BK/HTB-66I-R
BK/HTB-66I-R
    EATON(伊顿)
    FUSE HLDR CART 250V 20A PNL MNT
BK/HTB-66I-R 数据手册
Fuse Holders for 1⁄4" x 1 1⁄4" and 5 x 20mm Fuses HTB Panel Mount Series Description • For 1⁄4" x 1 1⁄4" and 5 x 20mm fuses • All holder bodies have the option of using 1 ⁄4" x 1 1⁄4" or 5 x 20mm carriers • Withstands 15 to 20 Lb-In torque to mounting nut when mounting fuse holder to panel • High temperature, flame retardant, Thermoplastic meets UL 94V0 Specifications Product UL Rating CSA Rating Code (amps) (amps) HTB-X2I 20 16 HTB-X4I 20 16 HTB-X6I 20 16 HTB-X8I 20 16 HTB-X2M 16 16 HTB-X4M 16 16 HTB-X6M 16 16 HTB-X8M 16 16 Voltage Rating 250 250 250 250 250 250 250 250 Fuse Quick Size Connect 1 3 ⁄4" x 1 1⁄4" ⁄16" 1 3 ⁄4" x 1 1⁄4" ⁄16" 1 1 ⁄4" x 1 1⁄4" ⁄4" 1 1 ⁄4" x 1 1⁄4" ⁄4" 5 x 20mm 3⁄16" 5 x 20mm 3⁄16" 1 5 x 20mm ⁄4" 1 5 x 20mm ⁄4" Maximum Panel Thickness Body Type HTB-2 HTB-3 HTB-4 HTB-5 HTB-6 HTB-8 HTB-9 Inch 0.30 0.30 0.125 0.125 0.30 0.125 0.125 Agency Information • UL Recognized: IZLT2, E14853 • CSA Component Acceptance: Class 6225-01, File 47235 • VDE Certified: 136128, HTB-XXM • SEMKO Certification: Ref. #0146149/01, HTB-XXM • CE Mounting Dimensions - in (mm) Replacement Parts mm 7.62 7.62 3.18 3.18 7.62 3.18 3.18 Dimensions - in (mm) Terminal Options Knob Type Carrier Solder/ 3 ⁄16˝ Quick-Connect Maximum Panel Thickness Common Dimensional Data: Length (Knob Type) - 1.69 (42.9mm) Plus In-Line Terminal NOTE: Plus In-Line Terminal 0.47" 1.125" (11.9mm) (28.6mm) 0.30˝ 7.62mm Low Profile Rear Hex Nut 0.09" NOM. (2.4mm) 0.69" 0.91" (17.5mm) (23.0mm) In-Line Rt. Angle In-Line Rt. Angle 0.34" 0.33" (8.7mm) (8.3mm) HTB-22I-R HTB-24I-R 0.47" (11.9mm) HTB-4 0.67" 0.92" (17.1mm) (23.4mm) 5 x 20mm (“M” Equals Metric) Knob 0.45" (11.5mm) HTB-26I-R HTB-28I-R 3 — HTB-26M-R HTB-28M-R — 3 HTB-42I-R HTB-44I-R HTB-46I-R HTB-48I-R 3 — HTB-42M-R HTB-44M-R HTB-46M-R HTB-48M-R — 3 HTB-62I-R HTB-64I-R HTB-66I-R HTB-68I-R 3 — HTB-62M-R HTB-64M-R HTB-66M-R HTB-68M-R — 3 HTB-82I-R HTB-84I-R HTB-86I-R HTB-88I-R 3 — HTB-82M-R HTB-84M-R HTB-86M-R HTB-88M-R — 3 0.125˝ 3.18mm High Profile Rear Hex Nut 1 ⁄4˝ x 1 1⁄4˝ (“I” Equals Inches) Knob HTB-22M-R HTB-24M-R HTB-2 Carrier Options ⁄4˝ Quick-Connect 1 0.30˝ 7.62mm Front Hex Nut HTB-6 0.47" 1.125" (11.9mm) (28.6mm) 0.125˝ 3.18mm Low Profile Snap-In HTB-8 Fuseholders and fuse carriers may be ordered separately. 