15600-08-21
15600-08-21
    EATON(伊顿)
15600-08-21 数据手册
Bussmann® ATC® Blade-Type Fuse Panels 15600 SPECIFICATIONS Interchangeable Blade Terminals: Accepts ATC® blade-type fuses or circuit breakers. Wiring: Output terminals - .250" x .032" QC rated 30A max. per circuit; Input terminals - #10-32 stud input rated 150A max. Positions: Provides 4 to 20 output circuits. Material: Black, UL rated 94VO thermoplastic, –20°F to 150°F. Applications: Compact and lightweight, yet rugged enough for use in trucks, buses, boats, RV’s, etc. Other Features: No top cover needed; recessed trifurcated fuse contacts. Recessed mounting holes. Dimensions: 15600 Series 15602 Series .22" DIA. HOLE WITH .41 x .12 DEEP C'BORE (4X) "L" "L" "C" "C" 3.37" (85.59) 1.06" (26.92) 1.06" (26.92) 2.50" (63.50) .62" (15.75) .250" QC (COPPER ALLOY - TIN PLATED) Ground Terminal Base Option (12) .250" QC TERMINALS W/COMMON WIRING STUD, ADD 1.300" TO "L" FOR OVERALL LENGTH 1.22" (30.98) (15602-04/08-20 SHOWN) .62" TYP (15.75) .80" (20.32) (15600 -10-20 SHOWN) PART NUMBERING SYSTEM Series ❏❏❏❏ No. of Fuses &/or Circuit Breaker Positions 0 ❏ – ❏❏ Hardware Options Ground Terminal Base – ❏ ❏ – ❏ ❏ 0 – W/O nuts 1 – Nuts shipped bulk 2 – Nuts assembled 0 – None 1 – Include Ground Pad 04-20 1 5 6 0 2 ❏ 0 – Single Stud 2 – Double Stud – ❏❏/ ❏❏ Left Side Right Side 04-16 04-16 (Max. combination of 20) The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 12-16-98 SB98107 Rev. A Form No. 15600 Page 1 of 1 BIF Document: 2064
15600-08-21 价格&库存
很抱歉,暂时无法提供与“15600-08-21”相匹配的价格&库存,您可以联系我们找货
