Technical Data 2107
Effective June 2016
Supersedes January 2003
BUSSMANN
SERIES
Automotive in-line fuse holders for
ATC® blade fuses
Dimensions - in:
0.78"
0.364"
0.91"
0.5"
0.38" 0.30"
HHD
0.25"
4.0" + 0.25"
1.125"
4.0" + 0.25"
Specifications:
Ratings
HHG
Volts - 32 V maximum
Amps
Catalog symbols:
HHC
HHD
HHF
HHG
Description:
In-line fuse holders for ATC blade fuses.
HHC 3-20 A
HHD 3-30 A
HHF 3-20 A
HHG 3-30 A
Agency information
Wire meets UL® 3266
Meets SAE J2030 heavy duty electrical
connector performance standard
Features:
Insulation body: Santoprene TPV
Wire
HHC - 26 strand tin-plated
HHD - 65 strand copper, no plating
HHF - 26 strand tin-plated
HHG - 65 strand tin-plated
Contact material: Brass, tin-plated
Technical Data 2107
Automotive in-line fuseholder
for ATC® blade-type fuses
Effective June 2016
Electrical ratings
Catalog symbol
Description
Fuse size
Electrical connection
Maximum continuous
current rating
HHC
Yellow fuse holder
3-20 A
5” long, #16 black leadwire
16 A*
HHD
Black fuse holder
3-30 A
4” long, #12 yellow leadwire
24 A*
HHF
Holder with protective cover
3-20 A
4” long, #16 yellow leadwire
16 A*
HHG
Heavy-duty holder with cover
3-30 A
24 A*
HHR
Heavy-duty water-resistant holder
3-30 A
5” long, #2 red leadwire
24 A*
ATC-FHID
EasyID illuminating holder with cover
3-20 A
6” long, #16 black leadwire
16 A*
* Or 80% of fuse rating, whichever is less.
Packaging options
Catalog No.
Description
Quantity per
pack
Quantity per
shelf carton
Quantity per
master carton
HHC
Traditional pack
1
10
200
BK/HHC
Bulk pack
100
BP/HHC-RP
Retail pack
1
5
120
HHD
Traditional pack
1
10
200
BK/HHD
Bulk pack
100
BP/HHD-RP
Retail pack
1
5
120
BP/HHD-30-RP*
Retail pack
1
5
120
HHF
Traditional pack
1
10
200
BP/HHF-RP
Retail pack
1
5
120
HHG
Traditional pack
1
10
200
BK/HHG
Bulk pack
100
BP/HHG-RP
Retail pack
1
5
120
* With 30A ATC fuse.
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction
of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible
applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
Eaton.com/bussmannseries
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 2107 – SB03020
June 2016
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Eaton, Bussmann, ATC and easyID are
valuable trademarks of Eaton in the US
and other countries. You are not permitted
to use the Eaton trademarks without prior
written consent of Eaton.
CSA is a registered trademark of the
Canadian Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BK/HHC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+9.46080
- 200+3.66120
- 500+3.53160
- 1000+3.46680
- 国内价格 香港价格
- 1+88.109931+11.43219
