BK/1A3400-09-R
BK/1A3400-09-R
    EATON(伊顿)
    FUSE CLIP CARTRIDGE 20A PCB
BK/1A3400-09-R 数据手册
Bussmann® Fuse Clips for Printed Circuit Boards 1AXXXX Series For ATC, 5mm, ⁄Ω¢∑ & ⁄‹Ω£™∑ Diameter Fuses 1A4534 Series For ⁄Ω¢∑ Diameter Fuses With End Stops & Angled Out Leads 1A4533 Series For ⁄Ω¢∑ Diameter Fuses Without End Stops & Angled Out Leads Dimensional Data Dimensional Data .155" (3.94mm) .102" (2.6mm) .155" Catalog Number Clip Mat.* Finish 1A4534-01 BeCu** Bright Tin 1A4534-06 Cart. Brass Bright Tin (3.94mm) .102" (2.6mm) .320" .280" .320" .280" (8.13mm) (7.11mm) (8.13mm) (7.11mm) .255" .245" .245" (6.2mm) (6.2mm) Catalog Number Clip Mat.* Finish 1A4533-01 BeCu** Bright Tin 1A4533-06 Cart. Brass Bright Tin Catalog Number Clip Mat.* Finish 1A3398-07 Cart. Brass Bright Tin (6.5mm) .060" (1.5mm) .410" .410" (10.4mm) (10.4mm) .255" .226" .150" (6.5mm) (5.74mm) (3.81mm) .060" .321" .226" .150" (5.79mm) (3.81mm) .321" (1.5mm) (8.15mm) (8.20mm) 1A1907 Series For ⁄Ω¢∑ Diameter Fuses With End Stops & Straight Leads 1A3398 Series For ⁄Ω¢∑ Diameter Fuses Without End Stops & Straight Leads Dimensional Data Dimensional Data .155" (3.94mm) .102" Dia. .280" (2.6mm) (7.1mm) .255" (6.5mm) .245" (6.2mm) .410" (10.4mm) .060" (1.5mm) .320" .140" Catalog Number Clip Mat.* 1A1907-02 Cart. Brass .155" Finish None Bright Dipped 1A1907-03 BeCu** Bright Tin 1A1907-05 BeCu** Silver 1A1907-06 Cart. Brass Bright Tin .280" (3.6mm) (7.1mm) (3.94mm) .102" Dia. .280" (2.6mm) (7.1mm) .255" (6.5mm) .410" (10.4mm) .060" (1.5mm) .320" .140" .280" (3.6mm) (7.1mm) (8.13mm) (8.13mm) *Spg. Br. - Spring Bronze; BeCu - Beryllium Copper; Cart. Brass - Cartridge Brass **Beryllium copper recommended for currents higher than 15 amps (⁄Ω¢∑ clips). 6-30-04 SB04208 Form No. 1AXXXX Series Page 1 of 4 Data Sheet: 2131 Bussmann® Fuse Clips for Printed Circuit Boards 1AXXXX Series For ATC, 5mm, ⁄Ω¢∑ & ⁄‹Ω£™∑ Diameter Fuses 1A3399 and 1A5018 Series For 5mm Diameter Fuses With Straight Leads 1A5601 Series For 5mm Diameter Fuses (0 to 7 amps) Dimensional Data Dimensional Data .062" .115" Clip Mat.* Finish 1A3399-10 Spg. Br. Bright Tin .237" 1A3399-01 BeCu** Silver (6.0mm) 1A3399-04 BeCu** Bright Tin .254" (6.5mm) .250" Catalog Number (1.6mm) (2.9mm) (6.35mm) .246" .344" + .015" (6.3mm) (8.73mm + 0.38mm) Catalog Number Clip Mat.* Finish 1A5601 Cart. Brass Bright Tin .344" + .015" (8.73mm + 0.38mm) .225" .125" (6.5mm) (3.2mm) .030" (1.6mm) .141" + .015" (3.58mm + 0.38mm) .060" .266" (1.5mm) (6.75mm) .022" + .002" .032" + .002" (0.56mm + 0.05mm) .060" .125" (1.5mm) (3.2mm) (.81mm + .05mm) .188" (4.8mm) .180" 1A5602 Series For 5mm Diameter Fuses (0 to 7 Amps) High Profile (4.57mm) .230" (5.84mm) Catalog Number Clip Mat.