Technical Data 2101
Effective March 2021
Supersedes June 2017
S-8000
1/4” x 1-1/4” Fuse blocks
Ordering part number
Bolt-in mounting
BK-S-8 1 02-6 -R
Packaging prefix
Family name
Product features
Terminal type:
For 1/4” x 1-1/4” (6 x 32 mm) fuses
High voltage rating (Up to 600 V)
Bolt-in, snap-in and DIN-rail mounting available
Number of poles:
Compact, tight cluster mounting
RoHS compliant
Multiple types of terminal options
Clips are made of bright tin-plated, spring
bronze
Anti-rotational pin available
Thermoplastic base meets UL94 V-0
Terminal angle:
Snap-in and DIN-rail mounting
BK-S-8 0 01-1 SNP-R
Packaging prefix
Agency information
Family name
UL Recognized: E14853
Terminal type:
CSA Certified: 47235
Terminal angle:
Number of poles:
Mounting style:
RoHS compliant
Environmental compliance
General specifications
Relative Temperature Index (RTI)
• Bolt-in +130 °C
Snap-in +110 °C
Packaging prefix
Blank- (Qty varies with number of poles)
BK- (QTY varies with number of poles)
Terminal type: 0= solder
1= 3/16” quick connect
2= 1/4” quick connect
3= screw
Terminal angle: 01= straight
02= 40° angle
03= side*
Number of poles: (1 - 12)
1X= One pole, No mounting stud
Mounting style: SNP**= Snap-in mounting*
DIN**= DIN-rail mounting
*Available only in single pole and 3/16” or 1/4” quick
connect terminals
** Available in single pole only
S-8000
Technical Data 2101
Specifications
Family
UL voltage
rating
(V)
UL current
rating
(A)
CSA voltage
rating
(V)
CSA current
rating
(A)
S-8000
600
30
300
21
S-8100
600
13
S-8200
600
30
300
16
S-8300
600
30
300
25
Dimensions- mm/inches
S-8000 Single pole bolt-in mounting
S-8000 Single pole snap-in mounting
40° Angle
terminal
40° Angle
terminal
Straight
terminal
Straight
terminal
Side
terminal
Screw
terminal
Mounting
Side
terminal
Mounting
Multiple pole
Mounting dimensions
ple pole
2
www.eaton.com/electronics
Number
of poles
A (inches)
B (inches)
A (mm)
B (mm)
1
2
1 1/8”
5/8”
28.6
15.9
3
1 3/4”
1 1/4”
44.4
31.8
4
2 3/8”
1 7/8”
60.3
47.6
5
3”
2 1/2”
76.2
63.5
6
3 5/8”
3 1/8”
92.1
79.4
7
4 1/4”
3 3/4”
108
95.2
8
4 7/8”
4 3/8”
123.8
111.1
9
5 1/2”
5”
139.7
127
10
6 1/8”
5 5/8”
155.6
142.9
11
6 3/4”
6 1/4”
171.4
158.8
12
7 3/8”
6 7/8”
187.3
174.6
S-8000
Technical Data 2101
DIN-rail mounting
B
A
C
Part number
A (inches)
B (inches)
C (inches)
A (mm)
B (mm)
C (mm)
BK-S-8002-1X-DIN
2
0.5
1.31
50.8
12.7
33.3
BK-S-8102-1X-DIN
2
0.5
1.31
50.8
12.7
33.7
BK-S-8202-1X-DIN
2
0.5
1.31
50.8
12.7
33.3
BK-S-8301-1X-DIN
2.189
0.5
1.31
55.6
12.7
33.3
BK-S-8103-1X-DIN
1.693
0.953
1.31
43
24.2
33.3
BK-S-8203-1X-DIN
1.693
0.953
1.31
43
24.2
33.3
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2021 Eaton
All Rights Reserved
Printed in USA
Publication No. 2101
March 2021
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BK/S8103-1SNP-R”相匹配的价格&库存,您可以联系我们找货
