Technical Data 2131
Effective February 2023
Supersedes June 2022
1AXXXX
PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses
and ATC/ATM blade fuses
Product features
Fuse clips for 1/4”, 5.0 mm and 13/32” (10 mm)
diameter fuses
Fuse clips for ATM/ATC fuses
Variety of sizes, options, and materials
1AXXXX
PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses and ATC/ATM blade fuses
Technical Data 2131
Clips for 1/4” diameter fuses- inches
1A1119 (End stops, angled-in leads)
Part number
Clip material
Clip finish
BK-1A1119-04-R
Copper clad steel
Bright tin
BK-1A1119-05
Copper clad steel
Silver
BK-1A1119-10-R
Cartridge brass
Bright tin
.187
Parts packaged 1000 parts in a bag
.312
.130
.226
.272 FYI.
4X R .025 FYI.
STAMP "BUSS"
.063 LETTERS
(BOTH SIDES)
.007
R .120 ±.015
2X .062
R.213
A
BUSS
.177 .400 ±.010
2X R .035
.250
.162
2X R .030
CL
.174 ±.025
2X .080
.320
BURR DIRECTION
CL
.290 ±.010
4
4X .015 X 45
CHAMFER (TRUE)
4X .030
.220 FLAT
.150
2X .155 ±.010
+.005
- .020
.363 ±.003
8X R .015
4X .003
4X .022
MAX.
2X .020
3
MATERIAL CODE
STAMP .063 NUMBER
(EXAMPLE SHOWN)
4X .050±.010
2X .054
4X .040
4X CARRIER
TABS
4X .050 ±.010
VIEW A
1A1120 (Without end stops, angled-in leads)
Part number
Clip material
Clip finish
BK-1A1120-05
Copper clad steel
Silver
BK-1A1120-06-R
Copper clad steel
Bright tin
BK-1A1120-09-R
Cartridge brass
Bright tin
.187
.312
.130 ±.003
.272 FYI.
2X .007
4X R .025 FYI.
R .120 ±.015
STAMP "BUSS"
.063 LETTERS
(BOTH SIDES)
.226
A
CL
.174 ±.025
+.005
- .020
4X .030
.162
2X .155 ±.010
2X .080
.220 FLAT
FLAT WITHIN .005
IN .220 AREA
.150
.290 ±.010
.363 ±.003
8X R .015
MATERIAL CODE
STAMP .063 NUMBER
(EXAMPLE SHOWN)
4X .040
3
4X .022 MAX.
4X .003
2X .020
2X .054
4X CARRIER TABS
4X .050 ±.010
4X .050 ±.010
VIEW A
2
www.eaton.com/electronics
+.010
- .025
BUSS
2X R .035
2X R .030
.320
.400 ±.010
.177
.250
+.010
- .025
.130 ±.025
CL
FLAT WITHIN .005
IN .220 AREA
1AXXXX
Technical Data 2131
1A1907 (End stops, straight leads)
Part number
Clip material
Clip finish
BK-1A1907-02-R
Cartridge brass
Burnish
BK-1A1907-03-R
High performance copper
Bright tin
BK-1A1907-05
High perfomance copper
Silver
BK-1A1907-06-R
Cartridge brass
Bright tin
.155
UL recognized file E14853
.280
.102±.002
+.010
.226 - .025
.272 FYI.
2X .007
STAMP "BUSS"
.064 LETTERS
(BOTH SIDES)
R.120±.015
R.213
.177
.130±.025
2X .030
A
BUSS
.400±.010
.250
2X R.028
.220 FLAT
.162
2X R.030
CL
.174±.025
BURR
DIRECTION
.140
2X .140
2X FULL R.
CL
.280
FLAT WITHIN .005
IN .220 AREA
+.004
2X .060 - .002
+.005
.320 - .020
4X .040
4X .003
4X R.020
4X .022 MAX.
3
4X .050±.010
4X .050±.010
VIEW A
4X CARRIER TABS
1A3398 (Without end stops, straight leads)
Part number
Clip material
Clip finish
BK-1A3398-07-R
Cartridge brass
Bright tin
.155
.280
.102 ±.002
SEE NOTE 1
.272 FYI.
