CHM1DU
CHM1DU
    EATON(伊顿)
    32A 690V 配电模块
CHM1DU 数据手册
Fuse Holders and Blocks Section Contents Page HHT Series in-line fuse holders for 5 X 15 to 20mm fuses . . . . . . . . . . . . . . . . . . . . . . . . .278 Tron® in-line fuse holders . . . . . . . . . . . . . . . . . . . . . 279-280 Panel mounted fuse holders for 5 X 20mm fuses . . . . . . .281 Panel mounted fuse holders for 1⁄4” X 1 1⁄4” fuses . . . . . . . . 282 Panel mounted fuse holders for 5 X 20mm and 1 ⁄4” X 1 1⁄4” fuses . . . . . . . . . . . . . . . . . . . . . . . . . . . . 283-284 Panel mounted fuse holders for indicating type fuses . . 285 Panel mounted fuse holders for 13 ⁄32” X 1 5⁄16” to 1 1⁄2” fuses . . . . . . . . . . . . . . . . . . . . . . . . .286 Panel mounted fuse holders for 13 ⁄32” X 1 1⁄2” fuses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .287 Fuse blocks for 1⁄4” X 1 1⁄4” fuses . . . . . . . . . . . . . . . . . . . . 288 Fuse blocks for 1⁄4” X 1” fuses . . . . . . . . . . . . . . . . . . . . . . 289 Fuse blocks for 13⁄32” X 1 1⁄2” fuses . . . . . . . . . . . . . . . . . . . .290 Rail mount fuse holders . . . . . . . . . . . . . . . . . . . . . . . . . . 291 RED indicates NEW information 249 Fuse Holders & Blocks OPM-1038 3-pole fuse holders with disconnect switch . . . . . . . . . . . . . . . . . . . . . . . . . . . . 250 OPM-1038 3-pole fuse holders . . . . . . . . . . . . . . . . . . . .251 OPMNGA- 3-pole Class CC and 13⁄32” X 1 1⁄2” fuse overcurrent protection modules . . . . . . . . . . .252-253 CH Series Class J modular fuse holders . . . . . . . . . . . . 254 JT(N)60030 & JT(N)600600 Safety J™ Class J fuse holders . . . . . . . . . . . . . . . . . . . . . . . . . . . . .255-256 CH Series Global Modular fuse holders . . . . . . . . . 257-258 SAMI™ fuse covers . . . . . . . . . . . . . . . . . . . . . . . . . . . 259 H250 & R250 Series 250V Class H (K) and R fuse blocks . . . . . . . . . . . . . . . . . . . . . . . . . . . .260-262 H600 & R600 600V Class H (K) and R fuse blocks . . . . . . . . . . . . . . . . . . . . . . . . . . . .263-265 J600 Series Class J fuse blocks . . . . . . . . . . . . . . 266-267 JP Series Class J fuse blocks . . . . . . . . . . . . . . . . . . . . 268 JA60030 add-a-pole Class J fuse blocks . . . . . . . . . . . . 268 T300 300V Class T fuse blocks . . . . . . . . . . . . . . . 269-270 T600 600V Class T fuse blocks . . . . . . . . . . . . . . . 271-272 BCA Series Class CC add-a-pole modular fuse blocks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 273 BMA Series 13⁄32” X 1 1⁄2” fuse add-a-pole modular fuse blocks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 273 BC Series Class CC fuse blocks . . . . . . . . . . . . . . . . . .274 BM Series Type M 13⁄32” X 1 1⁄2”” fuse blocks . . . . . . . . . . .274 BG & G Series Class G fuse blocks . . . . . . . . . . . . . . . 274 BH Series high speed fuse modular fuse blocks . . . . . 275 Class H & J modular fuse blocks . . . . . . . . . . . . . . . . . .275 Plug fuse box cover units . . . . . . . . . . . . . . . . . . . . . . .276 HFB & HEB-10 in-line fuse holders for 1⁄4” X 1 1⁄4” fuses . . . . . . . . . . . . . . . . . . . . . . . 277, 279 HHB & HRK universal in-line fuse holders for 1 ⁄4” dia. fuses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 277 HR & HM Series in-line fuse holders for 1⁄4” dia. fuses . . 278 HFA Series waterproof in-line fuse holders for 1⁄4” X 1 1⁄4” fuses . . . . . . . . . . . . . . . . . . . . . . . . . . . .278 Fuse Holders and Blocks Optima® Fuse Holder Module and Disconnect Switch Features/Benefits • Padlockable with finger-safe terminals for safety. Qualified as IP20 per IEC 60529. • Cam-action handle for easy module removal, offered with Class CC rejection clips or European 10 x 38mm clips to meet global needs • Wire ready with 35mm DIN rail or screw panel mounting (#8 screw, 11⁄4” long) saves installation time • Fuse indication lights with option for remote fuse status available. See Data Sheet for additional wiring details. OPM-1038 With Disconnect Switch Typical Applications • Industrial Control • Process Control Systems • Automated Warehouse Systems Communication • Individual Control Circuits Catalog Number Build-A-Code Series O P M - Fuse Type 1 0 3 8 S W Blank = 10 x 38mm or 13⁄32” x 1-1⁄2” R = Class CC Dimensions C= Communication Feature 5.72∑ (± .045) (145.3mm) (± 1.14) 4.25∑ (± 0.03) (108.0mm) (± 0.76) 0.43∑ (± 0.03) (10.9mm) (± 0.76) 1.38∑ (35.0mm) 3-Phase Volts HP 240 5 480 10 600 15 6T3 • • • • Midget (Non-Rejection) KTK FNM FNQ Communication Port 3L2 1.76∑ 0.27∑ (6.9mm) (44.7mm) 5L3 0.74∑ (18.8mm) 0.31∑ (7.9mm) 0.57∑ (± 0.03) (14.5mm) (± 0.76) 3.74∑ (± 0.03) (95.0mm) (± 0.76) Communication Port 3.17∑ (80.5mm) 0.23∑ (5.8mm) 0.50∑ (12.7mm) 0.44∑ (11.2mm) 0.224∑ (5.6mm) Recommended Fuse Types Class CC LP-CC KTK-R FNQ-R 1L1 4T 2 BUSS Specifications Description: 3-pole load break modular fuse holder and disconnect switch for 13⁄32 x 11⁄2” (10 x 38mm) fuses. Dimensions: See Dimensions illustration. Poles: 3 Agency Information: CE, UL (see table), CSA Certified, C22.2 No. 39, Class 6225-01, File 47235, IEC (see table). Flammability Rating: UL 94V0. Horsepower Rating of Switch 2T1 European C10M C10G 1.86∑ (47.2mm) Panel Mounting Hole Pattern 3.60∑ (91.4mm) 1.312∑ (± 0.01) (33.3mm) (± 0.25) Panel Mounting Hole Pattern Physical Characteristics Small size matches 45mm IEC starter width Accepts #8-18 AWG stranded, #10-18 AWG solid wire 3-pole Handle and shaft required for through the door operation Catalog Numbers Catalog Numbers OPM-1038SW Electrical Rating 30A, 600Vac UL/CSA OPM-1038RSW 32A, 660Vac IEC 30A, 600Vac UL/CSA OPM-1038SWC 30A, 600Vac UL/CSA OPM-1038RSWC 32A, 660Vac IEC 30A, 600Vac UL/CSA SCCR** Rating * 100kA * 100kA Clips Non-rejection, 10x38mm or 13 ⁄32” x 1 1⁄2” Rejection, Class CC Non-rejection, 10x38mm or 13 ⁄32” x 1 1⁄2” Rejection, Class CC Remote Open Fuse Indication No No Yes Yes UL Information Std. Recognized UL 508 Listed UL 508 Recognized UL 508 Listed UL 508 File Guide IEC CE E161278 NLRV2 IEC 60947-3 Yes E161278 NLRV E161278 NLRV2 E161278 NLRV *Rating varies depending on fuse used in module; 100kA maximum **Short-Circuit Current Rating Data Sheet: 1103 250 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Yes IEC 60947-3 No No Fuse Holders and Blocks Optima® Fuse Holder Module Features/Benefits • Padlockable with finger-safe terminals for safety. Qualified as IP20 per IEC 529. • Cam-action handle for easy module removal. • Offered with Class CC rejection clips or European 10 x 38mm clips to meet global needs • Wire ready with 35mm DIN rail or screw panel mounting (#8 screw, 1 1⁄4” long) saves installation time • Fuse indication lights with option for remote fuse status indication. See Data Sheet for additional wiring details. OPM-1038 Catalog Number Build-A-Code Series Fuse Type O P M - 1 0 3 8 Blank = 10 x 38mm or 13 ⁄32” x 1 1⁄2” R = Class CC Typical Applications • Industrial Control Communication • Process Control Systems • Automated Warehouse Systems • Individual Control Circuits Dimensions C= Communication Feature 3.22∑ (± 0.03) (81.8mm) (± 0.76) 2T1 IL1 Midget (Non-Rejection) KTK FNM FNQ European C10M C10G Communication Port 3L2 0.27∑ (6.9mm) 5L3 0.74∑ (18.8mm) 0.31∑ (7.9mm) 3.60∑ (± 0.03) (91.4mm) (± 0.76) 0.57∑ (14.5mm) Fuse Holders & Blocks Class CC LP-CC KTK-R FNQ-R 4T2 1.76 ∑ (± 0.03) (44.7mm) (± 0.7 ) 6T3 BUSS Specifications Description: 3-pole modular fuse holder for 13⁄32” x 1 1⁄2” (10 x 38mm) fuses. Dimensions: See Dimensions illustration. Poles: 3 Agency Information: CE, UL (see table), CSA Certified, C22.2 No. 4248, Class 6225-01, File 47235, IEC (see table). Flammability Rating: UL 94V0. Recommended Fuse Types 3.74∑ (± 0.03) (95.0mm) (± 0.76) 3.17∑ (80.5mm) Communication Port 1.65∑ (± 0.03) (41.9mm) (± 0.76) 0.23∑ (5.8mm) 0.50∑ (12.7mm) 0.44∑ (11.2mm) Physical Characteristics • Small size matches 45mm IEC starter width • Accepts #8-18 AWG stranded, #10-18 AWG solid wire • 3-pole 0.224" (5.6mm) 1.312∑ (± 0.01) (33.3mm) (± 0.25) Panel Mount Hole Pattern 3.60∑ (± 0.03) (91.4mm) (± 0.76) 1.86∑ (± 0.03) (47.2mm) (± 0.76) Panel Mount Hole Pattern Catalog Numbers Catalog Numbers OPM-1038 OPM-1038R OPM-1038C OPM-1038RC Electrical Rating 30A, 600Vac/dc UL/CSA (Max 3 Watts per fuse) 32A, 660V IEC 30A, 600Vac/dc UL/CSA 30A, 600Vac/dc UL/CSA (Max 3 Watts per fuse) 32A, 660V IEC 30A, 600Vac/dc UL/CSA SCCR** Rating * 200kA * 200kA Clips Non-rejection, 10 x 38mm or 13 ⁄32” x 1 1⁄2” Rejection, Class CC Non-rejection, 10 x 38mm or 13 ⁄32” x 1 1⁄2” Rejection, Class CC Remote Open Fuse Indication No UL Information Std. Recognized UL 4248 No Listed UL 4248 Recognized UL 4248 Yes Yes Listed UL 4248 File E14853 Guide IZLT2 E14853 IZLT E14853 IZLT2 E14853 IZLT IEC IEC 60269-2-1 CE Yes Yes IEC 60269-2-1 No No *Rating varies depending on fuse used in module; 200kA maximum. **Short-Circuit Current Rating Data Sheet: 1102 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 251 Fuse Holders and Blocks Optima® Three-pole Overcurrent Protection Module Fuse Holder Wire Range: — 75°Cu Only — #18-12 Single/Dual, torque 15lb-in — #10-8 Single/Dual, torque 20lb-in — Dual wire with same gauge and type OPM-NG- 75º Cu Only [mm2] AWu (N•m)/lb-in AWG [mm2] (N•m)/lb-in #18-8 x 1 1-6 x 1 18-12 Single/Dual #18-8 x 1 1-6 x 1 18-12 Single/Dual #18-8#18-8 x 2 x 21-6 1-6 x 2 x 2Strld 15lb-in (1.7#18-8 N•m) x 1 #18-8 x 1 1-6 x 1 10-8 Single/Dual #18-8#18-8 x 2 x 21-6 1-6 x 2 x 2 10-8 Single/Dual 1-4 1-4 x 1 x 1 20lb-in (2.5 N•m) 20in-lb (2.5 N•m) 1-4 1-4 x 2x 2 Solid Solid 1-6 x1 Stranded Ferrules Ferrules Specifications Description: OPM-NG-SC3: 3-pole Class CC fuse holder for use with Class CC fuses (Cooper Bussmann Types LP-CC, FNQ-R, KTK-R). OPM-NG-SM3: 3-pole fuse holder for use with 13⁄32” x 11⁄2” and 10.3 x 38mm fuses (Cooper Bussmann Types: 13⁄32” x 11⁄2”; KTK, FNQ, KLM, 10 x 38mm; FWA, FWC, C10G_ _, C10M_ _). Ratings: Volts: — OPM-NG-SC3: 600Vac (or less) — OPM-NG-SM3: 600Vac (or less) UL and CSA 30A — OPM-NG-SM3: 690Vac (or less) IEC 32A Amps: — OPM-NG-SC3: 0-30A — OPM-NG-SM3: 0-30A SCCR:— OPM-NG-SC3: 200kA — OPM-NG-SM3: Same as fuse IR, 200kA maximum Agency Information: CE, UL; OPM-NG-SC3 UL Listed, UL 4248, File E14853, Guide IZLT. OPM-NG-SM3, UL Recognized, UL 4248, File E14853, Guide IZLT2. CSA Certified, C22.2 No. 4248, Class 6225-01, File 47235. IEC 60947-3 Utilization Category AC20B. Handling & Storage Temperature: -10° to 65°C. Features/Benefits • 45mm width matches IEC starters • 35mm DIN rail or panel mounting feature. Maximum screw size #8 (M4) • Pressure plate terminations with dual-wire rated terminals (see Wire Table) and optional auxiliary contacts • Integrated collapsible handle and fuse carrier cannot be removed from holder base • Padlockable and IP20 finger-safe to IEC60529 Typical Applications • Mass Produced Control Systems • Process Control Systems • Automated Warehouse Systems • Individual Control Circuits Input Power Terminal Wire Range: Wiring Tightening Torque: Solid Conductor Stranded Conductor Connector Screw Clamp (1) #14 to #2 (1.5 (2) #14 to #6 (1.5 (1) #14 to #2 (1.5 (2) #12 to #6 (2.5 20lb-in (2.2 N•m) 15lb-in (1.7 N•m) 25mm2) 10mm2) 25mm2) 10mm2) or conductor conductors conductor or conductors Materials: — Housing: Thermoplastic - ULV2 — Clip: Tin-plated copper alloy — Contact lubricant: Fluoroether