Bussmann®
Panel-Mount Fuseholder
HPG and HPD
Dimensional Data
With Fuse
2.81" Max.
HPG
HPG-EE
(71.4mm)
0.88"
F
E
SE
USE
FU
(22.2mm)
FU S
Catalog Symbol: HPG and HPD
Panel-Mount
Agency Information: UL Recognized, Guide IZLT2,
File E14853
Flammability Rating: UL 94VO-Fuseholder Body
UL94HB-Knob
General Information:
• Bayonet-type knob.
• For supplementary protection of transformers, relays,
ballasts and small motors.
• Mount in ⁄Ω™∑ (12.7mm) knock-outs with locknut.
• Do not put tension on line (ear) terminal.
.250" ± .003"
(6.35 ± .08mm)
(Typ. 2)
1.125"
(28.6mm)
HPD
Punched Mounting Hole
Electrical Ratings
Catalog
Symbol
HPG
HPG-EE
Amps
30(3)
15
30(3)
Volts
AC
600
600
.880" + .005"
(22.4mm + .13mm)
Fuse Description
⁄‹Ω£™∑ x 1⁄Ω™∑ (10.3 x 38.1mm)
SC 0-15, ⁄‹Ω£™∑ ≈ 1fiΩ¡§∑ fuses.
.815" + .005"
(20.7mm + .13mm)
HPD
600
(3)20A max when used with quick connect terminals
Maximum panel thickness, mounting flange in front of panel
NOTE:
• HPG and HPG-EE has combination ⁄Ω¢∑ quick-connect/solder
terminals on both side (load) and rear (line) terminals.
• HPD has combination ⁄Ω¢∑ quick-connect/solder terminal on side
(load) terminal only. Rear (line) terminal is 3/16∑ shorter than
HPG. Rear terminal solder only.
Assumes Pollution Degree 3 per UL 840:
Conductive pollution, or dry, nonconductive pollution that
becomes conductive due to condensation that is expected.
Maximum panel thickness not including any sealing gaskets.
System Voltage
600V
480
277
240
120
Fuseholder
HPG
mm Inches mm Inches mm Inches mm Inches mm Inches
0.84 1/32” 1.73 1/16” 6.00 7/32” 6.55 1/4” 8.03 5/8”
HPD
8.03 5/8”
Thicker panels may be used if fuse holder load terminal is fully insulated, using a
UL recognized (VW-1) insulative heat-shrink tubing, or if anticipated environment
is of Pollution Degree 1 or 2, or if panel is nonconductive.
CE logo denotes compliance with European Union Low Voltage Directive
(50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann
Application Engineering at 636-527-1270 for more information.
Pollution Degree 2- Normally, only nonconductive pollution. However, a temporary
conductivity caused by condensation may be expected.
Pollution Degree 1- No pollution or only dry, nonconductive pollution.
The pollution has no influence.
Maximum panel thickness, mounting flange behind the panel:
5.08mm/0.200” (flush to knob collar)
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is
intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change
design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
6-3-04
SB04184
Form No. HPG
Page 1 of 1
Data Sheet: 2108
很抱歉,暂时无法提供与“BK/HPG”相匹配的价格&库存,您可以联系我们找货