2X .007
.226
4X R.025 FYI.
.174 ±.025
R .120 ±.003
.177
+.010
- .025
A
.400 ±.010
A
.250
.140
2X R .030
2X .060
.320
CL
+.004
- .002
+.005
- .020
4X .041
MATERIAL CODE
STAMP .063 NUMBER
(EXAMPLE SHOWN)
CL
2X FULL R. (TRUE)
4X R .020
3
4X .003
.161
4X CARRIER
TABS
4X .050±.010
4X 0.022 MAX
4X .050±.010
SECTION A-A
3
1AXXXX
Technical Data 2131
1A4534 (End stops, angled-out leads)
Part number
Clip material
Clip finish
BK-1A4534-01-R
Copper clad steel
Bright tin
BK-1A4534-06-R
Cartridge brass
Bright tin
.155
.280
.102 ±.002
.226
.272 FYI.
2X .007
4X R.025 FYI.
R .120 ±.015
(R.213)
A
BUSS
.400 ±.010
.177
.130 ±.025
2X .030
STAMP "BUSS"
.063 LETTERS
(BOTH SIDES)
.250
A
2X R .028
.150
2X R .030
.162
2X R .020
CL
.174 ±.025
2X .079
"A"
2X FULL R. (TRUE)
CL
FLAT WITHIN .003
CONCAVE MAX.
"B"
+.005
.320 - .020
DIMENSION
+.004
.060 - .002
4X .041
"A"
.226+0.02/-0.008
"B"
.321+0.02/-0.008
4X R .020
3
4X .003
+.010
- .025
.310
4X .022 MAX.
4X .050±.010
4X CARRIER TAB
4X .050±.010
SECTION A-A
SCALE 4 : 1
1A4533 (Without end stops, angled-out leads)
Part number
Clip material
Clip finish
BK-1A4533-01-R
Copper clad steel
Bright tin
BK-1A4533-06-R
Cartridge brass
Bright tin
.155
.280
.102 ±.002
.272 FYI.
2X .007
.174 ±.025
4X R.025 FYI.
R .120 ±.003
.177
.400 ±.010
.250
.226
.310
STAMP "BUSS"
.063 LETTERS
(BOTH SIDES)
A
BUSS
A
2X R .028
.150
2X R .030
CL
+.004
- .002
+.005
.320
- .020
2X .060
4X .041
2X R .020
"A"
2X FULL R. (TRUE)
4X R .020
2X .079
"B"
DIMENSION
"A"
.226+0.02/-0.008
"B"
.321+0.02/-0.008
4X CARRIER
TABS
4X .050±.010
4X .022 MAX
4X .050±.010
SECTION A-A
4
.220 FLAT
CL
3
4X .003
.161
+.010
- .025
FLAT WITHIN .003
IN .220 AREA
1AXXXX
Technical Data 2131
Clips for 5 mm diameter fuses- inches
1A5601
Part number
Clip material
Clip finish
Current rating
BK-1A5601
Brass
Bright tin
7A
BK-1A5601-01
Phosphor bronze
Bright tin
10 A
1A5601
1A5601-01
1A5602
Part number
Clip material
Clip finish
BK-1A5602
Brass
Bright tin
. 2 1 9 ±. 0 2 0
. 158
. 2 5 0 ±. 0 1 0
. 5 0 0 ±. 0 1 0
2X . 062
. 093
2 X . 1 4 0 ±. 0 1 0
2X R . 016
2X . 047
SEE NOTE 8
. 216
5
Technical Data 2131
1AXXXX
1A3399 (With straight leads)
Part number
Clip material
Clip finish
BK-1A3399-01
Silver
BK-1A3399-04-R
Bright tin
BK-1A3399-10-R
Bright tin
1A5018 (With straight leads)
Part number
Clip material
Clip finish
BK-1A5018-07
Silver
BK-1A5018-10-R
Bright tin
6
1AXXXX
Technical Data 2131
Clips for 13/32” 10 mm diameter fuses- mm
1A3400 (with end stops, straight leads)
Part number
Clip material
Clip finish
BK-1A3400-09-R
