BK1/HTC-50M
BK1/HTC-50M
    EATON(伊顿)
    BK1/HTC-50M
BK1/HTC-50M 数据手册
Technical Data 2110 Effective August 2020 Supersedes April 2020 HTC PCB Fuse accessories for 5 mm fuses PCB Fuse blocks Dimensions- inches (mm) HTC-15M • UL 4248 rating: 250 V, 20 A • IEC 60217-6 rating: 250 V, 6.3 A, 1.6 W • Self-certified voltage rating: 500 V, 20 A • Tin plated brass terminals • cURus: Guide IZLT2 & IZLT8, File # 14853 • Cover available: 1.047" (26.6mm) .354 " (9.0mm) HTC-140M Cover .571 " (14.5mm) .217 " (5.5mm) .531 " Mounting Holes (13.5mm) .890 " .866 " (22.60mm) (22.0mm) _ .002" Dia. (Typ.) .059 " + .177 " HTC-150M (Transparent) Flammability rating: UL94-V2 • (1.50 _+ . 05mm) (4.5mm) HTC-140M (Beige/Natural) Flammability rating: UL94-V0 • • IEC 60127-6 rating: 250 V, 6.3 A, 1.6 W • Self-certified voltage rating: 500 V, 20 A • cURus: Guide IZLT2 & IZLT8, File # 14853 • 90 0.5 mm) (1.5 0.0197 x 0.047 (0.5 x 1.2mm) 0.890 (22.6mm) 0.890 (22.6mm) Mounting holes 0.039 (1.0mm) UL 4248 rating: 250 V, 20 A 0.138 (3.5mm) • 0.453 (11.5mm) HTC-78M 0.413 (10.5mm) 0.370 (9.4mm) 0.961 (24.4mm) Cover available: HTC-100M Flammability rating: UL94-V0 • .886" .354" (22.5mm) .551" IEC 60127-6 rating: 250 V, 6.3 A, 1.6 W • Tin plated bronze terminals PCB Fuse clips .319" .177" (4.5mm) .50" (8.1mm) (12.7mm) BUSS • (1.3mm) .138" (3.5mm) BUSS UL 4248 rating: 250 V, 20 A BUSS • (15.0mm) .102" Dia. Hole (2.6mm) .051" Dia. Hole (3.5mm) HTC-60M .591" (9.0mm) .157" (3.99mm) .929" (23.6mm) .61" (15.5mm) HTC-200M • Tin plated bronze • Tape and fan fold packed .031" (.79mm) .012" .217" (.3mm) (5.5mm) .50" .50" (12.7mm) (12.7mm) 4.32mm 2.54mm 8.73mm 2.29mm 2.54mm 6.26mm HTC-210M • Tin plated brass 3.91mm 6.22mm 2.85mm 1.46mm 2.54mm HTC PCB Fuse accessories for 5 mm fuses  Technical Data 2110 Effective August 2020 PCB Fuse holders Dimensions- inches (mm) HTC-45M • 1.303" (33.1mm) max* .512 " 250 V, 10 A, 2.5 W Mounting Holes Not recommended for new designs. Recommended repalcement is H15 (13.0mm) • Bayonet cap/carrier • Operating temperature range: -30 °C to + 85 °C • cURus: Guide IZLT2 & IZLT8 File # 14853 F U SE .461 " (11.7mm) .394 " Printed Circuit Board (10.0mm) .051 _ _ .05mm ) ( 1.30 + Dia. (Typ.) * Maximum dimension with fuse is installed HTC-50M • 250 V, 10 A, 2.5 W • Bayonet cap/carrier .512 " • Operating temperature range: -30 °C to + 85 °C • cURus: Guide IZLT2 & IZLT8 File # 14853 (13.0mm) FU 1.303" (33.1mm) max* SE Mounting Holes _ .002" Dia. (Typ.) .051 " + _ .05mm ) ( 1.30 + .461 " (11.7mm) .394 " Printed Circuit Board (10.0mm) * Maximum dimension with fuse is installed Common HTC specifications • Solerability: In accordance with IEC 68-2-20 • Molded materials: UL94 V-0 Packaging codes Packaging code prefix Description Blank 10 pieces packed into a carton (HTC-15M and HTC-60M only)) BK- 100 pieces packed into a cardboard shelf package (HTC-15M and HTC-60M only) BK1- 1000 pieces packed into a poly bag AP 1000 pieces per box in Ammo pack (HTC-200M only) Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2020 Eaton All Rights Reserved Printed in USA Publication No. 2110 August 2020 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
BK1/HTC-50M 价格&库存
很抱歉,暂时无法提供与“BK1/HTC-50M”相匹配的价格&库存,您可以联系我们找货
