PolyCHIP™ Fuses
PC06F Series, Fast Acting
Description
• Low resistance
• Low profile 0603/1608 design
• Pb-free and RoHS Compliant
• High inrush withstand capability
• Polymer matrix design
• One time positive disconnect
• Ampere rating marked on both sides, dual orientation
• Compatible with leaded and lead-free reflow and wave
solder
ELECTRICAL CHARACTERISTICS
% of Amp Rating
Opening Time
100%
4 Hours Minimum
200%
5 Seconds Maximum
Agency Information
• UL Recognition Card: JDYX2, E19180
Environmental Data
• Life Test: MIL-STD-202, Method 108A, Test Condition C
• Load Humidity: MIL-STD-202, Method 103B
• Moisture Resistance: MIL-STD-202, Method 106G
• Thermal Shock: MIL-STD-202, Method 107D
• Solderability: ANSI/J-STD-002, Test B
• Mechanical Shock: MIL-STD-202, Method 213B,
Condition A
• High Frequency Vibration: MIL-STD-202, Method 204D,
Condition D
Packaging & Ordering Information
• 5,000 pieces; paper tape; 178mm (7 inch) reel;
per EIA Standard 481-1
• Order by Product Code (no prefix or suffix necessary)
Dimensions
mm
Land Pattern
⁄(inches)
1.25
(0.05)
0.90
(0.035)
0.50
(0.02)
Soldering Method
• Wave Solder: 260°C, 10 sec max.
• Infrared: 260°C, 30 sec max.
SPECIFICATIONS
Product
Code
PC06F500MA
PC06F750MA
PC06F1A
PC06F1.5A
PC06F2A
PC06F2.5A
PC06F3A
PC06F3.5A
PC06F4A
Voltage Rating
AC/DC
32V
32V
32V
32V
32V
32V
32V
32V
32V
Interrupting
Rating @
Rated Voltage*
50A
50A
50A
50A
50A
50A
50A
50A
50A
Typical DC Cold
Resistance
(ohms)**
0.143
0.088
0.065
0.042
0.027
0.021
0.018
0.014
0.012
Typical Melting
I2t (A2s)***
Alpha
Code
0.00128
0.00291
0.00616
0.02565
0.03968
0.10139
0.15778
0.25844
0.27034
F
G
H
K
N
O
P
R
S
* DC Interrupting Rating is measured at designated voltage, time constant of less than 50 microseconds, battery source.
** DC cold resistance is measured at less than 10% of rated current.
*** Melting I2t is measured with a battery back at rated DC voltage, at the lesser of either 10 times rated current or the interrupting rating with a time constant of less than 50
microseconds.
PolyCHIP™ Fuses
TIME CURRENT CURVE
Visit us on the web at:
www.CooperET.com
OC-2617 7/05
© Cooper Electronic
Technologies 2005
North America
Cooper Bussmann
Cooper Electronic Technologies
P.O. Box 14460
3601 Quantum Boulevard
St. Louis, MO 63178-4460
Boynton Beach, FL 33426-8638
Tel: 1-636-394-2877
Tel: 1-561-752-5000
Fax: 1-800-544-2570
Fax: 1-561-742-0134
Toll Free: 1-888-414-2645
Europe
Cooper (UK) Limited
Burton-on-the-Wolds
Leicestershire • LE12 5TH UK
Tel: +44 (0) 1509 882 737
Fax: +44 (0) 1509 882 786
Asia Pacific
1 Jalan Kilang Timor
#06-01 Pacific Tech Centre
Singapore 159303
Tel: +65 278 6151
Fax: +65 270 4160
很抱歉,暂时无法提供与“PC06F3A”相匹配的价格&库存,您可以联系我们找货