* Finish 1A5018-10 Spg. Br. Bright Tin 1A5018-7 Spg. Br. Silver Dimensional Data .219" .500" .440" .250" (12.70mm) (11.2mm) Catalog Number Clip Mat. Finish 1A5602 Cart. Brass Bright Tin Catalog Number Clip Mat.* Finish (5.57mm) (6.35mm) .140" (3.56mm) .093" (2.36mm) .047" .047" (1.2mm) .140" (3.7mm) .180" .216" (4.6mm) LEGS TO FIT IN .052" (1.3mm) DIA. HOLES ON CENTER (1.19mm) (5.48mm) 1A1119 Series For ⁄Ω¢∑ Diameter Fuses With End Stops and Angled In leads 1A1120 Series For ⁄Ω¢∑ Diameter Fuses Without End Stops and Angled In Leads Dimensional Data Dimensional Data .187" (4.8mm) .132" (3.4mm) .320" .312" (8.13mm) (7.9mm) .187" .132" (4.8mm) (3.4mm) Catalog Number Clip Mat.* Finish 1A1119-04 BeCu** Bright Tin 1A1120-02 Cart. Brass Bright Dip 1A1119-05 BeCu** Silver 1A1120-05 BeCu** Silver 1A1119-10 Cart. Brass Bright Tin 1A1120-06 BeCu** Bright Tin 1A1120-09 Cart. Brass Bright Tin .320" .312" (8.13mm) (7.9mm) .410" .420" (10.4mm) (10.7mm) .250" (6.35mm) .080" .290" .155" (3.9mm) (2.03mm) (7.4mm) .360" (9.14mm) .250" (6.35mm) .080" (2.03mm) .290" .155" (3.9mm) (7.4mm) .360" (9.14mm) *Spg. Br. - Spring Bronze; BeCu - Beryllium Copper; Cart. Brass - Cartridge Brass **Beryllium copper recommended for currents higher than 15 amps (⁄Ω¢∑ clips). 6-30-04 SB04208 Form No. 1AXXXX Series Page 2 of 4 Data Sheet: 2131 Bussmann® Fuse Clips for Printed Circuit Boards 1AXXXX Series For ATC, 5mm, ⁄Ω¢∑ & ⁄‹Ω£™∑ Diameter Fuses 1A5778 Series 1A5779 Series 1A5780 Series 14.68 .578 19.30 .760 1.24 .049 1.90 .075 4.75 .187 3.96 .156 4.45 .175 3.18 .125 BASE BASE 6.88 .271 4.98 .196 FUSECLIPS FUSECLIPS 11.18 .440 6.35 .250 1.57 .062 3.18 .125 8.64 .340 11.10 .437 3.18 .125 1.57 .062 3.66 .144 3.66 .144 2.18 .086 4.47 .176 1.27 .050 2.54 .100 1.45 .057 3.66 .144 4.06 .160 5.08 .200 1.57 .062 3.66 .144 2.54Å}.05 .100Å}.002 (TYP-4) 5.08 .200 DIA. HOLE MOUNTING LAYOUT 1.65Å}.05 .065Å}.002 (TYP-4) 3.66 .144 DIA. HOLE 4.47 .176 3.66 .144 SPECIFICATIONS FUSECLIPS . . . . . . . . MOUNTING LAYOUT FOR 2 CLIPS BASE MATERIAL 1.65Å}.05 .065Å}.002 (TYP-4) MATERIAL: BRASS, NICKEL PLATED, .30 THICK .012 DIA. HOLE MOUNTING LAYOUT ..... BRASS, NICKEL PLATED GLASS FILLED NYLON, UL RATED 94V-0 SPECIFICATIONS CURRENT RATING . . . . . 15 AMPS FUSECLIPS . . . . . . . . VOLTAGE RATING . . . . . 500V AC BASE MATERIAL -50flC TEMPERATURE RATING . . -58flF TO 145flC 292flF BRASS, NICKEL PLATED ..... GLASS FILLED NYLON, UL RATED 94V-0 CURRENT RATING . . . . . 15 AMPS VOLTAGE RATING . . . . . 500V AC TEMPERATURE RATING . . -50flC TO 145flC -58flF 292flF 1A3400 Series For ⁄‹Ω£™∑ Diameter Fuses (20 Amps Maximum) With End Stops & Straight Leads 1A5600 Series For ATC® Fuses (0 to 20 Amps) Dimensional Data Dimensional Data .050" .437" (1.27mm) (11.1mm) .218" (5.5mm) Catalog Number Clip Mat.* Finish 1A3400-09 Spg. Br. Bright Tin .142" Dia. .295" (7.49mm) .330" Catalog Number Clip Mat.