Technical Data 1206
Effective December 2016
Supersedes December 1998
1BS101 modular fuse block, 600 V, 100 A
Agency information
UL® Recognized, Guide IZLT2, File E14853
CSA® Certified, Class 6225-01, File 47235
CE
RoHS compliant
Materials
Base - molded black phenolic, 150°C
Mounting bolts - zinc plated steel, 1/4-20 x 1/2”
Washer - zinc plated steel 1/4” Belleville
Connector: tin-plated aluminum
Conductors
Connector accepts single 14 AWG - 2/0 copper
or aluminum, solid or stranded wire
Torque
Catalog number:
1BS101
Description:
Bussmann™ series modular fuse block for bolton high speed, Class J (70-100 A), 600 V Class T
(70-100 A) and select BS88 fuses. See mounting
dimensions table for applicable Bussmann series
fuse catalog symbols. Dovetail interlock on each
side of the base allows mounting multiple poles
adjacent to one another.
Specifications:
Ratings
Volts - 600 V
Amps - 100 A
Withstand rating - 200 kA RMS Sym. or the
applied fuse interrupting rating, whichever is
less
Conductor setscrew - 13.6 N•m (120 Lb-in)
Fuse mounting bolt - 7.9 N•m (70 Lb-in)
Technical Data 1206
Dimensions: —mm/in
See Table 1 for A, B and C dimensions per fuse catalog symbol/ampacity.
Table 1. Mounting dimensions — mm (in)
CL
44.7
(1.76)
This block is furnished with an interlocking
dovetail feature as shown. When mounting
multiple fuseblocks side by side, center-tocenter distance between mounting holes
each pole is 44.58 (1.755).
CL
Maximum fuse blade width is 25.4 (1.0).
11.4
CLEARANCE FOR SCREW HEAD
(0.45)
5.1 X 7.7 MOUNTING HOLE SLOT FOR #10 SCREW
(0.20) (0.30)
INTERLOCKING
DOVETAIL TAB
11.2
(0.44)
16.8
(0.66)
'A'
REF.
22.4
(0.88)
10.4
(0.41)
50.8
(2.0)
34.8
(1.37)
26.7
(1.05)
10.4
(0.41)
7.1
(0.28)
39.62
(1.56)
7.6
(0.3)
5.1
(0.2)
'B'
REF.
39.62
(1.56)
MOUNTING
SURFACE
6.4
(0.25)
3.3
(0.13)
9.4
(0.37)
ANTI-ROTATION PIN
44.5
(1.75)
'C'
REF.
Bussmann series
fuse catalog
symbol
FWA-_A
FWH-_B
FWH-_B
FWX-_A
FWX-_A
KAC-_
KAC-_
KAC-_
KBC-_
KBC-_
LPJ-_SP-_SP
JJS-_
JKS-_
_L14C
_L09C
Amp
range
70-100
35-60
70-100
35-60
70-100
1-30
35-60
70-100
35-60
70-100
70-100
70-100
70-100
80-100
80-100
A
49.3 (1.94)
58.9 (2.32)
72.4 (2.85)
59.4 (2.34)
59.7 (2.35)
63.5 (2.50)
88.9 (3.50)
105.7 (4.16)
88.9 (3.50)
93.0 (3.66)
95.5 (3.76)
59.9 (2.36)
96.3 (3.79)
89.9 (3.54)
112.0 (4.41)
B
16.0 (0.63)
25.6 (1.01)
39.1 (1.54)
26.1 (1.03)
26.4 (1.04)
30.2 (1.19)
55.6 (2.19)
72.3 (2.85)
55.6 (2.19)
59.6 (2.35)
62.2 (2.45)
26.6 (1.05)
62.9 (2.48)
56.6 (2.23)
78.7 (3.10)
C
95.4 (3.75)
104.9 (4.13)
118.3 (4.66)
105.4 (4.15)
105.6 (4.16)
109.4 (4.31)
134.8 (5.31)
151.6 (5.97)
134.8 (5.31)
138.9 (5.47)
141.4 (5.57)
105.9 (4.17)
142.2 (5.60)
135.8 (5.35)
157.9 (6.22)
MOUNTING HOLE ARRANGEMENT
39.62
(1.56)
5.16 DIA.
(0.203)
39.62
(1.56)
9.53 DIA.
(0.375)
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are
by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit
distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once
a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
Eaton.com/bussmannseries
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 1206 — SB98107
December 2016
Eaton and Bussmann are valuable trademarks
of Eaton in the U.S. and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
CSA is a registered trademark of the Canadian
Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“1BS101”相匹配的价格&库存,您可以联系我们找货
