BK/HHC-R
BK/HHC-R
    EATON(伊顿)
    BK/HHC-R
BK/HHC-R 数据手册
Technical Data 10443 Effective September 2015 HHF-JFCU Automotive in-line fuse holder for ATC blade-type fuses Product specifications Part Number Description Fuse size Voltage rating HHF-JFCU Black fuseholder with cover 3-20A 32Vdc Electrical connection 16 Gauge yellow leadwire Maximum continuous current rating 20A Body material Body contact material Santoprene TPV Brass/Tin plated A fuse must be properly and fully inserted into the holder to provide a solid connection. Poor or improper insertion of the fuse can result in failure of the fuse and holder, thus not protecting the device for which it was intended. Dimensions–mm 11.0±0.5 Envionmental data Normal operating temperature: +25°C ±2°C Storage temperature: -10°C to +40°C 20.0±0.5 CAVITY NO. “BUSS” MARK Packaging Bulk: (500 parts per box) 17.2±0.5 6.35±2.0 6.35±2.0 101.6±5.0 32.0±1.0 101.6±5.0 Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/elx © 2015 Eaton All Rights Reserved Printed in USA Publication No. 10443 BU-MC15015 September 2015 Eaton is a registered trademark. All other trademarks are property of their respective owners.
BK/HHC-R 价格&库存
很抱歉,暂时无法提供与“BK/HHC-R”相匹配的价格&库存,您可以联系我们找货
