C310FC-3-15-TR1
C310FC-3-15-TR1
    EATON(伊顿)
    C310FC-3-15-TR1
C310FC-3-15-TR1 数据手册
3.6x10mm Axial-leaded, Fast-Acting, Single Cap Ceramic Tube Fuses C310FC Series HALOGEN Pb HF FREE Dimensions - mm Drawing Not to Scale Axial Leaded Device Agency Information Description A fast-acting 3.6 x 10mm axial-leaded fuse constructed with ceramic tube and one-piece nickel-plated endcaps featuring tinned copper axial leads. Small 3.6 x 10mm size offers more design flexibility by doing away with conventional over-capping while providing higher I2t values. • • • • cURus Approval: File E19180 Guide JDYX2/YX8 TUV Approval: File No: J 50217156 CQC: CQC12012069004 KC: SU05030-12001A Ordering Amp Rating 800mA~3.15A Electrical Characteristics 1.5In 2.1In 2.75In 4In 10In Min Max Min Max Min Max Max 1hour 30min 10ms 3sec 3ms 300ms 20ms Features • • • • • • • Single cap, axial leaded, fast-acting fuse 3.6 x 10mm physical size Ceramic tube, nickel-plated brass endcap construction Tinned copper axial leads Designed to IEC60127-3, Sheet 3 RoHS complaint, lead-free and halogen free cURus, TUV, CQC, KC Agency approvals • Specify packaging, product and option code (e.g., C310FC-2-TR1) Environmental Specifications: • Terminal Strength: MIL-STD-202G Method 211A. Test Condition A • Thermal Shock: MIL-STD-202G,Method 107G (Test Condition 5cycles -40°C to 85°C) • Resistance to Moisture: MIL-STD-202G, Method 106, Humidity (90~98%RH), Heat (65°C) • Vibration: MIL-STD-202G, Method 201A (10~55Hz) Condition A • Salt Spray: MIL-STD-202G, Method 101D, Test Condition B • Solderability: J-STD-002C, Test Method C1 Specifications Catalog Number C310FC-800mA-R C310FC-1.6A-R C310FC-2A-R C310FC-3.15A-R Voltage Rating Vac 250 250 250 250 Interrupting Rating @ 250Vac (Amps) 35 35 35 35 Typical Cold Resistance (mΩ)* 70 34.5 26 15 Typical 2 Max. Voltage 2 Melting I t (A s)** 0.56 2.2 3.8 13.3 Drop (mV)*** 180 120 100 100 * Typical Cold Resistance (Measured at < _10% of rated current). ** Typical Melting I2t (Tested at 10ln). *** Maximum Voltage Drop (Voltage drop was measured at 25°C ambient temperature at rated current). 0812 BU-SB12692 Page 1 of 2 Data Sheet 4415 Agency Information cURus X X X X TUV X X X X CQC KC X X X X X X Wave Soldering Parameters 800mA Note: These devices are NOT recommended for IR or convection reflow processes. 1.6A 2A 3.15A Time-Current Curves 1000.000 100.000 Time-Current Curves • Reservoir Temperature: 260°C ± 3°C • Soldering Time: 3 seconds max. Hand Solder Parameters (Not Recommended) Time in Seconds 10.000 1.000 0.100 • Soldering Iron Tip Temperature: 350°C ± 5°C • Heating Time: 4-5 seconds max. Temperature Derating Curve 0.010 0.001 0.1 1.0 10.0 100.0 1000.0 Current in Amps Packaging Code Packaging Code Suffix -TR1 Description 1500 Fuses on a reel, five (5) reels in one (1) carton The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. © 2012 Cooper Bussmann www.cooperbussmann.com 0812 BU-SB12692 Page 2 of 2 Data Sheet 4415 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Cooper Bussmann: C310FC-1-6-TR1 C310FC-2-TR1 C310FC-3-15-TR1
C310FC-3-15-TR1 价格&库存
很抱歉,暂时无法提供与“C310FC-3-15-TR1”相匹配的价格&库存,您可以联系我们找货