Brass
Bright tin
BK-1A3400-17-R
BeCu
Bright tin
BK-1A3400-12-R
Brass
Bright tin
1A3400-09-R/1A3400-17-R
1A3400-12
7
1AXXXX
Technical Data 2131
Clips for ATC/ATM fuses
1A5778 (ATM fuse, mm/inches)
1A5600 (ATC fuse, inches/mm)
Part number
Clip material
Clip finish
BK-1A5778
Brass
Nickel
Part number
Clip material
Clip finish
BK-1A5600
Cartridge brass
Matte tin
Parts packaged 1000 parts per carton
.295"
(7.49mm)
.330"
(8.38mm)
.053"
(1.35mm)
3.96
.156
1.90
.075
.150"
(3.81mm)
.200"
(5.08mm)
0.08"± 0.01"
(2.03 ±0.25 mm)
0.09"
(2.29mm)
4.98
.196
11.18
.440
1.57
.062
3.18
.125
1.57
.062
3.66
.144
3.66
.144
2.18
.086
4.47
.176
1.65 ± 0.05
0.065 ± 0.002
(TYP-4)
3.66
.144
DIA. HOLE
MOUNTING LAYOUT FOR 2 CLIPS
8
1AXXXX
Technical Data 2131
Recommended pad layout --inches (mm)
B
A
B
C
A Dimension
Part number
Fuse length
7/8”
(22.2)
1”
(25.4)
1-1/4”
(31.8)
B
C
Tabs
4 holes
1A3398-
1.00”
(25.4)
1.125”
(28.58)
1.375”
(34.93)
0.295”-0.305”
(7.49-7.75)
0.067”-.070”
(1.70-1.78)
0.093”
(2.36)
1A1907-
1.00”
(25.40)
1.125”
(28.58)
1.375
(34.93)
0.295”-0.305”
(7.49-7.75)
0.067”-0.070”
(1.70-1.78)
0.093”
(2.36)
1A1119-
1.00”
(25.4)
1.125”
(28.58)
1.375”
(34.93)
0.295”-0.305”
(7.49-7.75)
0.093”±0.002
(2.36±0.05)
0.062” to 0.125”
(1.57 to 3.18)
1A1120-
1.00”
(25.4)
1.125”
(28.58)
1.375”
(34.93)
0.295”-0.305”
(7.49-7.75)
0.093”±0.002
(2.36±0.05)
0.062” to 0.125”
(1.57 to 3.18)
0.200”
(5.08)
0.067”-.070”
(1.70-1.78)
0.093”
(2.36)
0.405”
(10.29)
0.091”-.095”
(2.31-2.41)-
0.125”
(3.175)
1-3/8”
(34.93)
1-1/2”
(38.1)
(20)
0.875”
(22.23)
1A33991.50”
(38.1)
1A3400-
1.625”
(41.28)
Board thickness
1A4533-
1.00”
(25.4)
1.125”
(28.58)
1.375”
(34.93)
0.300”
(7.62)
0.067”-.070”
(1.70-1.78)
0.062”
(15.75)
1A4534-
1.00”
(25.4)
1.125”
(28.58)
1.375”
(34.93)
0.300”
(7.62)
0.067”-.070”
(1.70-1.78)
0.062”
(15.75)
0.180”
(4.57)
0.053”-.002”
(1.35 -0.05)
0.093”
(2.36)
"0.200”
(5.08)"
"0.062”±0.003” 0.125”max.
(1.57±0.077)" (3.18)
0.820”
(20.83)
1A50181A56001A5601-
0.820”±0.015” 0.266”
0.067”±0.003”
"0.220”
(5.588)"
1A5602-
0.062”
0.125”max.
(3.175)
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2023 Eaton
All Rights Reserved
Printed in USA
Publication No. 2131
February 2023
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BK/1A3398-07-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.459061+0.44743
- 5+2.856925+0.36955
- 10+2.6434010+0.34193
- 50+2.1892450+0.28318
- 100+2.01917100+0.26118
- 250+1.81596250+0.23490
- 500+1.67512500+0.21668
- 1000+1.545031000+0.19985
- 5000+1.278575000+0.16539