grease — Saddle screw: Plated steel — DIN rail springs: Stainless steel Optional Accessories: Comb Bar (Max current rating = 63A) OPMNGSA245 OPMNGSA254 OPMNGSA272 OPMNGSA345 OPMNGSA354 OPMNGSA445 OPMNGSA454 OPMNGSA472 OPMNGSA554 2 2 2 3 3 4 4 4 5 circuit, circuit, circuit, circuit, circuit, circuit, circuit, circuit, circuit, 45mm 54mm 72mm 45mm 54mm 45mm 54mm 72mm 54mm between between between between between between between between between same same same same same same same same same phases phases phases phases phases phases phases phases phases Input Terminal Block (Max current rating = 63A) OPMNGSA005 Input/Feed Through Power Terminal, Supports feed through to another system, DIN rail mount only OPMNGSA009 Input Power Terminal Cover OPMNGSA010 Protective Cover for unused terminals on comb bar Auxiliary Contacts OPMNGSAAUX11 OPMNGSAAUX20 NO/NC NO/NO Marking Tabs OPMNGSA101 Marking Tab - Mounts to front of carrier, quantity 100 Data Sheet: 1109 252 to to to to For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Optima® Three-pole Overcurrent Protection Module Optional Accessories Dimensions Millimeters (± 0.38), Inches (± .015) Fuse Holders & Blocks Data Sheet: 1109 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 253 Fuse Holders and Blocks Class J Modular Fuse Holders CH _ _ J _ Specifications Description: IP20 finger-safe, 1- to 3-pole Class J fuse holder with DIN rail or panel mounting. Ratings: Volts: — 600Vac/dc (or less) Amps: — 30A (30A version) — 60A (60A version) Withstand Rating SCCR: — 200kA Wire Range: Cu solid and stranded conductors with single (1-18AWG) and dual (3-18AWG) wire ratings. See Catalog Numbers table for details. Torque Rating:10-18AWG 24 lb-in. 1-8AWG 35 lb-in. Poles: 1-, 2- or 3-Pole. Storage & Operating Temperature Range*: -20°C to 75°C. Agency Information: CE, UL 4248/CSA 22.2 No. 4248. Flammability Rating: UL 94V0. 30 Amp Version 60 Amp Version Catalog Numbers See Catalog Numbers table below. Dimensions (mm): Features and Benefits • Choice of local fuse indication; easyID™ viewing window (for seeing indicator on LPJ-SPI indicating fuse) or neon lamp. • Versatile 1-, 2- and 3-pole versions for 0-30A and 35-60A fuses with dual wire rated connections simplify wiring. • Improved electrical safety with IP20 finger-safe construction with lock-out/tag-out feature. 3-phase fuse extraction assures all phases are opened for service work. • Flexible panel/35mm DIN rail mounting mounting options Fuse Size 0-30A 35-60A Poles W D H 1 2 3 1 2 3 32 64 96 40 80 120 70 70 70 83 83 83 115 115 115 125 125 125 *For fuse selection on applications above or below 25ºC, consult derating charts in Cooper Bussmann publication “Selecting Protective Devices” (SPD). Catalog Numbers Catalog Amp Volts # of Numbers Rating (AC/DC) Poles IP20 Finger-Safe Mounting Padlockable Local Indication AWG Single Wire Range CH30J1 CH30J1I CH30J2 CH30J2I CH30J3 CH30J3I 30 30 30 30 30 30 600 600 600 600 600 600 1 1 2 2 3 3 Yes Yes Yes Yes Yes Yes 35mm 35mm 35mm 35mm 35mm 35mm DIN/ DIN/ DIN/ DIN/ DIN/ DIN/ Panel Panel Panel Panel Panel Panel Yes Yes Yes Yes Yes Yes easyID** Neon Lamp*** easyID** Neon Lamp*** easyID** Neon Lamp** 1-18 1-18 1-18 1-18 1-18 1-18 CH60J1 CH60J1I CH60J2 CH60J2I CH60J3 CH60J3I 60 60 60 60 60 60 600 600 600 600 600 600 1 1 2 2 3 3 Yes Yes Yes Yes Yes Yes 35mm 35mm 35mm 35mm 35mm 35mm DIN/ DIN/ DIN/ DIN/ DIN/ DIN/ Panel Panel Panel Panel Panel Panel Yes Yes Yes Yes Yes Yes easyID** Neon Lamp*** easyID** Neon Lamp*** easyID** Neon Lamp*** 1-18 1-18 1-18 1-18 1-18 1-18 ** easyID™ viewing window, requires use of Cooper Bussmann LPJ_SPI permanent indication fuses. *** Indication non-fuse dependent, minimum voltage 90Vac/115Vdc. Data Sheet: 2144 254 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Class J (Finger-safe) Fuse Holders Safety J™ — JT(N)60030 & JT(N)60060 30 Amp Version 60 Amp Version Fuse Holders & Blocks Specifications Description: Indicating and non-indicating finger-safe, DIN rail mount fuse holders for use with Class J fuses - (Cooper Bussmann® LPJ, JKS). Dimensions: See Dimensions illustrations. Ratings: Volts: — 600Vac Amps: — 0-60A (JT(N)60060) — 0-30A (JT(N)60030) SCCR:— 200,000A RMS Sym. — 300,000A self certified using Cooper Bussmann LPJ_SP fuses Agency Information: CE, Listed to UL 4248: Guide IZLT, File 14853, CSA Certified: Class 6225-01, File 47235. IP20 per IEC 60529. Flammability Rating: UL 94V0. Indication: Min voltage: 90Vac, 115Vdc; neon lamp “ON” when fuse opens, voltage source and current path are present. Terminations: 30A dual port torque 20lb-in, 60A single port torque 45lb-in, terminal construction, tin-plated copper alloy. Wire Size: JT(N)60030 - rated for 75°C, AWG#18-#8; Cu only, JT(N)60060 - rated for 75°C, AWG#14-#4; Cu only. (Note: For JT(N)60030 use both stranded or solid, in a variety of dual wire combinations of same wire size and type.) Features and Benefits • Short-Circuit Current Rating of 300,000A with Cooper Bussmann LPJ___SP fuses. • Rapid, flexible 35 mm DIN rail mounting. • One piece interlocking design for assembling multiple pole blocks reduces inventory costs. • Removable fuse carrier allows fuse replacement away from base while maintaining finger-safe rating. Typical Applications • Industrial Controls • Process Controls • Small HP VFDs Catalog Numbers Catalog Numbers JT60030 JT60060 JTN60030 JTN60060 Amps 30 60 30 60 Indication Non-indicating Non-indicating Indicating (Neon) Indicating (Neon) Data Sheet: 1152 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 255 Fuse Holders and Blocks Class J (Finger-safe) Fuse Holders Dimensions for JT60030 & JTN60030 — in (mm) 1.14 (29.0) 1.05 (26.7) Slot Din-rail .07 (1.8) MOUNTING 2.75 (69.9) Shown without fuse pullout cover 1 pole BUSS BUSS BUSS JT60030 0 – 30A 600VAC JT60030 0 – 30A 600VAC JT60030 0 – 30A 600VAC USE CLASS J FUSES USE CLASS J FUSES USE CLASS J FUSES DO NOT REMOVE UNDER LOAD DO NOT REMOVE UNDER LOAD DO NOT REMOVE UNDER LOAD 1.23 (31.2) 2.42 (61.3) 2 pole 3.60 (91.4) 3 pole 2.52 (64.1) Dimensions for JT60060 & JTN60060 — in (mm) 1.31 (33.3) 1.25 (31.8) Slot Din-rail .10 (2.6) 3.10 (78.7) 1 pole BUSS BUSS BUSS JT60060 35 – 60A 600VAC JT60060 35 – 60A 600VAC JT60060 35 – 60A 600VAC USE CLASS J FUSES USE CLASS J FUSES USE CLASS J FUSES DO NOT REMOVE UNDER LOAD DO NOT REMOVE UNDER LOAD DO NOT REMOVE UNDER LOAD 1.52 (38.1) 2 pole 3 pole MOUNTING 2.96 (75.2) 4.40 (111.7) Shown without fuse pullout cover 3.06 (77.7) JT(N)600 Series fuse blocks can be dovetailed together within the same current rating to provide multiple pole block configurations. NOTE: JT(N)60030 cannot be dovetailed to JT(N)60060. Data Sheet: 1152 256 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Global Modular Fuse Holders CH Series - 8x32, 10x38, 14x51, 22x58, Class CC Specifications Description: The ‘CH’ line of modular fuse holders accommodates many fuses from around the world, including North American Class-CC, Midget, Class gR, aR HSF, and IEC Industrial Ferrule (Class gG and aM) in four physical sizes: 8x32, 10x38, 14x51 and 22x58mm. Agency Information: Manufactured in accordance with IEC 60269 and IEC 60947-3. Agency Compliance as indicated in the Catalog Numbers table. Features/Benefits • Optional open fuse indication (minimum 90Vac, 115Vdc for indicator lights) • 14x51 & 22x58mm configurations available with optional micro-switches for remote open fuse indication, pre-breaking, and fuse presence • Multi-phase connections available for ganging poles • Low voltage indicating device available for CC and midget (48V) Modular Fuse Holder Selection Table (10 x 38 and CC) Series & Size CHM1DNIU CHM1DNU CHM3DNIU Agency Markings Number Terminal SCCR Cooper Bussmann Rating of Poles Rating Fuses 1 2 3 4 FNQ, KLM, FNM, 1 pole + 1 Solid, KTK, BAF, FWA, neutral Stranded, 100kA rms sym DCM, C10 SERIES, Fine 3 poles + AGU, BAN, FWC Stranded, 1 neutral cURus; IEC 60269-2 IEC 60269-2 Spade Lug, Comb 1 Bus Bar; Single and 1 neutral Dual Wire; 75ºC and 1 90ºC Cu 2 wire UL 48Vdc/30A; IEC 48Vdc/32A CHPV1IU CHM1DNXU CHPV1U CHPV2IU CHPV2U CHCC1DIU CHCC CHCC2DIU Class CC CHCC3DIU UL 600V/30A; IEC 690V/32A CHM3DNU CHM1DI-48U CHPV Voltage & Current IEC 690V/32A UL & IEC; 1000Vdc/30A CHCC1DU UL 600V/30A CHCC2DU CHCC3DU CHCC1DI-48U UL 48Vdc/30A IEC60269-2 UR, CSA, UL4248-18, IEC60269-1 1 2 3 1 cULus CHCC & CHCCI CHM & CHMI Series: CHM Series: CHCC USE CLASS CC FUSE 75ºC OR 90ºC CU WIRE DO NOT OPEN UNDER LOAD Wire Range 18-12 AWG (0.8-4.0mm2) 10 AWG (5.0mm2) 18-16 AWG (0.8-1.3mm2) 14-10 AWG (0.8-5.0mm2) Single Solid, Stranded Wire Range 18-12 AWG (0.8-4.0mm2) 10 AWG (5.0mm2) 18-16 AWG (0.8-1.3mm2) 14-10 AWG (0.8-5.0mm2) 25 in-lbs 2.8 Nm Dual Stranded, 8-4 AWG Fine (8.4-21.1mm2) Stranded 18-14 AWG Spade (0.8-2.0mm2) Terminal N/A Torque 20 in-lbs 2.3 Nm Single 30 in-lbs 3.4 Nm Comb Bus Rated: 600V, 30A 50/60Hz 100kA RMS SYM 3W Indication Min Voltage: 90V IEC: 60269-2 690V-32A 3W Degree of Protection IP20 Conductor No. of Type Conductors Single Solid, Stranded 33kA Solar PV series 200kA rms sym LP-CC, FNQ-R, KTK-R Series: CHPV Conductor No. of Type Conductors Torque Wire Range 18-12 AWG (0.8-4.0mm2) 10 AWG (5.0mm2) 18-16 AWG (0.8-1.3mm2) 14-10 AWG (0.8-5.0mm2) 25 in-lbs 2.8 Nm Single USE MIDGET / 10X38 FUSE 75ºC OR 90ºC CU WIRE DO NOT OPEN UNDER LOAD 20 in-lbs 2.3 Nm Dual Stranded, 8-4 AWG Fine (8.4-21.1mm2) Stranded 18-14 AWG Spade (0.8-2.0mm2) Terminal N/A n/a CHPV & CHPVI USE MIDGET / 10X38 FUSE 75ºC OR 90ºC CU WIRE DO NOT OPEN UNDER LOAD Conductor No. of Type Conductors n/a 30 in-lbs 3.4 Nm Comb Bus Solid, Stranded Torque 20 in-lbs 2.3 Nm 25 in-lbs 2.8 Nm Dual Stranded, 8-4 AWG Fine (8.4-21.1mm2) Stranded 18-14 AWG Spade 2 (0.8-2.0mm ) Terminal N/A Rated: 600V, 30A 50/60Hz 200kA RMS SYM Indication Min Voltage: 90V Degree of Protection IP20 Single Single 30 in-lbs 3.4 Nm Comb Bus UL4248-18 Rated: 1000V, 30A 33kA RMS SYM Indication Min Voltage: 90V IEC: 60269-1 Degree of Protection IP20 Rated: 1000V, 3.5W R 430P MADE IN CHINA 4 MADE IN CHINA 1 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa MADE IN CHINA 5 257 Fuse Holders & Blocks CHM 10x38 and Midget Catalog Number With Without Indicator Indicator CHM1DIU CHM1DU CHM2DIU CHM2DU CHM3DIU CHM3DU CHM4DIU CHM4DU Fuse Holders and Blocks Global Modular Fuse Holders Modular Fuseholder Selection Table (8x32, 14x51, and 22x58) Part Numbers Series/ Size CH08 8X32 CH14 14X51 CH22 22X58 Max Catalog Numbers Voltage W/O Indication W/Indication & Current CH081D CH081DI CH081DNX 400Vac CH081DNS CH081DNSI 25A CH081DN CH081DNI IEC CH082D CH082DI 400Vac CH083D CH083DI 25A CH083DNS CH083DNSI CH083DN CH083DNI CH084D CH084DI UL/CSA CH141DICH1 40A CH141D CH141DMS -14X51 (5 Watt) UL/cURus CH141DNX IEC 600Vac/dc, CH141DN CH141DNI 690Vac, CH142D CH142DI 50A40A (5 Watt) CH143D CH143DI IEC CH143DMS 690Vac, CH143DN CH143DNI UL 50A CH143DNMS 600Vac/dc, CH144D CH144DI 100A CH221B NotCH22 (9.5 Watt) Not CH221BMS Available22X58IEC UL/cURus Available CH221BNX with 690Vac, 600Vac/dc, with CH221BN local 125A 100A local CH222B neon (9.5 Watt) neon CH223B indicatio IEC indication CH223BMS (remote 690Vac, (remote CH223BN microswitch 125A microswitch CH223BNMS only) only) CH224B IEC • • • • • • • • • • • • • • • • • • • • • • • • • • • • • UL † † † † † † Phase Configuration 1-pole 1 Neutral Pole 1-pole + Neutral 1-pole + Neutral 2-pole 3-pole 3-pole + Neutral 