BK/S-8202-3-R
BK/S-8202-3-R
    EATON(伊顿)
    BK/S-8202-3-R
BK/S-8202-3-R 数据手册
Technical Data 2101 Effective March 2021 Supersedes June 2017 S-8000 1/4” x 1-1/4” Fuse blocks Ordering part number Bolt-in mounting BK-S-8 1 02-6 -R Packaging prefix Family name Product features Terminal type: • For 1/4” x 1-1/4” (6 x 32 mm) fuses • High voltage rating (Up to 600 V) • Bolt-in, snap-in and DIN-rail mounting available Number of poles: • Compact, tight cluster mounting RoHS compliant • Multiple types of terminal options • Clips are made of bright tin-plated, spring bronze • Anti-rotational pin available • Thermoplastic base meets UL94 V-0 Terminal angle: Snap-in and DIN-rail mounting BK-S-8 0 01-1 SNP-R Packaging prefix Agency information Family name • UL Recognized: E14853 Terminal type: • CSA Certified: 47235 Terminal angle: Number of poles: Mounting style: RoHS compliant Environmental compliance General specifications • Relative Temperature Index (RTI) • Bolt-in +130 °C • Snap-in +110 °C Packaging prefix • Blank- (Qty varies with number of poles) • BK- (QTY varies with number of poles) Terminal type: 0= solder 1= 3/16” quick connect 2= 1/4” quick connect 3= screw Terminal angle: 01= straight 02= 40° angle 03= side* Number of poles: (1 - 12) 1X= One pole, No mounting stud Mounting style: SNP**= Snap-in mounting* DIN**= DIN-rail mounting *Available only in single pole and 3/16” or 1/4” quick connect terminals ** Available in single pole only S-8000 1/4” x 1-1/4” Fuse blocks  Technical Data 2101 Effective March 2021 Specifications Family UL voltage rating (V) UL current rating (A) CSA voltage rating (V) CSA current rating (A) S-8000 600 30 300 21 S-8100 600 20 300 13 S-8200 600 30 300 16 S-8300 600 30 300 25 Dimensions- mm/inches S-8000 Single pole bolt-in mounting S-8000 Single pole snap-in mounting 40° Angle terminal 40° Angle terminal Straight terminal Straight terminal Side terminal Screw terminal Mounting Side terminal Mounting Multiple pole Mounting dimensions ple pole 2 www.eaton.com/electronics Number of poles A (inches) B (inches) A (mm) B (mm) 1 - - - - 2 1 1/8” 5/8” 28.6 15.9 3 1 3/4” 1 1/4” 44.4 31.8 4 2 3/8” 1 7/8” 60.3 47.6 5 3” 2 1/2” 76.2 63.5 6 3 5/8” 3 1/8” 92.1 79.4 7 4 1/4” 3 3/4” 108 95.2 8 4 7/8” 4 3/8” 123.8 111.1 9 5 1/2” 5” 139.7 127 10 6 1/8” 5 5/8” 155.6 142.9 11 6 3/4” 6 1/4” 171.4 158.8 12 7 3/8” 6 7/8” 187.3 174.6 S-8000 1/4” x 1-1/4” Fuse blocks  Technical Data 2101 Effective March 2021  DIN-rail mounting B A C Part number A (inches) B (inches) C (inches) A (mm) B (mm) C (mm) BK-S-8002-1X-DIN 2 0.5 1.31 50.8 12.7 33.3 BK-S-8102-1X-DIN 2 0.5 1.31 50.8 12.7 33.7 BK-S-8202-1X-DIN 2 0.5 1.31 50.8 12.7 33.3 BK-S-8301-1X-DIN 2.189 0.5 1.31 55.6 12.7 33.3 BK-S-8103-1X-DIN 1.693 0.953 1.31 43 24.2 33.3 BK-S-8203-1X-DIN 1.693 0.953 1.31 43 24.2 33.3 Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2021 Eaton All Rights Reserved Printed in USA Publication No. 2101 March 2021 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
BK/S-8202-3-R 价格&库存
很抱歉,暂时无法提供与“BK/S-8202-3-R”相匹配的价格&库存,您可以联系我们找货
BK/S-8202-3-R
  • 75+94.39446
  • 150+88.77214
  • 300+79.29280
  • 4800+40.98850
库存:1785