0709 BU-SB09620 Page 1 of 2 Data Sheet 2119 Dimensions - in (mm) Terminal Options Screwdriver Type Carrier ⁄16˝ 3 Maximum Panel Thickness Common Dimensional Data: (Screwdriver Slotted) 1.75˝ (44.5mm) NOTE: Plus In-Line Terminal 0.17" 1.58" (4.37mm) (40.03mm) Low Profile Rear Hex Nut 0.41" 1.34" (34.13mm) ⁄4˝ Quick-Connect 1 Rt. Angle In-Line 1 ⁄4˝ x 1⁄4˝ (“I” Equals Inches) Rt. Angle Screwdriver 0.34" HTB-3 (10.31mm) In-Line (8.7mm) 0.30˝ 7.62mm Carrier Options Solder/ Quick-Connect 0.47" 0.33" (11.5mm) HTB-32I-R HTB-34I-R HTB-36I-R HTB-38I-R 3 — HTB-32M-R HTB-34M-R HTB-36M-R HTB-38M-R — 3 HTB-52I-R HTB-54I-R HTB-56I-R HTB-58I-R 3 — HTB-52M-R HTB-54M-R HTB-56M-R HTB-58M-R — 3 HTB-92I-R HTB-94I-R HTB-96I-R HTB-98I-R 3 — HTB-92M-R HTB-94M-R HTB-96M-R HTB-98M-R — 3 0.125˝ 3.18mm High Profile Rear Hex Nut HTB-5 0.17" 1.59" (4.37mm) (40.08mm) Screwdriver 0.45" (11.9mm) (8.3mm) 5 x 20mm (“M” Equals Metric) 0.125˝ 3.18mm Low-Profile Snap-In HTB-9 Fuseholders and fuse carriers may be ordered separately. Ordering Information FUSE CARRIER ONLY HTB- Packing (Blank) – Std. BK/ – Bulk Product Symbol Body Configuration and Mounting Knob Holders 2 — Low Profile (Rear Panel Hex-Nut) 4 — High Profile * 6 — (Front Panel Hex-Nut) 8 — Low Profile (Snap-In) Screwdriver Slotted Holders 3 — Low Profile 5 — High Profile 9 — Low Profile (Snap-In) P S Fuse Carrier I — 1/4˝ x 1 1/4˝ M — 5 x 20mm Rear Terminal Configuration 2 — Solder / 3/16˝ Quick-Connect (In-Line) 4 — Solder / 3/16˝ Quick-Connect (Right Angle) 6 — 1/4˝ Quick-Connect (In-Line) 8 — 1/4˝ Quick-Connect (Right Angle) Splash Proof Cap with O-Ring (Optional on Knob Holders Only) -R RoHS Compliant Packaging (Blank) – Std. BK/ – Bulk Product Symbol FT — Knob Type (For 20, 40, 60, and 80 Series Only) ST — Screwdriver Slotted (For 30, 50, and 90 Series Only) Fuse Carrier I — 1/4 ˝ x 11/4 ˝ M — 5mm x 20mm *Profile varies with panel thickness. Holder installs thru rear of panel. Packaging Packaging Code Prefix Blank BK Description 10 fuse holders packed into a carton 100 fuse holders packed into a cardboard shelf package The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. © 2009 Cooper Bussmann St. Louis, MO 63178 www.cooperbussmann.com 0709 BU-SB09620 Page 2 of 2 Data Sheet 2119
BK/HTB-66I-R 价格&库存
很抱歉,暂时无法提供与“BK/HTB-66I-R”相匹配的价格&库存,您可以联系我们找货
BK-HTB-66I-R
    BK/HTB-66I-R
      • 20+56.97281
      • 40+55.90880
      • 80+54.91734
      • 100+52.77723
      • 1000+25.27020
      库存:3000
