Fuse Holders and Blocks
Rail Mount Fuse Blocks and Holders
NDNF1-WH
NDNLFD1-WH
Specifications
Specifications
Description: Fuse holding rail
mount terminal block.
Circuit Jumper: JF1,
2 circuits
Fuse Size: 13⁄32" X 11⁄2"*
(KTK, FNQ).
Poles: 1
Wire Range: AWG #8-22 Cu.
Ratings:
Volts: — 600V
Amps: — 30A
Mounting Options: 35mm DIN rail, C-rail
Fuse Pullers: • PF1 (standard)
• neon or incandescent bulb
Description: Rail mount
fuse holder.
2 circuits.
Fuse Size: 1⁄4" X 11⁄4"
(Cooper Bussmann AGC,
MDL or equivalent).
Poles: 1
Ratings:
Volts: — 600V
Amps: — 30A (NDND1 non-fused)
— 15A (NDNFD1, 600V/CSA, fused)
— 15A (NDNLFD1*fused, indicating)
*LPF1 (lighted neon or incandescent bulb).
Torque Rating: 18 lb-in
Operating Temperature: 105°C
Agency Information: CSA File 15364
Catalog Numbers
Catalog
Color
White
Agency Information: CE, UL E62622; CSA LR15364.
Marking Tape: MT12-1-2
Catalog Numbers
Fuse Pullers (Optional): PF1
Lighted neon or incandescent lamp:
Catalog
Number
Color
Indicator
Catalog
NDNFD1-WH
White
NO
NDNLFD1-WH
White
90Vdc-600Vdc
115Vac-600Vac
NDNLFD1-WH 24
White
24V
Numbers
Voltage
LPF1-24
24
LPF1-120
120
LPF1-120-C
120
LPF1-220
220
LPF1-440
440
Fuse
Holders
& Blocks
Number
NDNF1-WH
*WH24 - 24V White, WH-90Vdc-600Vdc, 115Vac-600Vac White
For product data sheets, visit www.cooperbussmann.com/datasheets/ulcsa
291
很抱歉,暂时无法提供与“NDNF1-WH”相匹配的价格&库存,您可以联系我们找货
