BK/HLR
BK/HLR
    EATON(伊顿)
    FUSE HLDR CART 300V 12A PNL MNT
BK/HLR 数据手册
Bussmann® Specialty Fuse GLR & HLR Fast-Acting, Non-Rejecting Dimensional Data FUSE 0.63" (15.9mm) FUSE AND CARRIER HLR GLR-⁄Ω™ HLR GLR-6 HLR GLR-1 HLR GLR-7 HLR GLR-1⁄Ω™ HLR GLR-8 HLR GLR-1flΩ¡º HLR GLR-9 HLR GLR-2 HLR GLR-10 HLR GLR-3 HLR GLR-12 HLR GLR-4 HLR GLR-15 HLR-2A General Information: • HLR carrier comes with 6∑ of #18 red insulated solid copper wire attached to the line side. • Customer inserts a #18 insulated solid copper wire into load side receptacle. • Order part number HLR-2A to obtain 6∑ of #18 black insulated solid copper wire pre-installed in a load side receptacle. • Order part number HLR-2L to obtain 6∑ of #18 black insulated solid copper wire packaged loose (un-installed). • An alternative to the HLR fuseholder is the A fuseholder. The A fuseholder comes WITHOUT leads. The customer inserts #18 insulated solid copper wire into the line side receptacle as well as into the load side receptacle. It has the same body dimensions, utilizes the same mounting hole, and takes the same mounting clips as the HLR. The A fuseholder is UL Recognized, 10A, 300Vac, Guide IZLT2, File E14853 and CSA Certified, 10A, 300Vac, Class 6225-01, File 47235. • Fuse and knob are an integral one-piece unit. There are no replacement knobs (caps). • Units can be panel mounted with a separate steel clip. For the knockout hole (see above), choose #BK/A-104. For the keyhole punch type hole, choose #6374 for panels .043” to .062” thick, or #4909 for panels .030” to .042” thick. • Do not put tension on line (rear) terminal of fuse-holder. 5-22-02 SB02233 .635'' 16.13mm .740'' 18.80mm .410'' 10.41mm Knockout Hole Keyhole Punch 15 7 10 5 100 2 1 1.5 Time-Current Characteristic Curves–Average Melt AMPERE RATING 10 1 .1 .01 200 Carrier GLR-5 .255'' 6.48mm .870'' 22.10mm 100 Fuse HLR Load Lead MOUNTING HOLE 10 Carrier GLR-‹Ω¡§ C L 1 Fuse Line Lead .850'' 21.59mm TIME IN SECONDS Electrical Ratings for Type GLR Fuses and Non-Rejection Style Carriers 2.250'' 57.15mm .850'' 21.59mm .720'' 18.29mm .1 Catalog Symbol: GLR (Fuse) HLR (Fuseholder) Fast-Acting, Non-Rejection Style Fuse Ampere Rating: ‹Ω¡§-15 Amperes Voltage Rating: 300 Volts AC or less Interrupting Rating: 10,000 Amperes Agency Information: GLR Fuse: UL Listed, Std. 248-14 ‹Ω¡§-15A/300 Vac, Guide JDYX, File E19180 CSA Certified, C22.2 No. 248.14, 0-10A/300 Vac Class 1422-01, File 53787 HLR Fuseholder: UL Recognized, 12A, 300 Vac, Guide IZLT2, File E14853 CSA Certified, 12A, 300 Vac, Class 6225-01, File 47235 HLR-2A: UL Recognized, 15A, 300 Vac, Guide IZLT2, File E14853 CSA Certified, 15A, 300 Vac, Class 6225-01, File 47235 CURRENT IN AMPERES The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. CE logo denotes compliance with European Union Low Voltage Directive (50-1000 Vac, 75-1500 Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. Form No. GLR & HLR Page 1 of 1 Data Sheet: 2032
BK/HLR 价格&库存
很抱歉,暂时无法提供与“BK/HLR”相匹配的价格&库存,您可以联系我们找货
