BK/1A4534-01-R
BK/1A4534-01-R
    EATON(伊顿)
    FUSE-CLIP-2P_7.11X8.13MM_TM
    BK/1A4534-01-R
BK/1A4534-01-R 数据手册
Technical Data 2131 Effective February 2023 Supersedes June 2022 1AXXXX PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses and ATC/ATM blade fuses Product features • Fuse clips for 1/4”, 5.0 mm and 13/32” (10 mm) diameter fuses • Fuse clips for ATM/ATC fuses • Variety of sizes, options, and materials 1AXXXX PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses and ATC/ATM blade fuses  Technical Data 2131 Effective February 2023 Clips for 1/4” diameter fuses- inches 1A1119 (End stops, angled-in leads) Part number Clip material Clip finish BK-1A1119-04-R Copper clad steel Bright tin BK-1A1119-05 Copper clad steel Silver BK-1A1119-10-R Cartridge brass Bright tin .187 Parts packaged 1000 parts in a bag .312 .130 .226 .272 FYI. 4X R .025 FYI. STAMP "BUSS" .063 LETTERS (BOTH SIDES) .007 R .120 ±.015 2X .062 R.213 A BUSS .177 .400 ±.010 2X R .035 .250 .162 2X R .030 CL .174 ±.025 2X .080 .320 BURR DIRECTION CL .290 ±.010 4 4X .015 X 45 CHAMFER (TRUE) 4X .030 .220 FLAT .150 2X .155 ±.010 +.005 - .020 .363 ±.003 8X R .015 4X .003 4X .022 MAX. 2X .020 3 MATERIAL CODE STAMP .063 NUMBER (EXAMPLE SHOWN) 4X .050±.010 2X .054 4X .040 4X CARRIER TABS 4X .050 ±.010 VIEW A 1A1120 (Without end stops, angled-in leads) Part number Clip material Clip finish BK-1A1120-05 Copper clad steel Silver BK-1A1120-06-R Copper clad steel Bright tin BK-1A1120-09-R Cartridge brass Bright tin .187 Parts packaged 1000 parts in a bag .312 .130 ±.003 .272 FYI. 2X .007 4X R .025 FYI. R .120 ±.015 STAMP "BUSS" .063 LETTERS (BOTH SIDES) .226 A CL .174 ±.025 +.005 - .020 4X .030 .162 2X .155 ±.010 2X .080 .220 FLAT FLAT WITHIN .005 IN .220 AREA .150 .290 ±.010 .363 ±.003 8X R .015 MATERIAL CODE STAMP .063 NUMBER (EXAMPLE SHOWN) 4X .040 3 4X .022 MAX. 4X .003 2X .020 2X .054 4X CARRIER TABS 4X .050 ±.010 4X .050 ±.010 VIEW A 2 www.eaton.com/electronics +.010 - .025 BUSS 2X R .035 2X R .030 .320 .400 ±.010 .177 .250 +.010 - .025 .130 ±.025 CL FLAT WITHIN .005 IN .220 AREA 1AXXXX PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses and ATC/ATM blade fuses Technical Data 2131 Effective February 2023  Clips for 1/4” diameter fuses- inches 1A1907 (End stops, straight leads) Part number Clip material Clip finish BK-1A1907-02-R Cartridge brass Burnish BK-1A1907-03-R High performance copper Bright tin BK-1A1907-05 High perfomance copper Silver BK-1A1907-06-R Cartridge brass Bright tin .155 Parts packaged 1000 parts in a bag UL recognized file E14853 .280 .102±.002 +.010 .226 - .025 .272 FYI. 2X .007 STAMP "BUSS" .064 LETTERS (BOTH SIDES) R.120±.015 R.213 .177 .130±.025 2X .030 A BUSS .400±.010 .250 2X R.028 .220 FLAT .162 2X R.030 CL .174±.025 BURR DIRECTION .140 2X .140 2X FULL R. CL .280 FLAT WITHIN .005 IN .220 AREA +.004 2X .060 - .002 +.005 .320 - .020 4X .040 4X .003 4X R.020 4X .022 MAX. 3 4X .050±.010 4X .050±.010 VIEW A 4X CARRIER TABS 1A3398 (Without end stops, straight leads) Part number Clip material Clip finish BK-1A3398-07-R Cartridge brass Bright tin .155 Parts packaged 1000 parts in a bag .280 .102 ±.002 SEE NOTE 1 .272 FYI. 2X .007 .226 4X R.025 FYI. .174 ±.025 R .120 ±.003 .177 +.010 - .025 A .400 ±.010 A .250 .140 2X R .030 2X .060 .320 CL +.004 - .002 +.005 - .020 4X .041 MATERIAL CODE STAMP .063 NUMBER (EXAMPLE SHOWN) CL 2X FULL R. (TRUE) 4X R .020 3 4X .003 .161 4X CARRIER TABS 4X .050±.010 4X 0.022 MAX 4X .050±.010 SECTION A-A www.eaton.com/electronics 3 1AXXXX PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses and ATC/ATM blade fuses  Technical Data 2131 Effective February 2023 Clips for 1/4” diameter fuses- inches 1A4534 (End stops, angled-out leads) Part number Clip material Clip finish BK-1A4534-01-R Copper clad steel Bright tin BK-1A4534-06-R Cartridge brass Bright tin .155 Parts packaged 1000 parts in a bag .280 .102 ±.002 .226 .272 FYI. 2X .007 4X R.025 FYI. R .120 ±.015 (R.213) A BUSS .400 ±.010 .177 .130 ±.025 2X .030 STAMP "BUSS" .063 LETTERS (BOTH SIDES) .250 A 2X R .028 .150 2X R .030 .162 2X R .020 CL .174 ±.025 2X .079 "A" 2X FULL R. (TRUE) CL FLAT WITHIN .003 CONCAVE MAX. "B" +.005 .320 - .020 DIMENSION +.004 .060 - .002 4X .041 "A" .226+0.02/-0.008 "B" .321+0.02/-0.008 4X R .020 3 4X .003 +.010 - .025 .310 4X .022 MAX. 4X .050±.010 4X CARRIER TAB 4X .050±.010 SECTION A-A SCALE 4 : 1 1A4533 (Without end stops, angled-out leads) Part number Clip material Clip finish BK-1A4533-01-R Copper clad steel Bright tin BK-1A4533-06-R Cartridge brass Bright tin .155 Parts packaged 1000 parts in a bag .280 .102 ±.002 .272 FYI. 2X .007 .174 ±.025 4X R.025 FYI. R .120 ±.003 .177 .400 ±.010 .250 .226 .310 STAMP "BUSS" .063 LETTERS (BOTH SIDES) A BUSS A 2X R .028 .150 2X R .030 CL +.004 - .002 +.005 .320 - .020 2X .060 4X .041 2X R .020 "A" 2X FULL R. (TRUE) 4X R .020 2X .079 "B" DIMENSION "A" .226+0.02/-0.008 "B" .321+0.02/-0.008 4X CARRIER TABS 4X .050±.010 4X .022 MAX 4X .050±.010 SECTION A-A 4 www.eaton.com/electronics .220 FLAT CL 3 4X .003 .161 +.010 - .025 FLAT WITHIN .003 IN .220 AREA 1AXXXX PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses and ATC/ATM blade fuses Technical Data 2131 Effective February 2023  Clips for 5 mm diameter fuses- inches 1A5601 Part number Clip material Clip finish Current rating BK-1A5601 Brass Bright tin 7A BK-1A5601-01 Phosphor bronze Bright tin 10 A 1A5601 Parts packaged 1000 parts in a bag 1A5601-01 1A5602 Part number Clip material Clip finish BK-1A5602 Brass Bright tin . 2 1 9 ±. 0 2 0 Parts packaged 1000 parts in a bag . 158 . 2 5 0 ±. 0 1 0 . 5 0 0 ±. 0 1 0 2X . 062 . 093 2 X . 1 4 0 ±. 0 1 0 2X R . 016 2X . 047 SEE NOTE 8 . 216 www.eaton.com/electronics 5 Technical Data 2131 Effective February 2023 1AXXXX PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses and ATC/ATM blade fuses  Clips for 5 mm diameter fuses- inches 1A3399 (With straight leads) Part number Clip material Clip finish BK-1A3399-01 High performance copper Silver BK-1A3399-04-R High performance copper Bright tin BK-1A3399-10-R High performance copper Bright tin Parts packaged 1000 parts in a bag 1A5018 (With straight leads) Part number Clip material Clip finish BK-1A5018-07 High performance copper Silver BK-1A5018-10-R High performance copper Bright tin 6 www.eaton.com/electronics Parts packaged 1000 parts in a bag 1AXXXX PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses and ATC/ATM