3-pole + Neutral 4-pole 1-pole 1-pole + Microswitch 1 Neutral Pole 1-pole + Neutral 2-pole 3-pole 3-pole + Microswitch 3-pole + Neutral 3-pole + Neutral + Microswitch 4-pole 1-pole 1-pole + Microswitch 1 Neutral Pole 1-pole + Neutral 2-pole 3-pole 3-pole + Microswitch 3-pole + Neutral 3-pole + Neutral + Microswitch 4-pole † UL Recognized (cURus) †† UL LIsted (cULus) *Holder width as compared to standard, i.e., 1 = 17.5mm module 2 = 35mm. **90V miminum required for illumination No. of 17.5mm Modules* 1 1 1 2 2 3 3 4 4 1.5 1.5 1.5 3 3 4.5 4.5 6 6 6 2 2 2 4 4 6 6 8 8 8 Box Qty. 12 12 12 6 6 4 4 3 3 6 6 6 3 3 2 2 1 1 1 6 6 6 3 3 2 2 1 1 1 Wire Range Maximum Torque 1-16mm2 (18-6 AWG) 2.5 N•m (22in-lb) 1-10mm2 (18-8 AWG) 1-16mm2 (18-8 AWG) 2.0 N•m (17.5in-lb) 2.5 N•m (22in-lb) 1-16mm2 (18-6 AWG) 2.5 N•m (22in-lb) 2.5-16mm2 (14-6 AWG) 3.0 N•m (26in-lb) 2.5-50mm2 (14-1 AWG) 4.0 N•m (35in-lb) Accessories for CH Series Catalog Numbers Accessory AL-D JV-L CH810-HP CH14-HP C08NL C14NL C22NL CH14MS-1D CH14MS-3D CH-PLC**** CH22LS CH22IP20 For Use with Fuse Holders CH08 and Multi-Phase Connection Links CH14 Series CHM and Multi-Phase Connection Kit*** CHCC Series CH08 Series Multi-Phase Handle Pins CH14 Series CH08 Series CH14 Series Neutral Links CH22 Series CH141 Series Operated-Fuse Micro-Switches CH143 Series CHM and PLC Module CHCC Series 22x58 Lock Support CH22 Series 22x58 IP20 Protection CH22 Series Accessory No. of Poles – 12 – – – – – – – 1 3 10 Multi-Phase Connection Links 258 Neutral Links Multi-Phase Handle Pins For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 10 5 2 1 1 – 5 – 12 ***Kit contains 3-Spring pins and 6-connection links ****OL Listed (cULus) Operated-Fuse Micro-Switches Carton Qty. Programmable Logic Controller (PLC) Fuse Holders and Blocks SAMI™ Fuse Covers SAMI-1I SAMI™ Series SAMI-2I SAMI-3I SAMI-6I SAMI-7I SAMI-8I Features and Benefits • Insulated cover allows field conversion of fuses mounted in open fuse blocks to dead front configuration. • Optional open fuse indicating light aids in system troubleshooting. • Units are re-usable. • Allows visual marking of line and load side of fuses. Fuse Holders & Blocks Typical Applications • Class H, R and J fuse blocks up to 100A • Class T fuse blocks up to 60A • Class CC, G and Midget, 30A fuse blocks Dimensions TEST PROBE LINE TEST PROBE Buss SAMI -2 LOAD Specifications Description: Indicating and non-indicating fuse covers for Class J, RK1, RK5, H, K5, CC, G (0-30A) and midget-type fuses. Indicating feature requires a minimum of 90Vac or 115Vdc to illuminate lamp. One cover required for each pole. WARNING: To avoid electrical shock, turn power off before installing, removing or servicing. Dimensions: See Dimensions illustration. Ratings: Volts: — Non-Indicating - 0-600Vac/dc — Indicating - 90 to 600Vac -115 to 600Vdc Amps: — 0-100A Agency Information: CE, UL Listed; SAMI-1I through SAMI-6I, SAMI-8I and SAMI-9I, SAMI-1N through SAMI-6N, SAMI-8N and SAMI-9N, UL Recognized; SAMI-7I and SAMI-7N, CSA Certified, File LR47235-93C. SAMI-4I B Catalog Numbers Catalog Numbers* SAMI-1_ SAMI-2_ SAMI-3_ SAMI-4_ SAMI-5_ SAMI-6_ SAMI-7_ SAMI-8†_ SAMI-9_ Dimensions (inches) Description A 600V, J (0-30A) and 600V, T (35-60A)** 5.02 250V, RK, K5, H (35-60A) 600V, RK, K5, H (0-30A) 7.03 600V, J (65-100A) 7.03 250V, RK, K5, H (65-100A) 8.20 600V, RK, K5, H (35-60A) 8.20 600V, J (35-60A) 4.98 600V, Midget, Class CC, G (0-30A) 3.82 600V, RK††, K5, H (65-100A) 10.38 250V, RK, K5, H (0-30A) and 600V, 3.82 T (0-30A) A B 1.03 C 1.94 1.30 1.30 1.30 1.30 1.17 0.75 1.50 0.75 2.07 2.33 2.18 2.18 2.14 1.72 2.33 1.72 C FUSE *For indicating cover, add suffix “I”, for non-indicating cover, add suffix “N”. Example: SAMI-7I = Indicating, SAMI-7N = Non-indicating. **Available in non-indicating only. †SAMI-8A adapter available for small Fusetron® body design. SAMI-8I and SAMI-8N come standard with adapter (SAMI-8A). ††Not for use with KTS-R fuses. Data Sheet: 1204 (Trimming Guides: 12041, 12042, 12043, 12044, 12045, 12046, 12048, 12049) For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 259 Fuse Holders and Blocks Class H(K) and R Fuse Blocks – 250V H250 & R250 Series Specifications Agency Information: CE, UL Listed UL 4248, Guide IZLT, File E14853; CSA Certified, Class 6225-01, File 47235. Flammability Rating: UL 94V0. Descriptions: H250 Series: 1-, 2- and 3-pole fuse blocks for use with Class H fuses. R250 Series: 1-, 2- and 3-pole fuse blocks for use with Class R fuses (Cooper Bussmann LPN-RK and FRN-R, DLN-R and KTN-R fuses). Dimensions: See Dimensions illustrations. Ratings: Volts: — 250Vac/dc (H250 & R250 Series) Amps: — 1⁄10-600A SCCR: — H250 Series; 10kA RMS Sym. — R250 Series; 200kA RMS Sym. Features and Benefits • H250 fuse blocks provide one, two and three pole housing for Class H, K and R fuses at 250Vac. • H250 fuse blocks are listed with a Short-Circuit Current Rating of 10kA RMS Sym. • R250 fuse blocks provide one, two and three pole housing for Class R fuses at 250Vac. • R250 fuse blocks are listed with a Short-Circuit Current Rating of 200kA RMS Sym. Typical Applications • 250Vac/dc or less Control Systems • 250Vac/dc or less Industrial Control • 250Vac/dc or less Industrial Control Circuits Recommended DIN rail adapters for the 1⁄10-30A series • see page 413. Class H Fuseblocks (250V) Catalog Data (for NON and REN Fuses) Terminal Type (Suffix No.) Screw Amps ⁄10 to 30 1 Box Lug w/ Pressure Plate & Clip with Reinforced Spring Poles Catalog Number — Clip with Reinforced Spring 1 2 3 H25030-1 H25030-2 H25030-3 S S S SR SR SR P P P PR PR PR C C C CR CR CR — — — Q — — 1 2 3 — — — — — — — — — SR SR SR — — — — — — — — — — — — C C C — — — CR CR CR CR CR CR CO CO CO — — — — — — — — — 4 5 6 7 8 9 — — — — — CR — — 10 — — — — — CR — — 11 — — — — — CR* — — 12 — — — — — CR† — — 13 — — — — — CR — — 14 — — — — — CR† — — 15 31 1 H25060-1 to 2 H25060-2 60 3 H25060-3 61 1 H25100-1 to 2 H25100-2 100 3 H25100-3 101 H25200-1 1 to 3 H25200-3 200 201 1 H25400-1 to 3 H25400-3 400 401 1 H25600-1 to 3 H25600-3 600 *UL Recognized, No CSA Certification. †No UL, No CSA Certification. Pressure Plate — Clip with Reinforced Spring Copper Only 0.25˝ Quick Connect Figure Number C, CR #2-14 Cu, #2-12 Al P, PR #10-18 Cu Only Q N/A S, SR #10-18 Cu Only C, CR #2-14 Cu, #2-8 Al CO #2-14 Cu Only CR #1/0-8 Cu/Al SR #8W/ Ring Terminal CR 250kcmil-6 Cu/Al CR 500kcmil-4 Cu/Al CR (2) 500kcmil-4/0 Cu/Al Data Sheet: H250 Series, 1112; R250 Series, 1110 260 Wire Range For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Class H(K) and R Fuse Blocks – 250V Amps 1 ⁄10 to 30 Poles Class R Fuseblocks (250V) Catalog Data (for LPN-RK, FRN-R, DLN-R and KTN-R Fuses) 1 2 3 Terminal Type (Suffix No.) Screw w/ Box Lug w/ 0.25” Pres. Clip Quick— Plate — Cu Only Connect SR PR CR COR QR* SR PR CR COR — SR PR CR COR — Catalog Number R25030-1 R25030-2 R25030-3 31 1 R25060-1 — to 2 R25060-2 — 60 3 R25060-3 — 61 1 R25100-1 — to 2 R25100-2 — 100 3 R25100-3 — 101 1 R25200-1 — to 3 R25200-3 — 200 201 1 R25400-1 — to 3 R25400-3 — 400 401 1 R25600-1 — to 3 R25600-3 — 600 *UL Recognized, No CSA Certification. †No UL, No CSA Certification. ‡UL Recognized, CSA Certification Fig. No. 1 2 3 Wire Range COR #6-14 Cu Only CR #2-14 Cu, #2-12 Al PR #10-18 Cu Only QR N/A SR #10-18 Cu Only — — — — — — CR CR CR CR CR CR — — — — — — — — — — — — 4 5 6 7 8 9 — — CR CR — — — — 10 11 CR 250kcmil-6 Cu/Al — — CR‡ CR† — — — — 12 13 CR 500kcmil-4/0 Cu/Al — — CR CR† — — — — 14 15 CR 500kcmil-4/0 Cu/Al CR #2-14 Cu, #2-8 Al CR 1/0-8 Cu/Al Dimensions – in 250V 1⁄10 to 30A 2.05" 1.25" 0.95" 1.09" 0.17" 0.75" 0.41" 0.25" 3" 2.5" 2 SPACES AT 0.95" - 1.91" Fuse Holders & Blocks 1.41" 0.22" 1.27" 3.03" 0.5" 1.52" 0.55" 0.22" DIAMETER FIGURE 1. 0.55" FIGURE 2. FIGURE 3. 250V, 31A to 60A 1.73 0.27 1.5 2.81 1.31 0.5 0.5 0.5 1.31 4.125 1.31 0.5 0.5 0.22 x 0.41 0.22 x 0.41 0.22 x 0.41 4.25 G 1.25 1.5 FIGURE 4. FIGURE 5. FIGURE 6. Data Sheet: H250 Series, 1112; R250 Series, 1110 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 261 Fuse Holders and Blocks Class H(K) and R Fuse Blocks – 250V 250V, 61A to 100A 1.81" 2.06" 0.25" 0.62" 0.59" 3.38" 1.56" 4.94" 1.56" 1.56" 0.59" 0.62" 0.62" 0.28" DIA. x 0.5" C'BORE 7.36" 2.38" 3.125" 2.125" FIGURE 7. 250V, 101A to 200A FIGURE 8. FIGURE 9. 250V, 101A to 200A 8" 5" 3.15 0.75 0.31 0.5 3.4" 3.0 2.0 6" 3" 0.5" 1" 2" 7.13" 0.34" DIA. HOLE THROUGH 0.34 DIAMETER 7.125 0.75" C'BORE 4.5" EYELETS TO ACCEPT 0.25" DIA. SCREW 3.0 3" 2.06" 2.06 9" FIGURE 10. FIGURE 11. 250V, 201A to 400A 4.0 1.0 0.31 0.63 250V, 201A to 400A 10.88 9.25 4.0 0.82 1.0 3.0 1.75 0.34 DIAMETER 9.06 4.0 9.06 0.75" C'BORE 0.34" DIA. HOLE THROUGH 3.0 2.5 3.02 FIGURE 13. FIGURE 12. 250V, 401A to 600A 4.97 1.0 0.31 1.125 250V, 401A to 600A 14.74 11.0 4.97 1.0 4.0 1.75 0.34 DIAMETER 11.0 5.0 11.0 0.75" C'BORE 1.87 0.34" DIA. HOLE THROUGH 3.0 3.0 4.0 FIGURE 15. FIGURE 14. Data Sheet: H250 Series, 1112; R250 Series, 1110 262 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Class H(K) and R Fuse Blocks – 600V H600 & R600 Series Specifications Descriptions: H600 Series: fuse blocks for use with 1-, 2- and 3-pole Class H fuses. R600 Series: fuse blocks for use with 1-, 2- and 3-pole Class R fuses (Cooper Bussmann LPS-RK, FRS-R, DLS-R and KTS-R fuses). Dimensions: See Dimensions illustrations. Ratings: Volts: — 600Vac/dc (H600 & R600 Series) Amps: — 1⁄10-600A SCCR: — H600 Series; 10kA RMS Sym. — R600 Series; 200kA RMS Sym. Agency Information: CE, UL Listed UL 4248, Guide IZLT, File E14853; CSA Certified, Class 6225-01, File 47235. Flammability Rating: UL 94V0. H60030-3C H60030-2PR Features and Benefits • H600 fuse blocks provide one-, two- and three-pole housing for Class H, K and R fuses at 600Vac. • H600 fuse blocks are listed with a Short-Circuit Current Rating of 10kA RMS Sym. • R600 fuse blocks provide one, two and three pole housing for Class R fuses at 600Vac. • R600 fuse blocks are listed with a Short-Circuit Current Rating of 200kA RMS Sym. Typical Applications • 600Vac/dc or less Control Systems • 600Vac/dc or less Industrial Control • 600Vac/dc or less Individual Control Circuits Fuse Holders & Blocks Class H Fuseblocks (600V) Catalog Data (for NOS and RES Fuses) Terminal Type (Suffix No.) Screw Amps Poles Catalog Number ⁄10 1 H60030-1 to 2 H60030-2 30 3 H60030-3 31 1 H60060-1 to 2 H60060-2 60 3 H60060-3 61 1 H60100-1 to 2 H60100-2 100 3 H60100-3 101 H60200-1 1 to 3 H60200-3 200 201 1 H60400-1 to 3 H60400-3 400 401 1 H60600-1 to 3 H60600-3 600 †No UL, No CSA Certification. ‡UL Recognized, CSA Certification 1 — Clip with Reinforced Spring Pressure Plate S S S — — — — — — SR SR SR — — — — — — P P P — — — — — — — — — — — Box Lug w/ Pressure Plate & Clip with Reinforced Spring — Clip with Reinforced Spring Figure Number PR PR PR — — — — — — C C C C C C — — — CR CR CR CR CR CR CR CR CR 1 2 3 4 5 6 7 8 9 — — — CR 10 — — — CR 11 — — — — CR‡ 12 — — — — — CR† 13 — — — — — CR 14 — — — — — CR† 15 Wire Range C, CR #2-14 Cu, #2-12 Al P, PR, S, SR #10-18 Cu Only C, CR #2-14 Cu, #2-8 Al CR #1/0-8 Cu/Al CR 250kcmil-6 Cu/Al CR 500kcmil-4 Cu/Al CR (2) 500kcmil-4/0 Cu/Al Data Sheet: H600 Series, 1113; R600 Series, 1111 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 263 Fuse Holders and Blocks Class H(K) and R Fuse Blocks – 600V Class R Fuseblocks (600V) Catalog Data (for LPS-RK, FRS-R, DLS-R and KTS-R Fuses) Amps Poles Terminal Type (Suffix No.) Screw w/ Box Lug w/ Pres. Clip — Plate — Cu Only SR PR CR — SR PR CR COR SR PR CR COR — — CR — — — CR — — — CR — ⁄10 to 30 31 to 60 1 2 3 1 2 3 Catalog Number R60030-1 R60030-2 R60030-3 R60060-1 R60060-2 R60060-3 61 to 100 101 to 200 1 2 3 R60100-1 R60100-2 R60100-3 — — — — — — CR CR CR — — — 7 8 9 CR, 1/0-8 Cu/Al 1 3 R60200-1 R60200-3 — — — — CR CR — 10 11 CR 250kcmil-6 Cu/Al — — CR‡ CR† — — 12 13 — — CR CR† — — 14 15 1 201 1 R60400-1 — to 3 R60400-3 — 400 401 1 R60600-1 — to 3 R60600-3 — 600 †No UL, No CSA Certification. ‡UL Recognized, CSA Certification Fig. No. 1 2 3 4 5 6 Wire Range COR #6-14 Cu Only CR #2-14 Cu, #2-12 Al PR, SR #10-18 Cu Only CR #2-14 Cu, #2-8 Al CR 500kcmil-4 Cu/Al CR (2) 500kcmil-4/0 Cu/Al Dimensionals – in 600V, 1⁄10 to 30A 1.73 0.26 1.54 2.90 1.56 0.25 0.62 0.25 1.56 4.25 1.56 0.62 0.62 0.28 x 0.5 0.28 x 0.5 0.28 x 0.5 6.25 3.13 1.56 FIGURE 1. FIGURE 2. 