PC06F1A
PC06F1A
    EATON(伊顿)
    PC06F1A
PC06F1A 数据手册
PolyCHIP™ Fuses PC06F Series, Fast Acting Description • Low resistance • Low profile 0603/1608 design • Pb-free and RoHS Compliant • High inrush withstand capability • Polymer matrix design • One time positive disconnect • Ampere rating marked on both sides, dual orientation • Compatible with leaded and lead-free reflow and wave solder ELECTRICAL CHARACTERISTICS % of Amp Rating Opening Time 100% 4 Hours Minimum 200% 5 Seconds Maximum Agency Information • UL Recognition Card: JDYX2, E19180 Environmental Data • Life Test: MIL-STD-202, Method 108A, Test Condition C • Load Humidity: MIL-STD-202, Method 103B • Moisture Resistance: MIL-STD-202, Method 106G • Thermal Shock: MIL-STD-202, Method 107D • Solderability: ANSI/J-STD-002, Test B • Mechanical Shock: MIL-STD-202, Method 213B, Condition A • High Frequency Vibration: MIL-STD-202, Method 204D, Condition D Packaging & Ordering Information • 5,000 pieces; paper tape; 178mm (7 inch) reel; per EIA Standard 481-1 • Order by Product Code (no prefix or suffix necessary) Dimensions mm Land Pattern ⁄(inches) 1.25 (0.05) 0.90 (0.035) 0.50 (0.02) Soldering Method • Wave Solder: 260°C, 10 sec max. • Infrared: 260°C, 30 sec max. SPECIFICATIONS Product Code PC06F500MA PC06F750MA PC06F1A PC06F1.5A PC06F2A PC06F2.5A PC06F3A PC06F3.5A PC06F4A Voltage Rating AC/DC 32V 32V 32V 32V 32V 32V 32V 32V 32V Interrupting Rating @ Rated Voltage* 50A 50A 50A 50A 50A 50A 50A 50A 50A Typical DC Cold Resistance (ohms)** 0.143 0.088 0.065 0.042 0.027 0.021 0.018 0.014 0.012 Typical Melting I2t (A2s)*** Alpha Code 0.00128 0.00291 0.00616 0.02565 0.03968 0.10139 0.15778 0.25844 0.27034 F G H K N O P R S * DC Interrupting Rating is measured at designated voltage, time constant of less than 50 microseconds, battery source. ** DC cold resistance is measured at less than 10% of rated current. *** Melting I2t is measured with a battery back at rated DC voltage, at the lesser of either 10 times rated current or the interrupting rating with a time constant of less than 50 microseconds. PolyCHIP™ Fuses PC06F Series, Fast Acting TIME CURRENT CURVE Visit us on the web at: www.CooperET.com OC-2617 7/05 © Cooper Electronic Technologies 2005 North America Cooper Bussmann Cooper Electronic Technologies P.O. Box 14460 3601 Quantum Boulevard St. Louis, MO 63178-4460 Boynton Beach, FL 33426-8638 Tel: 1-636-394-2877 Tel: 1-561-752-5000 Fax: 1-800-544-2570 Fax: 1-561-742-0134 Toll Free: 1-888-414-2645 Europe Cooper Electronic Technologies Cooper (UK) Limited Burton-on-the-Wolds Leicestershire • LE12 5TH UK Tel: +44 (0) 1509 882 737 Fax: +44 (0) 1509 882 786 Asia Pacific Cooper Electronic Technologies 1 Jalan Kilang Timor #06-01 Pacific Tech Centre Singapore 159303 Tel: +65 278 6151 Fax: +65 270 4160
PC06F1A 价格&库存
很抱歉,暂时无法提供与“PC06F1A”相匹配的价格&库存,您可以联系我们找货
