SR-5-80MA-AP
SR-5-80MA-AP
    EATON(伊顿)
    径向
    FUSE BOARD MOUNT 80MA 250VAC RAD
SR-5-80MA-AP 数据手册
Subminiature Fuses HALOGEN HF FREE SR-5 Series, Time-Delay Pb Description • Radial leaded time-delay thru-hole fuse • Designed to IEC 60127-3, Sheet 4 • Internationally accepted for primary and secondary overcurrent protection • Place directly into PCB or plug into BK/PCS holder • High inrush withstand capability • Compatible with leaded and lead-free reflow and wave solder Packaging Information – mm Electrical Characteristics Rated 1.5 xIn 2.1 xIn 2.75 xIn 4 xIn 10 xIn Current min max min max min max min max 40mA-6.3A 1hr 2 min 400 mS10 Sec. 150 mS 3 Sec. 20 mS 150 mS Ø8.50±0.20 [Ø0.330±0.008] 7.60±0.20 [0.300±0.008] Agency Information* • cURus: Guide JDYX2,File E306920 & Guide JDYX8, File E306920 • VDE: File122052, 40020046 • SEMKO: File 902104, 902105 • CCC: File 2007010207229852 • CQC: File CQC08012024959 • EK-MARK: File SU05025-8001, SU05025-8002, SU05025-8003, SU05025-7001, SU05025-7002A • PSE: JET5766-31007-1001, JET5766-31007-1002 Specifications • Solderability: EIA-186-9E Method 9 • High frequency vibration: MIL-STD-202F, Method 201A • Operating temperature: -40°C to +85°C • Soldering heat resistance: 260°C, 10 Sec. max (IEC 60068-2-20) 4.30±0.30 [0.170±0.012] 0.50 [0.020] Ø0.60 [Ø0.024] (REF) 18.800±1.00 [0.740±0.039] 21.00±3.00 [0.827±0.118] 5.08 [0.200] BK PACK BK1 PACK BK2 PACK 35.00±1.00 [1.378±0.039] 13.00 [0.512] (REF) 18.00 [0.708] (REF) 9.00±0.38 [0.354±0.015] Ø4.00±0.10 [Ø0.156±0.004] 12.70 [0.500] 6.35±0.25 [0.250±0.010] AP PACK Ordering • Specify product and packaging code (i.e., SR-5-1A-AP) 4.0±0.5 [0.158±0.0195] 13.00±1.00 [0.512±0.039] 38.8±1.00 [1.528±0.039] ( ) Socket (PCS) 0.03" 0.30" (7.62mm) 0.20" (5.08mm) 18.00±1.00 [0.709±0.039] (0.76mm) 0.095" (2.41mm) 0.29" (7.37mm) 15.00 [0.590] 7.50 [0.295] 7.50±0.3 [0.295±0.012] AP1 PACK 0.12" ± 0.01" (3.05mm ± 0.25mm) Land Pattern 5.08 ± 0.2mm Ø 1.0 ± 0.1mm Mounting Socket (RoHS compliant) • Available as option. Specify catalog number BK/PCS (In bulk 100 per bag) Dimensions – mm 8.5±0.2 unit:mm 7.6±0.2 8.5±0.2 *See part number table for Agency Approvals by amp rating. 0709 BU-SB09254 0.5 min. 0.6Ø 4.3±0.3 (BULK) 5.08±0.1 Page 1 of 3 Data Sheet 4347 Specifications Part Number SR-5-40mA SR-5-50mA SR-5-63mA SR-5-80mA SR-5-100mA SR-5-125mA SR-5-160mA SR-5-200mA SR-5-250mA SR-5-315mA SR-5-400mA SR-5-500mA SR-5-630mA SR-5-800mA SR-5-1A SR-5-1.25A SR-5-1.6A SR-5-2A SR-5-2.5A SR-5-3.15A SR-5-4A *SR-5-5A *SR-5-6.3A Voltage Rating AC 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 Interrupting Rating (amps) @ Rated Voltage 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 40 50 63 Typical DC Cold Resistance (Ω) 11.5 8 5.36 3.43 2.37 1.6 1.02 0.94 0.66 0.43 0.285 0.242 0.154 0.112 0.085 0.061 0.043 0.031 0.024 0.018 0.012 0.010 0.008 Typical Melting** I2t (@1mS) 0.001988 0.003664 0.006979 0.010814 0.015155 0.026783 0.039097 0.168832 0.24778 0.2772 0.771618 2 3.5 6.5 7.5 13 24 30 45 57 80 95.4 200 Voltage Drop mV @ 20°C Rated Current 524 462 383.5 331 288.5 238 196.5 215.5 185 152 127 143.5 113 104.5 100 91 102 74.5 72.5 70.25 62 57.5 60.85 VDE x x x x x x x x x x x x x x x x x x x x x x x Agency Approvals SEMKO cURus CCC EK-Mark PSE x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x CQC x x x x CQC x x *Conducting Path min. 0.2mm2 **I2t value for 40mA to 400mA is measured at 100ln. I2t value for 500mA to 6.3A is measured at 10In. 0709 BU-SB09254 Page 2 of 3 Data Sheet 4347 Time in Seconds Time-Current Curve Current in Amp Packaging Code Packaging Code Suffix -AP -BK Description Ammo-pack taped 1,000 per box In bulk 200 per bag The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. © 2009 Cooper Bussmann St. Louis, MO 63178 www.cooperbussmann.com 0709 BU-SB09254 Page 3 of 3 Data Sheet 4347
SR-5-80MA-AP
物料型号为 COOPER Bussmann SR-5 Series。
器件简介为一种径向引线延时通孔保险丝,设计符合IEC 60127-3标准,适用于一次和二次过电流保护。
引脚分配为径向引线。
参数特性包括额定电流范围从40mA至6.3A,具有高浪涌承受能力,兼容有铅和无铅回流焊和波峰焊。
功能详解包括其延时特性,例如在40mA至6.3A的额定电流下,最小和最大延时时间。
应用信息包括可以直接放置在PCB上或插入BK/PCS插座。
封装信息包括尺寸和标记图案,例如8.50mm±0.20的直径和5.08mm±0.2mm的引脚间距。
SR-5-80MA-AP 价格&库存
很抱歉,暂时无法提供与“SR-5-80MA-AP”相匹配的价格&库存,您可以联系我们找货