blade fuses Technical Data 2131 Effective February 2023  Clips for 13/32” 10 mm diameter fuses- mm 1A3400 (with end stops, straight leads) Part number Clip material Clip finish BK-1A3400-09-R Brass Bright tin BK-1A3400-17-R BeCu Bright tin BK-1A3400-12-R Brass Bright tin Parts packaged 1000 parts in a bag UL recognized file E14853 1A3400-09-R/1A3400-17-R 1A3400-12 www.eaton.com/electronics 7 1AXXXX PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses and ATC/ATM blade fuses  Technical Data 2131 Effective February 2023 Clips for ATC/ATM fuses 1A5778 (ATM fuse, mm/inches) 1A5600 (ATC fuse, inches/mm) Part number Clip material Clip finish BK-1A5778 Brass Nickel Part number Clip material Clip finish BK-1A5600 Cartridge brass Matte tin Parts packaged 1000 parts per carton Parts packaged 1000 parts per carton .295" (7.49mm) .330" (8.38mm) .053" (1.35mm) 3.96 .156 1.90 .075 .150" (3.81mm) .200" (5.08mm) 0.08"± 0.01" (2.03 ±0.25 mm) 0.09" (2.29mm) 4.98 .196 11.18 .440 1.57 .062 3.18 .125 1.57 .062 3.66 .144 3.66 .144 2.18 .086 4.47 .176 1.65 ± 0.05 0.065 ± 0.002 (TYP-4) 3.66 .144 DIA. HOLE MOUNTING LAYOUT FOR 2 CLIPS 8 www.eaton.com/electronics 1AXXXX PCB Fuse-clips for 1/4”, 5.0 mm, 13/32”diameter fuses and ATC/ATM blade fuses Technical Data 2131  Effective February 2023 Recommended pad layout --inches (mm) B A B C A Dimension Part number Fuse length 7/8” (22.2) 1” (25.4) 1-1/4” (31.8) B C Tabs 4 holes 1A3398- 1.00” (25.4) 1.125” (28.58) 1.375” (34.93) 0.295”-0.305” (7.49-7.75) 0.067”-.070” (1.70-1.78) 0.093” (2.36) 1A1907- 1.00” (25.40) 1.125” (28.58) 1.375 (34.93) 0.295”-0.305” (7.49-7.75) 0.067”-0.070” (1.70-1.78) 0.093” (2.36) 1A1119- 1.00” (25.4) 1.125” (28.58) 1.375” (34.93) 0.295”-0.305” (7.49-7.75) 0.093”±0.002 (2.36±0.05) 0.062” to 0.125” (1.57 to 3.18) 1A1120- 1.00” (25.4) 1.125” (28.58) 1.375” (34.93) 0.295”-0.305” (7.49-7.75) 0.093”±0.002 (2.36±0.05) 0.062” to 0.125” (1.57 to 3.18) 0.200” (5.08) 0.067”-.070” (1.70-1.78) 0.093” (2.36) 0.405” (10.29) 0.091”-.095” (2.31-2.41)- 0.125” (3.175) 1-3/8” (34.93) 1-1/2” (38.1) (20) 0.875” (22.23) 1A33991.50” (38.1) 1A3400- 1.625” (41.28) Board thickness 1A4533- 1.00” (25.4) 1.125” (28.58) 1.375” (34.93) 0.300” (7.62) 0.067”-.070” (1.70-1.78) 0.062” (15.75) 1A4534- 1.00” (25.4) 1.125” (28.58) 1.375” (34.93) 0.300” (7.62) 0.067”-.070” (1.70-1.78) 0.062” (15.75) 0.180” (4.57) 0.053”-.002” (1.35 -0.05) 0.093” (2.36) "0.200” (5.08)" "0.062”±0.003” 0.125”max. (1.57±0.077)" (3.18) 0.820” (20.83) 1A50181A56001A5601- 0.820”±0.015” 0.266” 0.067”±0.003” "0.220” (5.588)" 1A5602- 0.062” 0.125”max. (3.175) Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2023 Eaton All Rights Reserved Printed in USA Publication No. 2131 February 2023 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
BK/1A4534-01-R 价格&库存
很抱歉,暂时无法提供与“BK/1A4534-01-R”相匹配的价格&库存,您可以联系我们找货
BK/1A4534-01-R
  • 200+5.71905
  • 400+5.62232
  • 800+5.53768
  • 1000+5.35632
  • 10000+4.54622
库存:101000
BK/1A4534-01-R
  • 1+16.821691+2.17014
  • 5+13.981035+1.80367
  • 10+12.8973410+1.66387
  • 50+10.7011250+1.38054
  • 100+9.87297100+1.27370
  • 250+8.87301250+1.14469
  • 500+8.18086500+1.05540
  • 1000+7.539441000+0.97265
  • 5000+6.223815000+0.80293
库存:1152