600V, 31 to 60A 2.06" 0.25" 1.81" 0.59" 3.38" 1.56" 0.62" 0.62" FIGURE 3. 0.59" 4.94" 1.56" 1.56" 0.62" 0.28" DIA. x 0.5" C'BORE 7.36" 2.38" 3.125" 2.125" FIGURE 4. FIGURE 5. FIGURE 6. Data Sheet: H600 Series, 1113; R600 Series, 1111 264 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Class H(K) and R Fuse Blocks – 600V 600V, 61 to 100A 2.22 2.38 0.34 0.88 0.67 4.03 1.81 0.88 5.84 1.81 1.81 0.67 0.88 0.28 x 0.5 0.28 x 0.5 0.28 x 0.5 9.5 4.25 2.63 FIGURE 7. FIGURE 8. FIGURE 9. 600V, 101 to 200A 3.15 0.75 0.31 9.0" 8.0" 6.5" 3.0 2.0 0.5 0.34 DIAMETER 3.15" 0.75" 0.34 DIAMETER 0.75" C'BORE 3.0 9.63 9.58" 0.75" DIA. C'BORE 0.50" Deep 5.5" 3.0" 3.31 2.04" Fuse Holders & Blocks FIGURE 11. FIGURE 10. 600V, 201 to 400A 4.02 1.0 0.56 0.63 11.63" 9.25" 3.0 1.75 0.34 DIAMETER 12.0 0.75" C'BORE 4.02" 1.00" 1.19" 3.0 0.34 DIAMETER 0.75" DIA. C'BORE 0.67" Deep 12.00" 7.00" 4.5 2.5" FIGURE 12. FIGURE 13. 600V, 401 to 600A 4.987 1.0 0.56 1.125 4.0 1.75 2.13" 0.34 DIAMETER 14.0 0.75" C'BORE 15.26" 11.0" 4.987" 1.00" 0.34 DIAMETER 0.75" DIA. C'BORE 0.67" Deep 14.00" 8.00" 3.0 5.5 3.00" FIGURE 15. FIGURE 14. Data Sheet: H600 Series, 1113; R600 Series, 1111 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 265 Fuse Holders and Blocks Class J Fuse Blocks J600 Series Specifications Description: 1-, 2- or 3-pole fuse blocks for use with Class J fuses (Cooper Bussmann® LPJ, DFJ and JKS). Dimensions: See Dimensions illustrations. Construction: Thermoplastic. Poles: 1 to 3 Ratings: Volts: — 600Vac/dc Amps: — 1⁄2-600A SCCR: — 200kA RMS Sym. Agency Information: CE, UL Listed, UL 4248, Guide IZLT, File E14853, CSA Certified, C22.2 No. 4248, Class 6225-01, File 47235. Flammability Rating: UL 94V0. Mounting: Accepts DIN rail adapter DRA-1. Catalog Numbers Screw† J60030-1S* J60030-2S* J60030-3S* — — — — — — — — — — — Pressure Plate† J60030-1P J60030-2P J60030-3P — — — — — — — — — — — Box Lug J60030-1C J60030-2C J60030-3C J60060-1C J60060-2C J60060-3C — — — — — — — — Catalog Numbers Box Lug w/ Retaining Clip Amps J60030-1CR†† 1 1 ⁄2-30 J60030-2CR†† ⁄2-30 J60030-3CR†† J60060-1CR†† J60060-2CR†† J60060-3CR†† J60100-1CR J60100-3CR†† J60200-1CR J60200-3CR J60400-1CR** J60400-3CR** J60600-1CR J60600-3CR* 31-60 31-60 61-100 61-100 101-200 101-200 201-400 201-400 401-600 401-600 Features and Benefits • J600 fuse blocks provide one-, two- and three-pole housing for Class J fuses at 600Vac. • J600 fuse blocks are listed with a Short-Circuit Current Rating of 200kA RMS Sym. Typical Applications • 600Vac/dc or less Control Systems • 600Vac/dc or less Industrial Control • 600Vac/dc or less Individual Control Circuits Fig. No. 1 2 3 1 2 3 4 5 6 7 8 9 10 11 Poles 1 2 3 1 2 3 1 3 1 3 1 3 1 3 Wire Range C, CR #2-14 Cu, #2-8 Al COR #2-14 Cu Only P, PR, S, SR #10-14 Cu Only C, CR, #2-14 Cu/Al COR #4-14 Cu Only COR 1/0-8 Cu Only CR, CRQ 1/0-8 Cu/Al CR 250kcmil-6 Cu/Al CR 500kcmil -4 Cu/Al CR (2) 500kcmil-4/0 Cu/Al †Clip reinforcing springs are standard on fuse blocks rated 100A and above. Available on 30A and 60A blocks by adding the letter “R” to the end of the part number. ††Copper only connections available by changing “CR” suffix to “COR”. *No UL, No CSA Certification **UL Recognized, CSA Certification Dimensions - in (±0.015) ⁄2 - 60A 61-100A 1 2.415" 1.702 3.202 .750 2.250 4.702 2.250 .750 C L 5" 2.28" .30" 4.005 .94" 1.583" .22" Dia. .5" C'Bore 6.28" CL 3.14" 1.500 FIGURE 1. FIGURE 2. FIGURE 3. 1.75" FIGURE 4. Data Sheet: 1114 266 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 1.5" FIGURE 5. Fuse Holders and Blocks Class J Fuse Blocks 101-200A 3.15" 3.1" .75" 3" 2" .31" 3.06" 8.31" 7.00" .5" .75" C'Bore 6.125" .344" Dia. hole thru .750 Dia. c'bore 6.125" 1.69" .34" DIA. .750" FIGURE 7. FIGURE 6. 201-400A 4" 1" 3" 1.75" .56" 10.51" 4.00" 9.00" 6.00" .625" 3.5" 7.5" 7.50" .50" .344" Dia. hole thru .750 Dia. c'bore 2.00" .5" FIGURE 8. Fuse Holders & Blocks .75" C'Bore .34" DIA. 1.00" FIGURE 9. 401-600A 4.99" 4.987" 4" 1.75" 1" 14.144" 11.00" 1.125" .56" 3.25" 2.375" .344" Dia. hole thru .750 Dia. c'bore 8.875" .50" 8.875" 2.88" .75" C'Bore .34" Dia. 1.00" FIGURE 10. FIGURE 11. Data Sheet: 1114 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 267 Fuse Holders and Blocks Class J Fuse Blocks JP Series Dimensions - in (mm) ± 0.015” (± 0.40mm) Specifications Description: Pyramid style 3-pole fuse block for use with Class J fuses (Cooper Bussmann® LPJ, DFJ, JKS). Dimensions: See Dimensions illustrations. Ratings: Volts: — 600Vac/dc Amps: — 0-30A SCCR: — 200kA RMS Sym. Agency Information: CE, UL Listed, UL 4248, Guide IZLT, File E14853, CSA Certified, C22.2 No. 39, Class 4225-04, File 47235. Flammability Rating: UL 94V0. Mounting: Panel or 35mm DIN rail mount. DIN-RAIL MOUNTING SCREW 8" (203.2mm) APART END STOPS - PREVENT BLOCK MOVEMENT WHEN CHANGING FUSES 4.00" MAX. (101.6mm) 3.75" (±0.02) (95.3mm (±0.50) 1.88" (47.6mm) 1.19" (30.2mm) 2.38" (60.4mm) 3.29" (83.6mm) To order DIN rail: Part# NDNA 100 (1 meter) or NDNA 200 (2 meter). Catalog Numbers Catalog Numbers JP60030-3PR JP60030-3CR JP60030-3COR JP60030-3PRA JP60030-3CRA JP60030-CORA *Adapter only for Mounting With Screws DIN with Rail Pressure Panel Adapter* Plate Aluminum X X X X X X X X X X DIN rail - Cat No. JPA-3. Box Copper Only X X Wire Range #10-14 Cu Only #2-14 Cu/Al #2-14 Cu Only #10-14 Cu Only #2-14 Cu/Al #2-14 Cu Only 2.78" 3.06" (70.6mm) (77.8mm) ADAPTOR FOR 35mm SYMMETRICAL DIN-RAIL MOUNTING 3.13" (79.5mm) Data Sheet:1108 JA60030 Add-a-pole Specifications Description: Adder fuse block to achieve number of poles desired, for use with Class J fuses (Cooper Bussmann LPJ, DFJ & JKS). Dimensions: See Dimensions illustrations. Ratings: Volts: — 600Vac/dc Amps: — 0-30A SCCR: — 200kA RMS Sym. Agency Information: UL Listed, UL 4248, Guide IZLT, File E14853, CSA Certified, C22.2 No. 4248, Class 6225-01, File 47235. Flammability Rating: UL 94V0. Mounting: Panel or 35mm DIN rail mount. Features: Panel and DIN rail mount, adder block, retaining clip Amps Poles Screw Screw w/Retaining Clip ⁄2 - 30 ADDER 1 2 3 JA60030-AS JA60030-1S JA60030-2S JA60030-3S JA60030-ASR JA60030-1SR JA60030-2SR JA60030-3SR 1 268 Pressure Plate JA60030-AP JA60030-1P JA60030-2P JA60030-3P Pressure Plate w/Retaining Clip JA60030-APR JA60030-1PR JA60030-2PR JA60030-3PR Dimensions - in (mm) Box Lug Box Lug w/Retaining Clip Wire Range (Cu Only) JA60030-AC JA60030-1C JA60030-2C JA60030-3C JA60030-ACR JA60030-1CR JA60030-2CR JA60030-3CR S, SR, P, PR 10 - 18 AWG C, CR, 10 - 14 AWG For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Class T Fuse Blocks – 300V T300 Specifications Description: T300 (300V) fuse blocks for use with Class T fuses (Cooper Bussmann® JJN). Dimensions: See Dimensions illustrations. Poles: 1 to 4 Ratings: Volts: — 300Vac/dc Amps: — 1⁄2 - 600A SCCR:— 200kA RMS Sym. Agency Information: CE, UL Listed UL 4248, Guide IZLT, File E14853, CSA Certified, Class 6225-01, File 47235. Flammability Rating: UL 94V0. T30100-1CR T30030-2CR Features and Benefits • Provide 1-, 2- and 3-pole housing for 300Vac Class T fuses. • Short-Circuit Current Rating of 200kA RMS Sym. • Class T fuse blocks have a small foot print, providing substantial space savings in equipment T30600-1C Class T Fuse blocks (300V) Catalog Numbers Typical Applications • 300Vac/dc or less Control Systems • 300Vac/dc or less Individual Control Circuits Catalog Numbers Catalog Numbers Screw T30030-2SR T30030-3SR T30030-4SR T30060-2SR T30060-3SR T30060-4SR — — — — — — — Box Lug T30030-2CR T30030-3CR T30030-4CR T30060-2CR T30060-3CR T30060-4CR T30100-1CR T30100-2CR T30100-3CR T30200-1C T30200-3C T30400-1C T30600-1C Dimensions - in 1.63" 0.72" 0.16" Amps 1/2-30 1 ⁄2-30 31-60 31-60 61-100 61-100 101-200 101-200 201-400 401-600 Poles 2 3 4 2 3 4 1 2 3 1 3 1 1 Fig. No. 1 Wire Range 1 1 CR #2-14 Cu/Al SR #10-18 Cu Only 2 2 1/0-8 Cu/Al 3 4 5 6 600kcmil-2/0 Cu/Al (2) 600kcmil-4/0 Cu/Al 250kcmil-6 Cu/Al Figure 1. 1⁄2-60A 0.69" T30030-S SECTION X-X C 1.03 1.03 2.06 2.06 3.09 3.09 SR #10-18 Cu CR #6-14 Cu/Al 1.63" 0.72" 0.16" A B 1.20" 0.91" Dimensions (in) A B 2.41 — 2.41 — 3.44 1.03 3.44 1.03 4.47 2.06 4.47 2.06 Fuse Holders & Blocks Catalog Numbers T30030-2 T30060-2 T30030-3 T30060-3 T30030-4 T30060-4 X Z 0.91" 2.75" 2.5" X Z 0.44" Full 0.20" Radius C T30060-C SECTION Z-Z Data Sheet: 1115 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 269 Fuse Holders and Blocks Class T Fuse Blocks – 300V Figure 2. 61 to 100A Figure 3. 101 to 200A 1.69" (1 POLE) 3.09" (2 POLE) 4.5" (3 POLE) 2.06" 0.84" 6" 1.41" (2 POLE) 2.81" (3 POLE) X 0.05" 3" 1.125" 0.28" DIAMETER 0.63" C'BORE 0.5" DEEP 1.69" 0.22" DIA. 0.52" C'BORE 0.55" DEEP 2.25" REF. 4.78" 2.25" 1.25" Z 3.06" 2.56" 2.39" 1.94" 0.81" Z X 0.38" 0.75" Figure 5. 201 to 400A Figure 4. 200A 4.87" 6" 1.695" 3" .996" 2.25" 1.25" 1.125" 0.63" A 0.28" DIAMETER 0.63" C'BORE 0.5" DEEP 2.75" A 1.84" 0.282" DIAMETER THRU HOLE 0.625" C'BORE 0.438" DEEP 3.06" 2.38" 0.81" 2.375" 0.625" 4.46" Figure 6. 401 to 600A 2.03" 5.75" 2.88" 1.5" 3.44" 2" 3" 3" 0.75" 0.33" DIAMETER 0.75" C'BORE 0.5" DEEP Data Sheet: 1115 270 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Class T Fuse Blocks – 600V T600 Specifications Description: T600 (600V) fuse blocks for use with Class T fuses (Cooper Bussmann® JJS). Dimensions: See Dimensions illustrations. Poles: 1 to 3 Ratings: Volts: — 600Vac/dc Amps: — 1⁄2 - 600A SCCR:— 200kA RMS Sym. Agency Information: CE, UL Listed UL 4248, Guide IZLT, File E14853, CSA Certified, Class 6225-01, File 47235. Flammability Rating: UL 94V0. Features and Benefits • Provide 1-, 2- and 3-pole housing for 600Vac Class T fuses. • Short-Circuit Current Rating of 200kA RMS Sym. • Class T fuse blocks have a small foot print, providing substantial space savings in equipment Typical Applications • 600Vac/dc or less Control Systems • 600Vac/dc or less Individual Control Circuits T60600-1C T30030-2CR Catalog Numbers Screw T60030-1SR T60030-2SR T60030-3SR T60060-1SR T60060-2SR T60060-3SR — — — — — — — Box Lug T60030-1CR T60030-2CR T60030-3CR T60060-1CR T60060-2CR T60060-3CR T60100-1C T60100-2C T60100-3C T60200-1C 1B0089* T60400-1C T60600-1C Catalog Numbers Fig. Amps Poles No. 1 1 1 1 ⁄2-30 1/2-30 2 3 1 2 2 31-60 2 31-60 3 1 3 3 61-100 2 61-100 3 101-200 1 44 101-200 3 201-400 1 5 401-600 1 6 Wire Range SR #10-18 Cu CR #2-14 Cu/Al CR #2-14 Cu/Al SR #10-18 Cu Only 2/0-14 Cu/Al 250kcmil-6 Cu/Al 600kcmil-2/0 Cu/Al (2) 600kcmil-4/0 Cu/Al * UL Listed, Guide IZLT, File E14853, CSA Certified Class 6225-01, File 21455M18 Fuse Holders & Blocks Dimensions - in Figure 1. 