR2/6125FA4A 数据手册
Brick™ Fuses 6125FA Series, Fast Acting Description • Fast Acting Surface Mount Fuse • Complies with the EIA-IS-722 Standard • Solder Immersion Compatible • Overcurrent protection of systems up to 125VAC/DC • Wire-in-air design ELECTRICAL CHARACTERISTICS % of Amp Rating Opening Time 100% 4 Hours Minimum 200% 5 Seconds Maximum RoHS 2002/95/EC Dimensions ⁄(inches) mm Drawing Not to Scale 1.35+.25 (0.053+.010) s p m A 2 e r v o f o b d A e d s n g e n i t m a m the R o s . i c s atings A e n F g R 5 i 612 NOT W Dest for 2A+eRt # 4377 Are NEeplacemenData She Agency Information • UL Listed Guide and File Numbers (250mA-12A): JDYX & E19180 • UL Recognized Guide and File Numbers (15A): JDYX2 & E195337 • CSA Component Acceptance: 053787 C 000 & Class No: 1422 30 Environmental Data • Shock: MIL-STD-202, Method 213, Test Condition 1 (100 G’s peak for 6 milliseconds) • Vibration: MIL-STD-202, Method 201 (10-55 Hz, 0.06 inch, total excursion) • Salt Spray: MIL-STD-202, Method 101, Test Condition B (48 hrs) • Insulation Resistance: MIL-STD-202, Method 302, Test Condition A (After Opening) 10,000 ohms minimum • Resistance to Solder Heat: MIL-STD-202, Method 210, Test Condition F (20 sec, at 260° C) • Thermal Shock: MIL-STD-202, Method 107, Test Condition B (-65° C to +125° C) Ordering • Specify product and packaging code R ee S d . e end Series m om 61F c e R CB 2.59+ .250 (0.102+.010) End View 1.35 +.25 (0.053+.010) 2.59+.25 (0.102+.010) 2.59+ .250 (0.102+.010) Land Pattern Top View 6.10+.25 (0.240+.010) 2.6 3.0 (0.102) (0.118) 4.0 (0.157) 8.6 (0.339) Soldering Method • Wave Solder: 260°C, 10 sec max. (MIL-STD-202, Method 210) • Infrared Reflow: 260°C, 30 sec max. SPECIFICATIONS Product Code 6125FA250mA 6125FA375mA 6125FA500mA 6125FA750mA 6125FA1A 6125FA1.25A 6125FA1.5A 6125FA2A 6125FA2.5A 6125FA3A 6125FA3.5A 6125FA4A 6125FA5A 6125FA6.3A 6125FA7A 6125FA10A 6125FA12A 6125FA15A AC 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V N/A Voltage Rating DC 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V 125V N/A N/A N/A DC 86V 86V 86V 86V 86V 86V 86V 86V 86V 86V 86V 86V 86V 86V 86V 86V 86V 86V Interrupting Rating* 125V AC 125V DC 86V DC 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A 300A 10,000A 50A N/A 10,000A 50A N/A 10,000A N/A N/A 10,000A Resistance (ohms)** Typ. 0.65 0.36 0.24 0.15 0.11 0.09 0.07 0.05 0.038 0.028 0.025 0.022 0.016 0.012 0.011 0.007 0.006 0.004 Typical Melt I2t† 0.01 0.03 0.06 0.07 0.14 0.24 0.41 0.80 1.4 2.4 3.3 4.4 7.8 14.0 19.0 44 69 124 Typical Voltage Drop (V)‡ 0.30 0.25 0.22 0.17 0.17 0.16 0.15 0.15 0.14 0.13 0.13 0.13 0.12 0.12 0.114 0.107 0.103 0.098 * AC Interrupting Rating (Measured at designated voltage, 100% power factor); DC Interrupting Rating (Measured at designated voltage, time constant of less than 50 microseconds, battery source) ** DC Cold Resistance (Measured at 10% of rated current) † Typical Melting I2t (Measured with a battery bank at rated DC voltage, 10x-rated current, time constant of calibrated circuit less than 50 microseconds) ‡ Typical Voltage Drop (Measured at rated current after temperature stabilizes) Device designed to carry rated current for four hours minimum. An operating current of 80% or less of rated current is recommended, with further derating required at elevated ambient temperatures. Brick™ Fuses 6125FA Series, Fast Acting TIME CURRENT CURVE s p m A 2 e r v o f o b d A e d s n g e n i t m a m the R o s . i c s atings A e n F g R 5 i 612 NOT W Dest for 2A+eRt # 4377 Are NEeplacemenData She R ee S d . e end Series m om 61F c e R CB PACKAGING CODE Packaging Code TR2 Visit us on the web at: www.cooperbussmann.com OC-2531 Rev. I 3/07 © Cooper Electronic Technologies 2007 Description 5,000 pieces of fuses on 12mm tape-and-reel on a 13 inch (330mm) reel per EIA Standard 481 North America Cooper Electronic Technologies Cooper Bussmann 1225 Broken Sound Parkway NW P.O. Box 14460 Suite F St. Louis, MO 63178-4460 Tel: 1-636-394-2877 Boca Raton, FL 33487-3533 Fax: 1-800-544-2570 Tel: 1-561-998-4100 Fax: 1-561-241-6640 Toll Free: 1-888-414-2645 Europe Cooper Electronic Technologies Cooper Electronic Technologies Avda. Santa Eulalia, 290 Cooper (UK) Limited 08223 Burton-on-the-Wolds Terrassa, (Barcelona), Spain Leicestershire • LE12 5TH UK Tel: +44 (0) 1509 882 737 Tel: +34 937 362 812 +34 937 362 813 Fax: +44 (0) 1509 882 786 Fax: +34 937 362 719 Asia Pacific Cooper Electronic Technologies 1 Jalan Kilang Timor #06-01 Pacific Tech Centre Singapore 159303 Tel: +65 278 6151 Fax: +65 270 4160
TR2/6125FA4A 价格&库存
很抱歉,暂时无法提供与“TR2/6125FA4A”相匹配的价格&库存,您可以联系我们找货
