BK/HKP-BBHH-R
BK/HKP-BBHH-R
    EATON(伊顿)
    FUSE HLDR CART 250V 15A PNL MNT
BK/HKP-BBHH-R 数据手册
Effective June 2017 Supersedes June 2008 Technical Data 2106 HKP 1/4” x 1 1/4” Panel-mount fuse holders Agency information • UL Recognized: IZLT2, E14853 • CSA Component Acceptance: Class 6225-01, File 47235 • CE (HKP, HKP-L, HKP-W, HKP-OO) Environmental data Product features • • • • • • • • • For 1⁄4" x 1 1⁄4" (6.3 mm x 32 mm) fuses Maximum panel thickness 5⁄16" (7.9 mm) thick Bayonet-type knob Vibration resistant Military version is designated FHN26G1 Standard plastic nut Optional metal nut Cap – 9435-1/2 Neoprene washer – 9732 Product Code HKP HKP-BBHH HKP-HH HKP-L HKP-LW-HH HKP-OO HKP-W Feature • Temperature rating (RTI): The mounting body for all devices has a temperature rating of 150 °C. The knob for these devices are molded plastic with a temperature rating of 150 °C. • Meets UL 94HB • Terminal Strength: 5 pounds • Torque: Mounting – 20 inch-pound • Salt Spray (corrosion): Test condition B Ordering information • Specify packaging, product, and option code • Optional metal nut, order separately part number BK/1A4806-2 (100 parts minimum) Specifications Standard ⁄4" Quick-Connects, nut and washer assembled 1 ⁄4" Quick-Connects 2250 stand-off barrier Drip-proof knob, 2250V stand-off barrier and 1⁄4" quick connects1 Snap-lock Drip-proof knob1 1 1. IP53 rating for exposed locations Voltage Rating 250 V 250 V 250 V 250 V 250 V 250 V 250 V Current Rating 30 A 15 A 15 A 30 A 15 A 30 A 30 A HKP 1/4” x 1 1/4” Panel-mount fuse holders Technical Data 2106 Effective June 2017 Dimensions - in (mm) Drawing Not to Scale HKP-BBHH, HKP-HH, HKP-LW-HH HKP, HKP-L, and HKP-W HKP-OO Component Terminal Body Cap Nut Material Tin-Plated Brass Thermoset Thermoset Thermoplastic Packaging Packaging Code Prefix Blank BK Description 10 fuseholders packed into a carton 100 fuseholder components packed separately into a carton Option Code Option Code Suffix -R Description RoHS compliant version Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 2106 BU-SB07473 June 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
BK/HKP-BBHH-R 价格&库存
很抱歉,暂时无法提供与“BK/HKP-BBHH-R”相匹配的价格&库存,您可以联系我们找货
