BK-S505-V-8-RS
BK-S505-V-8-RS
    EATON(伊顿)
    FUSE_D5X20MM
    FUSECERAMIC8A250V5X20MM
BK-S505-V-8-RS 数据手册
HALOGEN 5 x 20mm Time-Delay, Ceramic Tube Fuses HF FREE S505 Series 5 x 20mm fuse with optional axial leads Pb Dimensions - mm • Ratings above 6.3A have a maximum 0.81mm diameter lead • With TR2 packaging code, leadwire length is 19.05mm Description • Time-delay, high breaking capacity • Available with optional axial leads • Ceramic tube, silver-plated endcap construction (500mA-800mA), nickel-plated brass endcap construction (1-12A) • Optional sleeve is flexible flouropolymer (UL flammability rating VW-1). Consult factory for details. • 5 x 20mm physical size • Designed to IEC 60127-2 (500mA-10A) & extension 12A Electrical Characteristics 1.5In 2.1In 2.75In 4In 10In Amps Min min. Max min. Min ms Max s Min ms Max s
BK-S505-V-8-RS 价格&库存
很抱歉,暂时无法提供与“BK-S505-V-8-RS”相匹配的价格&库存,您可以联系我们找货
