4164-FR
4164-FR
    EATON(伊顿)
    4164-FR
4164-FR 数据手册
Technical Data 2024 Effective December 2015 Supersedes August 2004 BUSSMANN SERIES ANL non-time-delay low voltage limiter Catalog numbers (amps) ANL-35 ANL-150 ANL-40 ANL-175 ANL-50 ANL-200 ANL-60 ANL-225 ANL-80 ANL-250 ANL-100 ANL-275 ANL-125 ANL-300 ANL-130 ANL-325 ANL-350 ANL-400 ANL-500 ANL-600 ANL-675 ANL-750 Dimensions - in (mm): 0.88" (±0.005) (22.2mm) Catalog symbol: • 0.34" ANL-(amp) (8.7mm) Description: 2.44" 3.19" (±0.015) (61.0mm) Non-time-delay low voltage limiter for use in isolating faults in battery operated systems. (±0.015) (81.0mm) Specifications: 0.88" Ratings • Volts 80Vdc or less • Amps 35-750A • IR 2700A Agency information • UL Recognized, Guide JFHR2, File E56412 • SAE J1171 ignition protected (35-500A) • RoHS compliant (22.2mm) 0.34" (±0.005) (8.7mm) Features: • Element visible through clear window to easily identify open status Recommended fuse blocks*: Description 1-pole open stud terminal block with nylon inserted locknuts 1-pole open stud terminal block with standard hex nuts Catalog number 4164 4164-FR * Blocks rated to 80Vdc and 800 amps. Size • 3.38” long, 09.5” wide, 1.62” tall Stud centers • 2.43” Technical Data 2024 ANL non-time-delay low voltage limiter Effective December 2015 100 35 50 80 100 130 150 200 225 275 325 400 350 500 Time-current curves – average melt: AMP RATING TIME IN SECONDS 10 1 CURRENT IN AMPS 10,000 1000 10 0.01 100 0.1 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2015 Eaton All Rights Reserved Printed in USA Publication No. 2024 — BU-MC15053 December 2015 Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
4164-FR 价格&库存
很抱歉,暂时无法提供与“4164-FR”相匹配的价格&库存,您可以联系我们找货
