Fuse Holders
Protect Fuses
from Extreme
Conditions
Gasket-sealed, In-line
Fuse Holders Seal out
Contaminants, Seal in
the Power
Superior Seal
Tough cover locks tightly to fuse holder, silicone rubber gasket
provides excellent seal
Water and Solvent Resistant
Black nylon housing and PVC insulated leads are highly resistant
to attack from water, common solvents and harsh environments
Wide Range of Applications and Demand
Ideal for SUV, ATV, trailer and marine applications where water
and contamination of fuse holders are a problem
Handle up to 30 Amps
Five-inch, 12-gauge copper leads come fully assembled, ready
for splicing into circuits
Easy, Secure Mounting
Single, built-in mounting hole provides quick and secure installation
Broad Market Coverage with Just Two Holders
New HHU ATM® fuse holder complements the existing HHR ATC®
holder for broad and popular blade-type fuse coverage
Gasket-Sealed Inline
Blade Fuse Holders
New HHU for ATM® Blade Fuses
Specifications
Volts: Up to 32Vdc
Cap & Housing: Nylon
Gasket: Silicone Rubber
Lead Wires: (2) 12-gauge;
5", silicone coated and
PVC insulated
Unit
Amps: Up to 30A
Flammability Rating: UL 94V2
Terminals: Tin-plated brass
Available in blister or
boxed packaging
HHU In-line ATM®
Fuse Holder
Shelf Carton
HHR In-line ATC®
Fuse Holder
Master Carton
Qty
Unit
Weight
Bar Code
Qty
Wgt
Cubic
Inches
Bar Code
Qty
Cubic
Inches
Wgt
051712 505758
1
0.05
30051712505759
10
0.5
35.25
70051712505757
320
1401.45
17
12
4
BP/HHU 051712 629904
1
0.06
30051712629905
5
0.35
108.74
70051712629903
120
3007.64
8.2
6
3
Part#
HHU
UPC Code
Tie High
Cooper Bussmann provides a full line of blade-style fuse holders
Standard
Pack
Retail
Pack
Max
Amps
Gauge
Lead
Color
Lead
Length
Description
ATC® Style
HHC
BP/HHC
black
3.5" each
Does not include cover
HHD
BP/HHD
30
12
yellow
3.5" each
HHD-C
Cover for HHC and HHD fuse holders
HHD-12
Display contains 12 HHD fuse holders
HHF
BP/HHD-30
30
12
yellow
3.5" each
Same as HHD; also includes ATC-30 fuse
BP/HHF
yellow
3.5" each
Splash resistant protective cover
HHG
BP/HHG
30
12
yellow
3.5" each
HHR
BP/HHR
orange
4" each
BP/HHS
BP/HHA
10
not included
Locking, sealed-gasket water-resistant cover with mounting hole
Self-stripping: use #18 to #14 AWG copper wire only (not included)
Add-a-line converts to 2 circuits; plugs into fuseblock
ATM® Style
HHL
BP/HHL
black
3.5" each
HHM
BP/HHM
30
12
red
3.5” each
30
12
red
3.5” each
HHM-B
HHM-C
NEW
HHU
Cover only - Fits HHM and HHL fuseholders
BP/HHU
30
BP/HHH
10
12
4” each
MAX Style
HHX
60
6
HHX-B
60
6
HHX-C
60
red
5” each
Body only; does not include lead wires
Cover only - Fits HHX fuseholder
©2006 Cooper Bussmann • St. Louis, MO 63178
www.cooperbussmann.com
Printed in USA
Reorder # 5084C 10-06-5M
很抱歉,暂时无法提供与“HHR”相匹配的价格&库存,您可以联系我们找货