* Finish 1A5600 Cart. Brass Satin Finish Tin (8.38mm) (3.6mm) .053" .450" (1.35mm) (11.9mm) .710" (18.0mm) .150" (3.81mm) .200" .090" ± .010" (2.29mm) (5.08mm) .090" (2.29mm) .080" (2.0mm) .470" .380" (9.7mm) (11.9mm) *Spg. Br. - Spring Bronze; BeCu - Beryllium Copper; Cart. Brass - Cartridge Brass **Beryllium copper recommended for currents higher than 15 amps (⁄Ω¢∑ clips). 6-30-04 SB04208 Form No. 1AXXXX Series Page 3 of 4 Data Sheet: 2131 Bussmann® Fuse Clips for Printed Circuit Boards 1AXXXX Series For ATC, 5mm, ⁄Ω¢∑ & ⁄‹Ω£™∑ Diameter Fuses Fuse Clip Catalog Numbers Footprint Dimensional Data A B B C Dimensions A ATC ATM 20mm — — — — — — — — — .560 (14.22) — .464” (11.79) .464” (11.79) — 1.375∑ (34.920) — — — — 1.125∑ (28.58) 1.375∑ (34.92) — — — 1.125∑ (28.58) — 1.375∑ (34.920) — — — 1A3399- 1.00∑ (25.40) — — — 1A3400- — — — 1A4533- 1A5018- 1.00∑ (25.40) 1.00∑ (25.40) — 1.125∑ (28.58) 1.125∑ (28.58) — 1.375∑ (34.920) 1.375∑ (34.920) — 1A5600- — — 1A5601- — 1A5602- — Catalog Number 1A5778- ‡Ω•∑ (22.2mm) — 1∑ (25.4mm) — 1⁄Ω¢∑ 1‹Ω•∑ (31.8mm) (34.93mm) — — 1⁄Ω™∑ (38.10mm — 1A5779- — — — — 1A5780- — — — 1A33981A1907- 1.00∑ (25.40) 1.125∑ (28.58) 1A1119- 1.00∑ (25.40) 1A1120- 1A4534- B Tabs .144” (3.66) .144” (3.66) .200” ( 5.08) C (4 holes) .065∑ ± .002∑ (1.65 ± .05) .065∑ ± .002∑ (1.65 ± .05) .100∑ ± .002∑ (2.54 ± .05) Board Thickness .062∑ (1.57) .062∑ (1.57) .062∑ (1.57) — 295∑- .305∑ (7.49 - 7.75) .067∑ - .070∑ (1.70 - 1.78) .093∑ (2.36) — — .295∑ - .305∑ (7.49- 7.75) .093∑ ± .002∑ (2.36 ± .05) .062∑ to .125∑ (1.57 to 3.18) — — — .875∑ (22.23) — — — — — — — — — — — — — — — — — — — .820∑ ± .015∑ (20.80 ± .38) — — — — — — — — — .093∑ ± .002∑ (2.36 ± .05) .067∑ - .070∑ (1.70 - 1.78) .091∑ - .095∑ (2.31 - 2.41) .067∑ - .070∑ (1.70 - 1.78) .067∑ - .070∑ (1.70 - 1.78) .053∑ - .002∑ (1.35 - 0.05) .052∑ ± .003∑ (1.32 ± .077) .067∑ ± .003∑ (1.70 ± .074) — — — — — — .295∑- .305∑ (7.49 - 7.75) .200∑ (5.08) .405∑ (10.29) .300∑ (7.62) .300∑ (7.62) .180∑ (4.6) .200∑ (5.08) .266∑ (6.76) .220∑ (5.588) .062∑ to .125∑ (1.57 to 3.18) 093” (2.36) .125∑ (3.18) .062∑ (1.57) .062∑ (1.57) .093∑ (2.36) .125∑ max. (3.18) .062∑ (1.57) .125∑ max. (3.175) 1.50∑ (38.10) — — 1.625∑ (41.28) — .820∑ ± .015∑ (20.80 ± .38) — *Spg. Br. - Spring Bronze; BeCu - Beryllium Copper; Cart. Brass - Cartridge Brass **Beryllium copper recommended for currents higher than 15 amps (⁄Ω¢∑ clips). The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 6-30-04 SB04208 Form No. 1AXXXX Series Page 4 of 4 Data Sheet: 2131
BK/1A3400-09-R 价格&库存
很抱歉,暂时无法提供与“BK/1A3400-09-R”相匹配的价格&库存,您可以联系我们找货
BK/1A3400-09-R
  • 1000+3.68776
  • 10000+3.13157
库存:11482
BK/1A3400-09-R
    • 500+2.55453500+0.30525
    • 1000+2.508091000+0.29970
    • 2000+2.461642000+0.29415
    • 2500+2.450032500+0.29277
    • 7500+2.415207500+0.28860
    库存:489