1⁄2 to 30A 1.44" 0.55" 0.5" 1.44" 0.33" 0.55" 2.59" 1.16" 0.33" 0.55" 3.75" 2.31" 0.33" 0.22" DIAMETER 0.5" C'BORE 0.33" 3.19" 1.563" 1.42" Figure 2. 31 to 60A 1.75" 0.59" 0.5" 1.81" 0.63" 0.59" 3.34" 1.53" 0.63" 0.59" 4.86" 3.06" 0.63" 0.22" DIAMETER 0.5" C'BORE 2.94" 1.63" 1.47" Data Sheet: 1116 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 271 Fuse Holders and Blocks Class T Fuse Blocks – 600V Figure 3. 61 to 100A 1.69" (1 POLE) 3.09" (2 POLE) 4.5" (3 POLE) 1.41" (2 POLE) 2.81" (3 POLE) 0.84" X 0.78" Z 0.22" DIA. 0.52" C'BORE 0.55" DEEP 2.34" REF. 2.39" X 0.38" Z SECTION Z-Z 0.75" Figure 4. 101 to 200A Figure 5. 201 to 400A 6" 6" 0.05" 3" 3" 1.125" 1.25" 2.25" 2.25" 1.25" 1.125" 2.5" 0.28" DIAMETER 0.63" C'BORE 0.5" DEEP 0.63" 0.28" DIAMETER 0.63" C'BORE 0.5" DEEP 2.72" 3.06" 2.56" 1.94" 0.81" 3.06" 2.38" 0.81" Figure 6. 401 to 600A 2.95" 6.75" 3.38" 1.5" 3.44" 2" 3" 3" 0.75" 0.33" DIAMETER 0.75" C'BORE 0.5" DEEP Data Sheet: 1116 272 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Add-a-pole Fuse Blocks Dimensions in ± 0.015" (mm 0.38mm) BCA Series - Class CC fuses BMA Series - 13⁄32" X 1 1⁄2" fuses Adder Block Fuse Holders & Blocks Specifications Description: 1-, 2 and 3-pole fuse blocks for use with Class CC fuses (BCA Series use Cooper Bussmann® LP-CC, KTK-R, and FNQ-R), or with standard 13⁄32" x 1 1⁄2" fuses (BMA Series 1-Pole use Cooper Bussmann® KTK, FNQ, FNM, BAF, PV and AGU) Both Series use an "adder block" to form multi-pole segmented blocks to achieve the desired number of poles. Dimensions: See Dimensions illustration. 2-Pole Poles: 1 to 3. Wire Range: #10-#18 Cu only. Terminals: Screw/quick connect* or pressure plate/quick connect*. Ratings: Volts: — 600Vac/dc 3-Pole Amps: — 1⁄10-30A SCCR: — BCA Series: 200kA RMS Sym. BMA Series: 10kA RMS Sym. Agency Information: BCA Series: CE, UL Listed, UL 4248, Guide IZLT, File E14853. CSA Certified, C22.2 No. 4248, Class 6225-01, File 47235. BMA Series: CE, UL Recognized, UL 4248, Guide IZLT2, File E14853. CSA Certified, C22.2 No. 4248, Class 6225-01, File 47235. Flammability Rating: UL 94V0 *Quick connect rated for 20A maximum. Catalog Numbers BMA Series BCA Series Catalog Numbers BCA603ASQ BCA6031SQ BCA6032SQ BCA6033SQ BCA603APQ BCA6031PQ BCA6032PQ BCA6033PQ Poles Adder Block 1 2 3 Adder Block 1 2 3 Terminal Type Screw w/ quick connect Screw w/ quick connect Screw w/ quick connect Screw w/ quick connect Pressure plate w/ quick connect Pressure plate w/ quick connect Pressure plate w/ quick connect Pressure plate w/ quick connect Catalog Numbers BMA603ASQ BMA6031SQ BMA6032SQ BMA6033SQ BMA603APQ BMA6031PQ BMA6032PQ BMA6033PQ Poles Adder Block 1 2 3 Adder Block 1 2 3 Terminal Type Screw w/ quick connect Screw w/ quick connect Screw w/ quick connect Screw w/ quick connect Pressure plate w/ quick connect Pressure plate w/ quick connect Pressure plate w/ quick connect Pressure plate w/ quick connect Data Sheets: BCA Series 1154, BMA Series 1155 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 273 Fuse Holders and Blocks Class CC, Type M and Class G Fuse Blocks BC Series BM Series Type M Specifications Description: Class CC fuse blocks for use with Class CC fuses (Cooper Bussmann LP-CC, KTK-R, and FNQ-R). Dimensions: See Data Sheet 1105 Poles: 1 to 3 Ratings: Volts: — 600V Amps: — 1⁄10-30A SCCR:— 200kA RMS Sym. Agency Information: CE, UL Listed (Guide IZLT, File E14853), CSA (Class 6225-01, File 47235) Flammability Rating: UL 94V0 DIN Rail Adapters: See page 413 for DRA-1 & DRA-2 Catalog Numbers Screw BC6031S BC6032S BC6033S Screw with Quick Connect* BC6031SQ BC6032SQ BC6033SQ Terminal Type Pressure Plate w/ Pressure Quick Plate Connect* BC6031P BC6031PQ BC6032P BC6032PQ BC6033P BC6033PQ Box Lug BC6031B BC6032B BC6033B Specifications Specifications Description: Supplementary fuse Description: Class G fuse blocks for use blocks for use with any 13⁄32” x 11⁄2” fuses with Class G fuses (Cooper Bussmann SC). (Cooper Bussmann® KTK, FNQ, FNM, Dimensions: See Data Sheet 1106 BAF, PV, and AGU). Poles: 1 to 3 Dimensions: See Data Sheet 1104 Ratings: Poles: 1 to 3 Volts: — 600Vac/dc (0-20A) DIN Rail Adapters: See page 413 — 480Vac/dc (25-60A) for DRA-1 & DRA-2 Amps: — 1-60A (See Catalog Numbers Ratings: table) Volts: — 600Vac/dc SCCR: — 100kA RMS Sym. Amps: — 1⁄10-30A Agency Information: CE, UL Listed SCCR:— 10kA RMS Sym. 35-60A (Guide IZLT, File E14853), UL Agency Information: CE, UL Recognized 1-30A, (Guide IZLT2, File Recognized (Guide IZLT2, File E14853), CSA (Class 6225-01, File 47235). E14853), CSA (Class 6225-01, File DIN Rail Adapters: See page 413 for 47235). DRA-1 & DRA-2. Flammability Rating: UL 94V0. Catalog Numbers Catalog Numbers Terminal Type Poles 1 2 3 Data Sheet: 1105 BCCM Series Screw with Quick Connect* BM6031SQ BM6032SQ BM6033SQ Terminal Type Pressure Plate w/ Quick Box Connect* Lug BM6031PQ BM6031B BM6032PQ BM6032B BM6033PQ BM6033B Recommended Cover Puller Description: 3-pole fuse block for use with (2) Class CC fuses and (1) 13⁄32” x 11⁄2” fuse • PF1-WH (White) • PF1-BK (Black) Catalog Numbers Catalog Numbers BCCM6033SQ BCCM6033PQ BG & G Series Terminal Type Screw with Quick-Connect* Pressure Plate w/Quick-Connect* Poles 1 2 3 Screw with Quick Connect* BG3011SQ BG3012SQ BG3013SQ BG3021SQ BG3022SQ BG3023SQ BG3031S BG3032S BG3033S — — — Pressure Plate w/ Quick Connect* BG3011PQ BG3012PQ BG3013PQ BG3021PQ BG3022PQ BG3023PQ BG3031P BG3032P BG3033P — — — Box Lug w/retaining clip — — — — — — — — — G30060-1CR G30060-2CR G30060-3CR Recommended Cover Puller • PF1-WH (White) • PF1-BK (Black) *Quick-connect terminal rated for 20A max. Recommended Cover Puller • PF1-WH (White) • PF1-BK (Black) Data Sheet: 1104 274 Box Lug BG3011B BG3012B BG3013B BG3021B BG3022B BG3023B BG3031B BG3032B BG3033B — — G30060-3C Data Sheet: 1106 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Amps 1 1-15 to 15 20 20 Poles 1 2 3 1 2 3 25 1 25-30 to 2 30 3 35 1 35-60 to 2 60 3 Fuse Holders and Blocks Modular Fuse Blocks BH Series Modular Type Fuse blocks for Class H & J Fuses BH Series Features and Benefits • BH fuse blocks provide a wide range of mounting configurations for Cooper Bussmann high speed fuses. • BH fuse blocks have a Short-Circuit Current Rating of any installed fuse up to 200kA RMS Sym. Typical Applications • Solid State Control Circuits • VFDs • UPS Systems Catalog Numbers BH-0001 BH-0002 BH-0003 BH-0111 BH-0112 BH-0113 BH-0121 BH-0122 BH-1001 BH-1002 BH-1003 BH-1131 BH-1132 BH-1133 BH-2001 BH-2002 BH-2003 BH-2031 BH-2032 BH-2033 BH-3003 BH-3004 BH-3033 BH-3144 BH-3145 Class H & J Features and Benefits • H & J modular fuse blocks provide three pole 30 and 60 amp ratings for specific client requirements for separate line and load fuse clip configurations. Typical Applications • Up to 60A, space confined, control circuits Screw 11241-3SR* 11242-3SR 11241-3SR 11242-3SR** 11239-3SR 11240-3SR** 11241-3SR 11239-3SR* Catalog Numbers Fuse Pressure Plate Class Volts 11241-3PR* H 250 250 11242-3PR 11241-3PR 600 H 11242-3PR** 11239-3PR 600 11240-3PR** 11241-3PR J 600 J 11239-3PR* Amps 60 60 35 35 60 60 35 60 Fig. No. 1 2 1 2 1 2 1 1 Note: Order two blocks per fuse (matched or mixed.) *11239 and 11241 have wire terminals and mounting holes located under fuse. (Figure 1) **11240 and 11242 have wire terminals and mounting holes located at end of fuse. (Figure 2) Refer to the data sheet numbers below for the catalog code description information. Data Sheet: (BH-0) 1200; (BH-1) 1201; (BH-2) 1202; (BH-3) 1203 Figure 1 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Figure 2 275 Fuse Holders & Blocks Specifications Description: For use with Cooper Bussmann® high speed fuses. Ratings: SCCR: — 200kA RMS Sym. or fuse IR, whichever is lower. Agency Information: CE, UL Recognized, Guide EZLT2, File No. E14853 up to 700V, CSA Certified, Class 6225-01, File No. 47235 up to 700V. Specifications Description: 3-Pole only, modular type fuse blocks for Class H & J fuses with standard reinforced retaining clips. Ratings: Volts: — 250V (0-60A See Catalog Numbers table) — 600V (35-60A See Catalog Numbers table) Amps: — 0-60A @ 250Vac/dc (See Catalog Numbers table) — 35-60A@600V (See Catalog Numbers table) SCCR: — Class J 200kA, Class H 10kA Agency Information: CE, UL Recognized, Guide IZLT2, File E14853, CSA Certified, Class 6225-01, File 47235. Fuse Holders and Blocks Box Cover Units for Plug Fuses SOU, SRU, SSN, SSU, SOW, SRW, SSW, SOX, SRX, SSX, SOY, SRY, SSY, SSY-RL, SSY-L, STY, SCY, SOY-B & SKA Specifications Description: Box covers for standard electrical boxes that provide fused outlet, fused switch or circuit fuse protection. Ratings: Volts: — 125V/250V (See Catalog Numbers table) Amps: — 0-15A (See Catalog Numbers table) Agency Information: CE, See Catalog Numbers table. Features/Benefits • Cooper Bussmann® Box Cover Units provide a low-cost method of controlling and protecting small motors when used with Cooper Bussmann® Type T, Fusetron® , dual-element fuses. • Provide low-cost supplementary protection and disconnection of 125V or less, single phase circuits. SOU SRU SSU Typical Applications • Fractional Horsepower, 125 Volt Single-Phase Motor Circuits • General 125 Volt Supplemental Circuits STY SSN Catalog Numbers Catalog Numbers SOU SRU SSU SOW SRW SSW SOX SRX SSX SOY SRY SSY SSY-RL STY3 Type Box Handy 221⁄41"⁄4"Handy 223⁄43"⁄4"Switch Switch 4"Octagon Octagon 4" Square 4"4"Square Fuse holder 3 Single Double X X X X X X X X X X X X X X SCY X SOY-B SKA SSN X X 1 2 3 4 411⁄16" Square Single Gang X Receptacle Outlet to Load Switch 125V 250V Control1 Switch Light2 X X X X X X X X X X X X(2) X Motor Size (Max) 3 ⁄4hp 1 ⁄2hp 1 ⁄2hp 3 ⁄4hp 1 ⁄2hp 1 ⁄2HP 3 ⁄4hp 1 ⁄2hp 1 ⁄2hp 3 ⁄4hp 1 ⁄2hp 1 ⁄2hp 1 ⁄2hp 1 ⁄2hp 1 ⁄2hp (2) ⁄4hp 2hp 1 ⁄2hp 3 X(15A) X X General Data 125V, 15A 125V, 15A 125Vac, (do not use on dc), 15A 125V, 15A 125V, 15A 125Vac, (do not use on dc), 15A 125V, 15A 125V, 15A 125Vac, (do not use on dc), 15A 125V, 15A 125V, 15A 125Vac, (do not use on dc), 15A 125Vac, (do not use on dc), 15A 125Vac, (do not use on dc), 15A 125Vac, (do not use on dc), can protect two motors, 15A 125V, protects two motors, 15A 250V, 15A single phase Weatherproof model, 15A Switch turns power to fused load OFF or ON. Switch light indicates power to load (dark when switch OFF or fuse open). Double pole switch opens both sides of circuit. Can be used for two separate motors with common switch or a single motor (3⁄4Hp, 250Vac max.). UL Guide JAMZ, File IE6491; CSA Class 6225-01, File 47235. Data Sheet: 1129 276 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Agency4 Listing/ Certification UL, CSA UL UL, CSA UL, CSA UL UL, CSA UL, CSA UL UL, CSA UL, CSA UL UL, CSA — UL UL UL UL UL Fuse Holders and Blocks In-line Fuse Holders for 1⁄4" x 7⁄8" to 11⁄4" Fuses HFB & HFB-10 HHB HRK Specifications Description: Waterproof in-line fuse holder for 1⁄4" x 11⁄4" fuses. Dimensions: See Dimensions illustration. Construction: Thermoplastic rubber body with tin-plated, copper contacts. Ratings: Volts: — 32V Amps: — 30A max Specifications Description: Universal in-line fuse holder for 1⁄4" x 7⁄8", 1" and 11⁄4" fuses. Dimensions: See Dimensions illustration. Construction: Nylon body with tinplated, copper contacts. Ratings: Volts: — 32V Amps: — 30A max Flammability Rating: UL 94V2. Pull Force: 5lbs minimum to separate fuse holder housing with fuse installed. Specifications Description: Universal in-line fuse holder for 1⁄4" x 7⁄8" to 1 1⁄4" fuses. Dimensions: See Dimensions illustration. Construction: 8" (203mm) #14 lead wires. Ratings: Volts: — 32V Amps: — 15A max Catalog Numbers Description Standard Pack (10-in) Bulk Pack (100-in) HFB Replacement Contact Clip HFB-10** Replacement Contact Clip *HFB accepts #12 to #18 wire leads (not provided). See Data Sheet for recommended crimp tools. **HFB-10 accepts #10 wire leads (not provided). See Data Sheet for recommended crimp tools. Features/Benefits • Simple assembly with one-piece thermoplastic (important information molded into body) • High visibility yellow color for easy identification in dark or hard-to-access locations • Ideal for shock and vibration environments; withstands many organic solvents; temperature range -40/+150°C Typical Applications • Supplemental, Low Voltage, Low Amperage Control Circuits Features and Benefits • HHB Universal in-line fuse holder for 1 ⁄4" x 7⁄8", 1" and 1 1⁄4" fuses. Typical Applications • Supplemental, Low Voltage, Low Amperage Control Circuits Catalog Numbers Holder — without leads* - RoHS compliant Catalog Numbers Description HHB-R Standard Pack (10-in) BK/HHB-R Bulk Pack (100-in) *Accepts #12 to #16 wire leads (not provided with basic fuse holder). See Data Sheet for recommended crimp tools. Holder — with pre-attached #14 Insulated lead wires - Not RoHS compliant unless noted Catalog Numbers Wire 19" Length 8" Length Color BK/HHB-Y419 BK/HHB-Y408 Yellow BK/HHB-R419 BK/HHB-R408** Red BK/HHB-B419 BK/HHB-B408 Black Features and Benefits • HRK Universal in-line fuse holder for 1 ⁄4" x 7⁄8", 1" and 11⁄4" fuses with #14 lead wires. • RoHS compliant Typical Applications • Supplemental, Low Voltage, Low Amperage Control Circuits Catalog Number Catalog Number HRK-R* Amp Rating Volts 15 32 Fuse Description ⁄4" diameter fuses of different lengths. 1 *Three springs furnished with fuse holder to accommodate different length 1⁄4" fuses. Dimensions - in (mm) 2.19" (55.6mm) 0.75" (19.1mm) 0.69" (17.5mm) 1.56" (39.7mm) **RoHS compliant. 0.38" (9.5mm) Dimensions - in (mm) Dimensions - in (mm) Fuse Length 7 ⁄8" (AGW) 1" (AGX) 11⁄4" (AGC, MDL) 3" (76.2mm) Fuse Holder Length “L” 2.100 Max 2.250 Max 2.420 Max L 0.75" 0.53" (19.1mm) Data Sheet: 2102 (13.5mm) Data Sheet: 2103 Data Sheet: 2111 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 277 Fuse Holders & Blocks Catalog Numbers HFB* BK/HFB BK/1A2294 1A2294-01 Fuse Holders and Blocks In-line Fuse Holders HR and HM Series Specifications Description: In-line fuse holders for SFE and 1⁄4" dia. x various length fuses. Dimensions: See Dimensions illustration. Ratings: Volts: — 32V Amps: — 20A Features and Benefits • HR and HM Universal in-line fuse holder for SFE and various length 1⁄4" diameter fuses with #14 lead wires. Typical Applications • Supplemental, Low Voltage, Low Amperage Control Circuits Catalog Numbers Catalog Numbers HRJ* HRI HRH HRE HRG HRF HMJ** HMI HMH HME HMG HMF Includes Fuse SFE-20 SFE-14 SFE-9 SFE-71⁄2 SFE-6 SFE-4 SFE-20 SFE-14 SFE-9 SFE-71⁄2 SFE-6 SFE-4 Wire Length & Size 19” of #14 HHJ-B HHI-B 8” of #14 For 1⁄4" x 11⁄4" fuse, no wire or fuse included, accepts #18 - #22 wire. For 1⁄4" x 11⁄4" fuse, no wire or fuse included, accepts #12 - #16 wire. Specifications Description: In-line water-resistent fuse holders for 1⁄4" x 11⁄4" fuses. Dimensions: See Dimensions illustration. Construction: Phenolic body with copper crimp contact leads. Ratings: Volts: — 250V Amps: — 20A Agency Information: CE, UL Recognized, (Guide IZLT2, File E14853) UL. Flammability Rating: UL 94HB. Specifications Description: In-line fuse holders for 5 x 15mm or 5 x 20mm fuses. Dimensions: See Dimensions illustration. Construction: Black thermoplastic body with brass contacts, wire: 16 AWG, red. Ratings: Volts: — 32V Amps: — 5A (5 x 15mm) — 10A (5 x 20mm) Typical Applications • Supplemental, Low Voltage, Low Amperage Control Circuits Features and Benefits • HHT in-line fuse holders for 5 x 15mm and 5 x 20 mm fuses. Typical Applications • Supplemental, Low Voltage, Low Amperage Control Circuits Catalog Numbers Catalog Number HHT Refer to data sheet for recommend crimp tools Fuse Size 5 x 15mm & 5 x 20mm Dimensions - in 1/4" ± 1/32" Catalog Numbers For 1⁄4" x 11⁄16" fuse, no wire or fuse included, accepts #12 - #16 wire. Replacement Contacts Catalog Number 9838 9841 HHT Series Features and Benefits • HFA in-line, water-resistent fuse holder for 1⁄4" x 11⁄4" fuses. * Also available as in-line fuse holder only with lead wire contacts, HRJ-LESS-Fuse. ** Also available as in-line fuse holder only with lead wire contacts, HMJ-LESS-Fuse. HHJ-A HFA Series Catalog Numbers HFA HFA-HH* 6-3/16" ± 1/4" Terminals Crimp #12 - #16 1 ⁄4" Quick Connect *No UL Recognition. Symbol HHJ-A HHJ-B 1.84" WIRE LENGTH: 13" ± 0.5" Dimensions - in (mm) 0.42" DIA. 2.34" (59.5mm) 1.84" Dimensions - in (mm) .800" .600" (20.3mm) (15.2mm) 2.19" (55.6mm) 0.75" (19.1mm) 0.69" (17.5mm) 1.56" (39.7mm) Data Sheet: 2122 278 6-1/16" ± 1/4" (IN ASSEMBLED POSITION) 0.38" (9.5mm) Data Sheet: 2115 Data Sheet: 2138 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Tron™ In-line Fuse Holders HEG Series HEH Series HEC Series HEJ Series Specifications Description: Single-pole, non-breakaway, in-line fuse holders for Type SC fuses, 480V (or less). Ratings: Volts: — 600V Amps: — 0-15A Fuse Size: 13⁄32" x 1.31" Specifications Description: Single-pole, non-breakaway, in-line fuse holders for Type SC fuses (Also fuse types BBS & KTQ, nominal size 13⁄32" x 1 3⁄8"). Ratings: Volts: — 600V Amps: — 0-20A Agency Information: CSA - 15A. Specifications Description: Single-pole, non-breakaway, in-line fuse holders for Type SC-25, & SC-30 fuses, size 13 ⁄32" x 1 5⁄8". Ratings: Volts: — 480V Amps: — 0-30A Specifications Description: Single-pole, non-breakaway, in-line fuse holders for Type SC and Type HVW fuses, size 13⁄32" x 2 1⁄4". Ratings: Volts: — 480V Amps: — 35-60A Type SC — 1⁄2-6A Type HVW Catalog Number HEG-AA Catalog Numbers Optional Boots: HEH-AA, HEH-AD 2A0660 Single Conductor 2A0661 Two Conductor Optional Boots: Catalog Numbers Catalog Numbers HEC-AA, HEC-RW-RLB-R HEJ-AA, HEJ-AB, HEJ-AC, HEJ-BB, HEJ-JJ, HEJ-JK, HEJ-LL, HEJ-LLB, HEJ-CC, HEJ-DD, HEJ-WW, HEJ-PP, HEJ-QQ Optional Boots: 2A0660 Single Conductor 2A0661 Two Conductor Optional Boots: 2A0660 Single Conductor 2A0661 Two Conductor Fuse Holders & Blocks 2A0660 Single Conductor 2A0661 Two Conductor Data Sheet: 2124 Data Sheet: 2124 Data Sheet: 2124 Data Sheet: 2123 HEB Series HET Series HEY Series HEX Series Specifications Description: Double-pole in-line fuse holders for KTKR fuses with optional breakaway receptacle, polarized, and accepting Class CC branch circuit fuses (Cooper Bussmann® KTK-R, FNQ-R & LP-CC; 600V or less, 200,000A IR). Ratings: Volts: — 600V Amps: — 0-30A Specifications Description: Double-pole inline fuse holders for 13⁄32" x 1 1⁄2" fuses (typically fuse types BAF, FNM, FNQ, and KTK 1 ⁄10 - 30A). Ratings: Volts: — 600V Amps: — 0-30A Specifications Description: Single-pole in-line fuse holders for any 13 ⁄32" x 1 1⁄2" fuses (typically fuse types: BAF, FNM, FNQ, and KTK 1⁄10 - 30A). Ratings: Volts: — 600V Amps: — 0-30A Catalog Numbers See Page 280 Specifications Description: Single-pole in-line fuse holders for 13 ⁄32" x 1 1⁄2" fuses with a permanently solid neutral identified by white plastic coupling nut. Catalog Numbers HET-AA, HET-AB, HET-AW, HETAW-RLC-A, HET-AW-RLC-B, HETAW-RLC-C, HET-AW-RLC-J, HETAW-RYC, HET-BB, HET-BW-RLC-B, HET-BW-RYC, HET-JJ, HET-JK, HET-JW, HET-JW-RLC-J, HET-JWRYC, HET-KK Catalog Numbers HEY-AA, HEY-AB, HEY-AC, HEYAD, HEY-AE, HEY-AL, HEY-AWDRLC-A, HEY-AW-DRLC-B, HEYAW-DRYC, HEY-BB, HEY-JJ Data Sheet: 2127 Data Sheet: 2125 Data Sheet: 2126 Catalog Numbers HEX-AA, HEX-AB, HEX-AC, HEX-AD, HEX-AE, HEX-AW, HEX-AW-DRLC-A, HEX-AW-DRYC, HEX-AW-RLC-A, HEX-AW-RYC, HEX-AY, HEX-BB, HEX-CC, HEX-JJ, HEX-JK, HEX-JWDRYC, HEX-KK Data Sheet: 2126 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 279 Fuse Holders and Blocks For HEB Holders Only Directions: To select complete holder P/N, work from left to right starting with loadside terminal options and then lineside terminal options. Then determine breakaway or non-breakaway style. Lineside Terminal Loadside Terminal Terminal Type Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Setscrew Copper Setscrew Copper Setscrew Copper Setscrew Aluminum Setscrew Aluminum Crimp Aluminum Crimp Aluminum Crimp Aluminum Crimp Aluminum Crimp No. of Terminal Wire Size Wires per Solid Stranded W i r e W i r e T ype Terminal #12 to #8 #12 #12 to #8 #12 #12 to #8 #12 #12 to #8 #12 #12 to #8 #12 #12 to #8 #12 #12 to #8 #12 #12 to #8 #12 #12 to #8 #12 #12 to #8 #12 #6 #10 #6 #10 #6 #10 #6 #10 #4 #8 #2 #6 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 1 2 Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y N Y N Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y #20, #18 1 Y Y #12 to #3 1 Y Y #12 to #3 1 Y Y #12 to #3 1 Y Y #12 to #3 1 Y Y #12 to #2 1 Y Y #8 #6 #6 #4 #3, #4 #2 1 1 1 1 1 1 N Y N Y N Y Y N Y N Y N #1, #2 1 N Y 1/0 1 N Y 1 Y N 1 N Y SolidTerminal #8 to #12 for aluminum connector #10 to #14 (1)UL Recognized, Guide IZLT2, File E14853 (2)CSA Certified, Class 6225-01, File 47235 (3)CE (4)HEB-AW-RLC-C is for (1) #4 stranded wire only. 280 Copper Crimp Copper Crimp Copper Crimp (4) Copper Crimp Copper Crimp Copper Setscrew Copper Setscrew Aluminum Setscrew Aluminum Setscrew Aluminum Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Crimp Copper Setscrew Copper Setscrew Aluminum Setscrew Aluminum Setscrew Aluminum Setscrew Aluminum Crimp Aluminum Crimp Aluminum Crimp Aluminum Crimp Aluminum Crimp Available P/N’s No. of Wire Size Wires per Solid Stranded Wire Terminal Wire #12 to #8 #12 #6 #10 #4 #8 #2 #6 2/0 #3 1 2 1 2 1 2 1 2 1 2 Y Y Y Y N Y N Y N N Y Y Y Y Y Y Y Y Y Y #12 to #3 1 Y #12 to #3 2 #12 to #2 #12 to #2 Non-Breakaway P/N Breakaway P/N (Boots not included) (Boots included) HEB-AA(1)(2) (3) HEB-AW-RLC-A(1)(2) (3) HEB-AB(2) HEB-AW-RLC-B HEB-AC(2) HEB-AW-RLC-C(4) HEB-AD(2) N/A HEB-AE(2) N/A Y HEB-AJ HEB-AW-RLC-J Y Y HEB-AK HEB-AW-RYC 1 Y Y HEB-AL HEB-AW-RLA 2 Y Y HEB-AY HEB-AW-RYA #1, #2 1 N Y HEB-AR N/A #12 to #8 #12 #6 #10 #4 #8 #2 #6 #4 #8 #2 #6 #12 to #8 #12 1 2 1 2 1 2 1 2 1 2 1 2 1 2 Y Y Y Y N Y N Y N Y N Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y Y HEB-BA(2) HEB-BW-RLC-A HEB-BB(2) HEB-BW-RLC-B HEB-BC(2) N/A HEB-BD(2) N/A HEB-CC(2) N/A HEB-DD(2) N/A HEB-ZA N/A #12 to #3 1 Y Y HEB-JJ HEB-JW-RLC-J #12 to #3 2 Y Y HEB-JK HEB-JW-RYC #12 to #2 1 Y Y HEB-JL N/A #12 to #2 2 Y Y HEB-JY N/A #12 to #2 1 Y Y HEB-LL HEB-LW-RLA #8 #6 #6 #4 #3, #4 #2 1 1 1 1 1 1 N Y N Y N Y Y N Y N Y N HEB-NN N/A HEB-PP(2) N/A HEB-QQ(2) N/A #1, #2 1 N Y HEB-RR(2) N/A 1/0 1 N Y HEB-TT(2) N/A 1 Y N 1 N Y HEB-SS N/A SolidTerminal #8 to #12 for aluminum connector #10 to #14 Insulating boots for single conductor-2A0660 Dual conductor-2A0661 Contact your local Cooper Bussmann representative for other possible terminations not listed. For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Data Sheet: 2127 Fuse Holders and Blocks Panel Mounted Fuse Holders for 5 x 20mm Fuses HTC-35M 37.5mm 12.70mm +0.0 –0.1 Ø15mm 4mm 5.5mm HTC-40M Data Sheet: 2110 11mm 12.00mm +0.0 –0.1 12.70mm +0.0 –0.1 3.0x0.51mm Ø15mm Ø22mm 37.5mm Ratings: Volts: — 250Vac Amps: — 10A UL, 6.3A VDE Fuse Access: Screwdriver slot 12.00mm +0.0 –0.1 3.0x0.51mm Ø16mm Ratings: Volts: — 250Vac Amps: — 10A UL, 6.3A VDE Fuse Access: Threaded cap 6.5mm Data Sheet: 2110 36mm HTC-55M 12.00mm +0.0 –0.1 3.0x0.51mm Ø15mm Ratings: Volts: — 250Vac Amps: — 10A UL, 6.3A VDE Fuse Carrier: Bayonet type 12.70mm +0.0 –0.1 Ø16mm 0.5mm 4mm 5.5mm 11mm 35.5mm Data Sheet: 2110 10.2mm 12.00mm +0.0 –0.1 0.5mm 4mm 5.5mm 11mm Fuse Holders & Blocks Ratings: Volts: — 250Vac Amps: — 10A UL, 6.3A VDE Fuse Carrier: Bayonet type 4.8x0.51mm Ø15mm HTC-70M 12.70mm +0.0 –0.1 Ø16mm Data Sheet: 2110 Specifications Terminals: Molded Materials: Solderability: Agency Information: Electrical: Shock Safety: Packaging: Tin-plated brass. High temperature thermoplastic that meets the flammability ratings of UL 94V0; Glow Wire Test: 960°C per IEC 60695-2-1. In accordance with IEC 68-2-20. cURus, VDE Contact Resistance: ≤ 10 megohm; Insulation Resistance: ≥ 10MΩ; Dielectric Strength ≥ 2000Vac. PC2 (fuse holders). Standard Qty 10 (No Prefix), Bulk Qty 100 (Prefix Catalog Number with BK/). For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 281 Fuse Holders and Blocks Panel Mounted Fuse Holders for 1⁄4" x 11⁄4" Fuses HKP, HKP-L, HKP-W HKP-BBHH, HKP-HH and HKP-LW-HH HKP-OO Specifications Description: Standard fuse holders. Dimensions: See Dimensions illustration. Ratings: Volts: — 250V Amps: — 30A Specifications Description: Fuse holders with 1⁄4" quick-connects. Dimensions: See Dimensions illustration. Ratings: Volts: — 250V Amps: — 15A Catalog Numbers Specifications Description: Snap-lock fuse holders. Dimensions: See Dimensions illustration. Ratings: Volts: — 250V Amps: — 30A Catalog Numbers Catalog Numbers Catalog Numbers HKP HKP-L HKP-W Fuse Description — HKP w/ 2250V stand-off barrier HKP w/ drip-proof knob Catalog Numbers HKP-BBHH HKP-HH HKP-LW-HH Dimensions - in (mm) Fuse Description HKP w/ 1⁄4" quick-connects, nut and washer assembled. HKP w/ 1⁄4" quick-connect. HKP w/ drip-proof knob, 2250V stand-off barrier and 1⁄4" quick-connects. Catalog Number HKP-OO Fuse Description HKP with snap-lock Dimensions - in (mm) .75" (19.1mm) 1.56" (39.7mm) SE F US E FU Dimensions - in (mm) .855" (21.7mm) 1.17" FUSE .800" (20.3mm) Punched Mounting Hole .890" (22.6mm) .811" (20.6mm) Data Sheet: 2106 Data Sheet: 2106 Data Sheet: 2106 Specifications Terminals: Agency Information: Replacement Parts: 282 Bayonet-type knob. Vibration resistant. For panels up to 5⁄16" (7.9mm) thick. CE (HKP, HKP-L, HKP-W, HKP-OO), UL Recognized — Guide IZLT2, File E14853, CSA Certified — Class 6225-01, File 47235 Cap: 9435-1/2 Plastic Nut: BK/1A4287 (100 pieces minimum) Metal Nut: BK/1A4806-2 (100 pieces minimum) Washer: 9732 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Panel Mounted Fuse Holders for 5 x 20mm and 1⁄4" x 1 1⁄4" Fuses HTB Series Specifications Description: Fuse holders with knob-type carriers. Dimensions: See Dimensions illustrations. Construction: High temperature, flame retardant thermoplastic; UL Component Recognized; UL 94V0; mounting nut, spacer-black polycarbonate. Terminals: tin-plated brass. Electrical Data: Insulation resistance (per IEC #257) — 10,000 ohms @ 500Vdc; contact resistance (per IEC #257) — 0.005 ohms Max @ 1A; standoff voltage (per IEC #257) — 480V/Mil @ 0.125” thickness. Agency Information: CE, UL Recognized — Guide IZLT2, File E14853, 1⁄4˝ dia fuse @ 20A, 5mm dia fuse @16A @ 250V, CSA — 16A @ 250V Class 6225-01 File 47235; VDE Certified: 136128, HTB-XXM, SEMKO Certification: Ref. #0146149/01, HTB-XXM. Mounting: Withstands 15 to 20 Lb-In torque to mounting nut when mounting fuse holder to panel. Environmental: Maximum operating temperature -55°C to 85°C. Replacement Parts Dimensional Data - in (mm) Knob Type Carrier Terminal Options Maximum Panel Thickness Common Dimensions: Length (Knob Type) - 1.69" (42.9mm) Plus In-Line Terminal NOTE: Plus In-Line Terminal 0.47" 1.125" (11.9mm) (28.6mm) Fuse Holders & Blocks Solder/ 3 ⁄16" Quick-Connect Carrier Options ⁄4" Quick-Connect 1 ⁄4" x 11⁄4" 5 x 20mm (“I” Equals Inches) (“M” Equals Metric) Knob Knob 1 In-Line 0.34" 8.7mm) Rt. Angle 0.33" (8.3mm) In-Line 0.47" (11.9mm) HTB-26I-R Rt. Angle 0.45" (11.5mm) 0.30” HTB-22I-R HTB-24I-R HTB-28I-R 7.62mm HTB-22M-R HTB-24M-R HTB-26M-R HTB-28M-R 0.125” HTB-42I-R HTB-44I-R 3.18mm HTB-42M-R HTB-44M-R HTB-46M-R HTB-48M-R 0.30” HTB-62I-R HTB-64I-R 7.62mm HTB-62M-R HTB-64M-R HTB-66M-R HTB-68M-R 0.125” HTB-82I-R HTB-84I-R 3.18mm HTB-82M-R HTB-84M-R HTB-86M-R HTB-88M-R X X 0.09" NOM. (2.4mm) 0.69" 0.91" (17.5mm) (23.0mm) 0.67" 0.92" (17.1mm) (23.4mm) 0.47" 1.125" (11.9mm) (28.6mm) HTB-46I-R HTB-66I-R HTB-86I-R HTB-48I-R HTB-68I-R HTB-88I-R X X X X X Fuse holders and fuse carriers may be ordered separately. For product data sheets, visit www.cooperbussmann.com/products/datasheets/ulcsa X Data Sheet: 2119 283 Fuse Holders and Blocks Panel Mounted Fuse Holders for 5 x 20mm and 1⁄4" x 1 1⁄4" Fuses HTB Series Dimensional Data - in (mm) Screwdriver Type Carrier Terminal Options Carrier Options Solder/ 3 ⁄16" Quick-Connect Maximum Panel Thickness Common Dimensions: (Screwdriver Slotted) 1.75" (44.5mm) NOTE: Plus In-Line Terminal 0.17" 1.58" (4.37mm) (40.03mm) In-Line Rt. Angle 0.34" ⁄4" Quick-Connect 1 0.47" 0.33" 8.7mm) Rt. Angle In-Line 0.45" (11.9mm) (8.3mm) 1 ⁄4" x 1 1⁄4" 5 x 20mm (“I” Equals Inches) (“M” Equals Metric) Screwdriver Screwdriver (11.5mm) 0.30” HTB-32I-R HTB-34I-R HTB-36I-R HTB-38I-R 7.62mm HTB-32M-R HTB-34M-R HTB-36M-R HTB-38M-R 0.125” HTB-52I-R HTB-54I-R 3.18mm HTB-52M-R HTB-54M-R HTB-56M-R HTB-58M-R 0.125” HTB-92I-R HTB-94I-R 3.18mm HTB-92M-R HTB-94M-R HTB-96M-R HTB-98M-R X X HTB-3 0.41" 1.34" (10.31mm) (34.13mm) HTB-5 0.17" 1.59" (4.37mm) (40.08mm) HTB-9 HTB-56I-R HTB-96I-R HTB-58I-R HTB-98I-R X X X X Catalog Number Build-A-Code FUSE CARRIER ONLY HTBS Packing Blank (Std.) – 10 fuse holders in a carton BK – 100 fuse holders in a cardboard shelf package Product Symbol Body Configuration and Mounting Knob Holders 2 — Low Profile (Rear Panel Hex-Nut) 4 — High Profile 6— * (Front Panel Hex-Nut) 8 — Low Profile (Snap-In) Screwdriver Slotted Holders 3 — Low Profile 5 — High Profile 9 — Low Profile (Snap-In) Fuse Carrier I — 1/4˝ x 1 1/4˝ M — 5 x 20mm Rear Terminal Configuration 2 — Solder / 3/16˝ Quick-Connect (In-Line) 4 — Solder / 3/16˝ Quick-Connect (Right Angle) 6 — 1/4˝ Quick-Connect (In-Line) 8 — 1/4˝ Quick-Connect (Right Angle) P Splash Proof Cap with O-Ring (Optional on Knob Holders Only) -R RoHS Compliant Packaging (Blank) – Std. BK/ – Bulk Product Symbol FT — Knob Type (For 20, 40, 60, and 80 Series Only) ST — Screwdriver Slotted (For 30, 50, and 90 Series Only) *Profile varies with panel thickness. Holder installs through rear of panel. Data Sheet: 2119 284 For product data sheets, visit www.cooperbussmann.com/products/datasheets/ulcsa Fuse Carrier I — 1/4˝ x 1 1/4˝ M — 5 x 20mm Fuse Holders and Blocks Panel Mounted Fuse Holders for Indicating Type Fuses HLD HJL HK Series Specifications Description: Pin indicating for 1 ⁄4" x 11⁄4" fuses. Dimensions: See Dimensions illustration. Ratings: Volts: — 250V Amps: — 15A Agency Information: CE, UL Recognized, File E14853, Guide IZLT2. Specifications Description: Neon lamp indicating for 1 ⁄4" x 1" fuses. Dimensions: See Dimensions illustration. Ratings: Volts: — 250V Amps: — 15A Agency Information: None Specifications Description: Neon and incandescent lamp indicating for 1⁄4" x 11⁄4" fuses Dimensions: See Dimensions illustration. Ratings: Volts: — 250V Amps: —15A (HKL, HKL-X) — 20A (HKR, HKT, HKU, HKX) Agency Information: CE, UL Recognized, (Guide IZLT2, File E14853), CSA Certified (Class 6225-01, File 47235). Catalog Numbers Catalog Numbers* HLD HLD-HH Terminals Solder terminals 1 ⁄4" quick-connect terminals *Use w/GBA, GLD Fuses. Catalog Number Catalog Number* HJL Lamp Volts Color 90 to 250 Clear Knob Type Oct *Use with AGX or MKB fuses, for panels up to 1⁄8" thick. Catalog Numbers Dimensions - in (mm) 2.81" (71.4mm) 1.19" (30.2mm) 2.5" (HLD) (63.5mm) 0.81" (20.6mm) 0.69" (17.5mm) Octagonal Sides Octagonal Sides (69.9mm) (16.0mm + .13mm) Knob Color/Type Clear/Oct Clear/FS Amber/Oct Amber/Oct Red/Oct Amber/FS * Neon lamp — UL Recognized and CSA Certified. ** Incandescent lamp. 2.75" (HLD-HH) Punched Mounting Hole Punched Mounting Hole .505" + .005" Lamp Volts 90-250 90-250 22-30 13-22 4-6 22-33 Dimensions - in (mm) .630" + .005" (16.0mm + .13mm) 2.81" .590" + .003" (14.6mm + .08mm) .473" + .005" (71.4mm) Flat-Sides 1.19" (30.2mm) (12.0mm + .13mm) 0.81" (20.6mm) Octagonal Sides Punched Mounting Hole .630" + .005" (16.0mm + .13mm) .573" + .003" (14.6mm + .08mm) Data Sheet: 2120 Data Sheet: 2121 Data Sheet: 2105 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 285 Fuse Holders & Blocks Dimensions - in (mm) Catalog Numbers HKL* HKL-X* HKR** HKT** HKU** HKX** Fuse Holders and Blocks Panel Mounted Fuse Holders for 13⁄32" x 1 5⁄16" to 1 1⁄2" Fuses HPF HPS HPG HPD #10 wire max for solder connection Specifications Description: Standard fuse holders with screw-type knob for 13⁄32" x 15⁄16" to 11⁄2" Fuses. Dimensions: See Dimensions illustration. Agency Information: CE, UL Recognized, Guide IZLT2, File E14853; CSA Certified, Class 6225-01, File 47235. Flammability Rating: UL 94HB. Terminals: Combination 1⁄4" quick-connect/solder terminals. Catalog Numbers Catalog Numbers HPF HPF-C HPF-L HPF-EE HPF-JJ HPF-FF1 HPF-RR Amp Ratings 302 303 5 15 20 302 302 Volts 600 6003 600 600 600 480 600 HPF-WT 302 600 1 2 3 Specifications Description: Standard fuse holders with bayonet-type knob for 13⁄32" x 15⁄16" to 11⁄2" fuses. Dimensions: See Dimensions illustration. Agency Information: CE, UL Recognized, Guide IZLT2, File E14853; CSA Certified, Class 6225-01, File 47235. Flammability Rating: UL 94HB. Terminals: Combination 1⁄4" quickconnect/solder terminals. Catalog Numbers Fuse Description 1 1⁄2" (38.1mm) 1 1⁄2" (38.1mm) clear knob. BBS, 13⁄32" x 1 3⁄8" fuses. SC 0-15, 13⁄32" x 1 5⁄16" fuses. SC 20, 13⁄32" x 1 13⁄32" fuses. SC 25 & 30, 13⁄32" x 1 5⁄8" fuses. KTK-R, LP-CC & FNQ-R Class CC fuses. Splash-proof knob. 13⁄32" x 1 1⁄2" (38.1mm) No CSA Certification 20A max when used with quick-connect terminals. HPF-C ratings for CSA-15A, 250V Dimensions - in (mm) Catalog Symbol HPS HPS-L HPS-EE* HPS-JJ* HPS-F-EE1 Amp Ratings 30 2 3 5 15 20 15 Volts 600 600 600 600 600 Fuse Description ⁄32" x 1 1⁄2" BBS, 13⁄32" x 1 3⁄8" fuses. SC 0-15, 13⁄32" x 1 5⁄16" fuses. SC 20, 13⁄32" x 1 13⁄32" fuses. Sleeve on body, leaded for 13 ⁄32" x 15⁄16" fuses. 1 2 HPS-FF* 30 480 SC 25 & 30, 13⁄32" x 1 5⁄8" fuses. HPS-RR*1 30 2 600 KTK-R, LP-CC, FNQ-R Class CC fuses. *-EE, -JJ, -FF and -RR versions are UL Recognized for applications requiring branch circuit protection. 1 No CSA Certification 2 20A max when used with quick-connect terminals. 3 HPS rated at 250V for CSA 13 Specifications Description: Standard fuse holders with bayonet-type knob for 13⁄32" x 11⁄2" fuses. Dimensions: See Dimensions illustrations. Agency Information: CE, UL Recognized, (Guide IZLT2, File E14853). Flammability Rating: UL 94V0 - fuse holder body UL 94HB - Knob. Catalog Numbers Catalog Amp Numbers Ratings Volts Fuse Description 13 HPG* 301 600 ⁄32" x 1 1⁄2" fuses HPG-EE* 15 600 SC 0-15, 13⁄32" x 1 5⁄16" fuses. 