Effective November 2021
Supersedes August 2020
Technical Data 2002
MDA
1/4” x 1 1/4” Time-delay ceramic tube fuses Pb
HALOGEN
HF
FREE
Agency information
• UL Listed Card: MDA 1/4 - 20 A (Guide JDYX, File E19180)
• UL Recognized Card: MDA 25 - 30 A (Guide JDYX2, File
E19180)
• CSA Certification Card: MDA 1/4 - 20 A (Class No. 1422-01)
• CSA Component Acceptance: MDA 25 - 30 A (Class No.
1422-30)
General specifications
Product features
Time-delay
Optional axial leads available
1/4” x 1-1/4” (6.35 x 31.75 mm) physical size
Ceramic tube, nickel-plated brass endcap construction
UL Listed product meets standard 248-14
Ordering
Rated current
1/4 - 30 A
Shock: 1 A thru 30 A – MIL-STD-202, Method 213, Test
Condition J
Vibration: 1/4 A thru 30 A – MIL-STD-202, Method 204, Test
Condition C (Except 5 g, 500 Hz)
Electrical characteristics
Amp rating
Opening time
100%
None
135%
60 minutes max.
200%
120 seconds max.
Specify packaging code prefix, part number and and option
code. Replace the "/" with a "-" (i.e. BK-MDA-BV-1-4-R)
Specifications
Part
number
MDA-1/4-R
MDA-1/2-R
MDA-3/4-R
MDA-1-R
MDA-1-1/2-R
MDA-2-R
MDA-2-1/2-R
MDA-3-R
MDA-4-R
MDA-5-R
MDA-6-R
MDA-7-R
MDA-8-R
MDA-10-R
MDA-12-R
MDA-15-R
MDA-20-R
MDA-25-R
MDA-30-R
Voltage rating
Vac
Vdc
250
250
250
250
250
250
125
250
125
250
125
250
125
250
125
250
125
250
250
125
125
250
125
250
125
250
250
125
250
125
250
125
AC interrupting
rating* (A)
250 V 125 V
35
10000
35
10000
35
10000
35
10000
100
10000
100
10000
200
10000
200
10000
200
10000
200
10000
200
10000
200
10000
200
10000
200
10000
750
10000
750
10000
1500 10000
1500 10000
1500 10000
DC interrupting
rating (A) 125 V
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
Typical DC cold
resistance** (Ω)
8.7
1.78
0.82
0.56
0.2565
0.17
0.068
0.0525
0.03575
0.0256
0.02035
0.0165
0.013
0.00925
0.00755
0.00565
0.004065
0.0031
0.002465
Typical
Typical voltage
drop‡
melting I2t† AC
0.748
4.00
2.53
1.42
8.58
1.31
12.21
1.03
27.5
0.691
70.4
0.623
31.79
0.213
44.99
0.182
147.4
0.162
380.49
0.145
587.73
0.141
638.33
0.137
1038.4
0.134
1620.43
0.135
125.18
0.128
336.82
0.107
483.45
0.095
734.69
0.105
1096.7
0.110
* Interrupting ratings (Measured at 70% - 80% power factor on AC. The interrupting ratings for 25 A, 30 A were measured at 90% - 100% power factor on AC)
** DC Cold resistance (Measured at _
很抱歉,暂时无法提供与“MDA-1/16-R”相匹配的价格&库存,您可以联系我们找货