13 HPD** 301 600 ⁄32" x 1 1⁄2" fuses 1 20A max when used with quick-connect terminals. *HPG and HPG-EE has combination 1⁄4" quick-connect/solder terminals on both side (load) and rear (line) terminals. **HPD has combination 1⁄4" quick-connect/solder terminal on side (load) terminal only. Rear (line) terminal is 3⁄16" shorter than HPG. Rear terminal solder only. Dimensions - in (mm) HPG, HPG-EE 0.88" (22.2mm) 1.125" Dimensions - in (mm) (28.6mm) With Fuse 2.81" Max. (71.4mm) E USE FU With Fuse SE F 1.00" 1.31" 2.81" 1.78" HPD (71.4mm) (25.4mm) (33.3mm) (45.2mm) 0.88" FUS (22.2mm) 0.180" DIA. 1.125" (4.6mm) (28.6mm) 0.88" 1.78" (22.2mm) 0.250" ± 0.003" (6.35 ± .08mm) (Typ.2) (45.2mm) 2.69" Max. (68.3mm) Without Fuse 0.250" ± .003" (6.35 ± .08mm) (Typ.2) 0.180" (4.6mm) 1.125" (28.6mm) 0.80" (20.2mm) 2.41" (64.3mm) Without Fuse Data Sheet: 2114 286 Data Sheet: 2113 2.81" (71.4mm) Data Sheet: 2108 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Panel Mounted Fuse Holders for 13⁄32" x 1 1⁄2" Fuses HPM HPC-D HPS2 #10 wire max for solder connection Specifications Description: Standard fuse holder with screw-type knob for 13⁄32" x 11⁄2" fuses. Dimensions: See Dimensions illustration. Ratings: Volts: — 600Vac/dc Amps: — 30A1 1 20A max when used with quick-connect terminals. Catalog Numbers Catalog Numbers HPM HPM-D Description ⁄4" quick-connect/solder Splash-resistant knob 2 1 HPM-D has 1⁄4" quick-connect/solder terminal on rear (load) terminal only. The side (line) terminal is 1⁄4" quickconnect only. 2 1 20A max when used with quick-connect terminals. Agency Information: CE, UL Recognized, Guide IZLT2, File E14853. Flammability Rating: UL 94HB. Catalog Numbers Catalog Number HPC-D Description Mount in panels up to 1⁄4" thick. Replacement knob - BK/9987SA Dimensions Specifications Description: For fuse size 13⁄32" x 11⁄2", meeting UL 1598 requirement that both poles be removed simultaneously. Dimensions: See Dimensions illustration. Ratings: Volts: — 600V@30A Amps: — 0-30A 1 1 20A max when used with quick-connect terminals. Agency Information: UL 4248 recognized, (Guide IZLT2, File E14853), CSA certified: (Class 6225-01, File 47235). Flammability Rating: UL 94V0. Terminals: 1⁄4” quick-connect/solder. Catalog Numbers Catalog Numbers HPS2 BK/HPS2 Standard 10-in carton Bulk 100-in carton With Fuse 2.48" (63.1mm) Dimensions Dimensions 0.88" (22.2mm) With Fuse 2.73" (69.5mm) 1.775" 0.94" (45.1mm) (23.8mm) 0.180" 1.41" (4.6mm) (30.6mm) 1.120" (30.5mm) 2.594" (65.89mm) Without Fuse Mounting Hole Flange Rear of Panel Mounting Hole Flange Front of Panel 1.031" + 0.003" 0.250" ± 0.003" (6.35 ± 0.08mm) (26.2mm + 0.08mm) 0.187" + 0.002" (4.75mm + 0.05mm) Nut Torque: 30 lb-in. Replacement Knob: Catalog Number: BK/9789-Y2 (50 pieces) Data Sheet: 2112 1.312" + 0.003" (33.3mm + 0.08mm) Data Sheet: 2109 0.890" + 0.003" (22.6mm + 0.08mm) 1.312" + 0.003" (33.3mm + 0.08mm) Panel Mount Hole Dimensions Data Sheet: 2140 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 287 Fuse Holders & Blocks Agency Information: CE, UL Recognized, Guide IZLT2, File E14853; CSA Certified, Class 6225-01, File 47235. Flammability Rating: UL 94HB. Specifications Description: Fuse holder with screw-type knob for 13⁄32" x 11⁄2" fuses. Supplied with O-ring and panel gasket. Dimensions: See Dimensions illustration. Ratings: Volts: — 600Vac/dc Amps: — 30A1 Fuse Holders and Blocks Fuse Blocks for 1⁄4" x 1 1⁄4" Fuses Series 8000 Single-Pole Fuse Blocks Specifications Description: Bolt-in and snap-in mounting for 1⁄4" x 11⁄4" fuses. Construction: Blocks are molded flame retarded thermoplastic. Clips are spring-bronze. Ratings: Volts: — 300V Amps: — 25A (See Catalog Numbers table) Agency Information: CE, UL Recognized ; File E14853, Guide IZLT2, CSA Certified Class 6225-01, File 47235. Anti-Rotation Pin: Single-pole blocks may be ordered without the anti-rotational pin simply by adding an “X” to the number of poles (Example: BK/S-8000-1X). Carton Quantity: 10; shelf package: 100. Bulk Carton: Single-pole and 2-pole fuse blocks – 1,000; Multiple-pole fuse blocks – 3- to 8-pole: 200; 9- to 12-pole: 50. When ordering bulk quantities, prefix “BK/” to catalog number: (Example: BK/S-8001-1-SNP). Catalog Numbers Bolt-in Mounting Basic Catalog Numbers S-8001S-8002S-8101S-8102S-8201S-8202S-8203S-8301Snap-in Mounting Catalog Numbers S-8001-1-SNP S-8002-1-SNP S-8101-1-SNP S-8102-1-SNP S-8201-1-SNP S-8203-1-SNP Series 8000 8000 Terminal Solder 8100 8100 ⁄16" Quick Connect 1 ⁄4" Quick Connect Side Screw 3 8200 8200 8300 8300 Series 8000 8000 8100 8100 8200 8200 Terminal Solder ⁄16" Quick Connect 1 ⁄4" Quick Connect 3 Catalog Number Build-A-Code Angle 0° 40° 0° 40° 0° 40° — Angle 0° 40° 0° 40° 0° Side Agency Maximums UL 25A CSA 21A UL 20A CSA 13A UL 20A CSA 16A Poles (Suffix) 1 - 12 4405 - 0° Solder terminals with integral terminal and clip Dimensions - in (mm) 2.31" (58.7mm) 0.69" (17.5mm) 0.27" (6.7mm) 1.63" (41.3mm) 4406 - Side solder terminal 4574 - Spare fuse block Dimensions - in (mm) 1 - 12 1.63" (41.3mm) 0.69" UL 30A CSA 25A (17.5mm) Agency Maximums UL 25A CSA 21A UL 20A CSA 13A UL 20A CSA 16A Catalog Code BK/ S-8 0 Specifications Description: Single-pole fuse block for 1⁄4" x 11⁄4" (6.4 x 31.8mm) size fuses. Dimensions: See Dimensions illustrations. Construction: Bakelite base width 1⁄2" (12.7mm); springbronze, bright tin-lead plate clips. Ratings: Volts: — 250V Amps: — 30A Poles (Suffix) Available Available only in only in single single pole pole 00 -00 0.27" (6.7mm) 2499 - Dimensions - in (mm) Prefix for Bulk Packing Series 8000 Product Line Type Terminal “0”-Solder “1”-‹/¡§∑ Quick Connect “2” - ⁄/¢∑ Quick Connect “3” - Screw Terminal Angle “01” - straight (0º) “02”- 40º “03” - side* Number of Poles (1-12) Data Sheet: 2101 288 Side quick-connect Agency Information: UL Recognized, Guide IZLT2, File E14853 Terminals: 1⁄4" (6.4mm); 15A, 250V 1.63" 0.75" (41.3mm) (19.1mm) 0.27" 0.72" (6.7mm) (18.3mm) 0.5" (12.7mm) Note: Mounting screw hole diameter is 0.147" (3.7mm). Counterbore diameter, 0.636" (8.0mm). Max Mounting Screw No. 6. *Available only in single pole For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Fuse Blocks for 1⁄4" x 1" Fuses 3828 Series 4520 and 4393 Specifications Description: Fuse block for 1⁄4" x 1" (6.4 x 25.4mm) fuses with solder terminals. Dimensions: See Dimensions illustration. Ratings: Volts: — 250V Amps: — 30A Mounting: Mounting screw hole diameter is 0.147" (3.7mm), diameter. Max mounting screw No. 6. Specifications Description: Single-pole fuse block for 1⁄4" x 1" fuses. Dimensions: See Dimensions illustrations. Construction: Bakelite with 1⁄2" (12.7mm) width base. Spring-bronze, bright tin-lead plated clips. Ratings: Volts: — 250V Amps: — 30A Mounting: Mounting screw hole diameter is 0.147" (3.7mm), counterbore 0.636" (8.0mm) diameter. Max mounting screw No. 6. Catalog Numbers Poles 1 2 3 4 5 6 7 8 10 12 *Base Length - in (mm) ⁄2 (12.7) 1 1⁄8 (28.6) 1 3⁄4 (44.5) 2 3⁄8 (60.3) 3 (76.2) 3 5⁄8 (92.1) 4 1⁄4 (108.0) 4 7⁄8 (123.8) 6 1⁄8 (155.6) 7 3⁄8 (187.3) 1 *Small phenolic base, base width 1 3⁄8" (34.9mm) Catalog Numbers Catalog Numbers 4520 4393 Description Integral clip and straight solder terminals Spare fuse block Fuse Holders & Blocks Catalog Numbers 3828-1 3828-2 3828-3 3828-4 3828-5 3828-6 3828-7 3828-8 3828-10 3828-12 No. 4520 - Integral clip and straight solder terminals Dimensions - in (mm) Dimensions - in (mm) 1.88" (47.6mm) 1.94" (49.2mm) 0.63" .188" .598" (4.8mm) (15.9mm) (15.2mm) 0.19" 1.38" (4.8mm) (34.9mm) 1.38" (34.9mm) No. 4393 - Spare fuse block Dimensions - in (mm) 1.38" (34.9mm) 0.188" 0.598" (4.8mm) (15.2mm) For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 289 Fuse Holders and Blocks Blocks for 13⁄32" X 11⁄2" Fuses 3743 3835 Series 4421 and 4515 Specifications Specifications Description: Add-on fuse blocks for 13 ⁄32" X 1 1⁄2" (10.3 X 38.1mm) fuses. Single pole blocks lock into each other and can be added at any time. Each has a single end barrier. Dimensions: See Dimensions illustration. Ratings: Volts: — 600Vac/dc Amps: — 30A Agency Information: CE, UL Recognized Guide IZLT2, File E14853. Description: Multiple pole fuse blocks for 13⁄32" X 1 1⁄2" (10.3 X 38.1mm) fuses. Dimensions: See Dimensions illustration. Ratings: Volts: — 250Vac/dc Amps: — 30A Agency Information: CE Catalog Numbers Catalog Numbers 3835-1 3835-2 3835-3 3835-4 3835-5 3835-6 3835-7 3835-8 3835-9 3835-10 3835-12 Poles 1 2 3 4 5 6 7 8 9 10 12 Base* Width In (mm) 27 ⁄32 (21.4) 1 13⁄16 (46.0) 2 25⁄32 (70.6) 3 3⁄4 (95.2) 4 23⁄32 (119.9) 5 11⁄16 (144.5) 6 21⁄32 (169.0) 7 5⁄8 (193.7) 8 19⁄32 (218.8) 9 9⁄16 (242.9) 11 1⁄2 (292.1) *Base length: 2 3⁄4" (69.9mm) 0.84" 1.29" Specifications Description: Single pole fuse blocks for 13⁄32" X 1 1⁄2" (10.3 X 38.1mm) fuses. Dimensions: See Dimensions illustration. Ratings: Volts: — 250Vac/dc (or less) Amps: — 30A Agency Information: CE 2.5" (63.5mm) 0.897" 0.19" (22.78mm)(4.8mm) Dimensions 1.63" (41.3mm) 2.75" 0.500" (69.9mm) 4421—Solder Terminals 3742 2.56" 1.0" 1.125" 0.25" (25.4mm) (6.4mm) Base width 5⁄8" (15.9mm) 0.25" 2.56" (65.1mm) 3742—End Barrier Only 2.56" Note: Mounting screw hole diameter is 0.148" (3.7mm). Countersink, 0.313" (7.9mm). Max. mounting screw No. 6. 0.323" (65.1mm) (8.2mm) 0.897" 0.19" (22.78mm) (4.8mm) 0.25" 1.125" (6.4mm) (28.6mm) 0.78" (19.8mm) 4515—Screw Terminals 0.144" 1.34" (34.1mm) 3723—Block and end barrier marking strip. Length is 93⁄8" Base width 3⁄4" (19mm) Note: Mounting screw hole diameter is 0.147" (3.7mm). Countersink, 0.312" (7.9mm). Max. mounting screw No. 6. (23.8cm). Note: Mounting screw hole is 0.147" (3.7mm) dia. Counterbore, 0.636" (8mm) dia. Max. mounting screw No. 6. Data Sheet: 2104 290 For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa Fuse Holders and Blocks Rail Mount Fuse Blocks and Holders NDNF1-WH NDNLFD1-WH Specifications Specifications Description: Fuse holding rail mount terminal block. Circuit Jumper: JF1, 2 circuits Fuse Size: 13⁄32" X 11⁄2"* (KTK, FNQ). Poles: 1 Wire Range: AWG #8-22 Cu. Ratings: Volts: — 600V Amps: — 30A Mounting Options: 35mm DIN rail, C-rail Fuse Pullers: • PF1 (standard) • neon or incandescent bulb Description: Rail mount fuse holder. Circuit Jumper: JF1, 2 circuits. Fuse Size: 1⁄4" X 11⁄4" (Cooper Bussmann AGC, MDL or equivalent). Poles: 1 Wire Range: AWG #8-22 Cu. Ratings: Volts: — 600V Amps: — 30A (NDND1 non-fused) — 15A (NDNFD1, 600V/CSA, fused) — 15A (NDNLFD1*fused, indicating) *LPF1 (lighted neon or incandescent bulb). Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: CSA File 15364 Catalog Numbers Catalog Color White Agency Information: CE, UL E62622; CSA LR15364. Mounting Options: 35mm DIN rail, C-rail Marking Tape: MT12-1-2 Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: CSA File 15364 Catalog Numbers Fuse Pullers (Optional): PF1 Lighted neon or incandescent lamp: Catalog Number Color Indicator Catalog NDNFD1-WH White NO NDNLFD1-WH White 90Vdc-600Vdc 115Vac-600Vac NDNLFD1-WH 24 White 24V Numbers Voltage LPF1-24 24 LPF1-120 120 LPF1-120-C 120 LPF1-220 220 LPF1-440 440 Fuse Holders & Blocks Number NDNF1-WH *WH24 - 24V White, WH-90Vdc-600Vdc, 115Vac-600Vac White For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa 291 292
CHM1DU 价格&库存
很抱歉,暂时无法提供与“CHM1DU”相匹配的价格&库存,您可以联系我们找货
