Fuse Clips with Mounting Holes
5000
Series
For 1/4˝, 9/32˝, 13/32”, and 9/16˝ Diameter Fuses
Dimensional Data
B
C
C
D
D
• Beryllium copper is by far the most satisfactory metal yet
discovered for use in fuse clips. It has the ability to retain
spring pressure better than any other metal under high
current and high ambient conditions. It also has
exceedingly high electrical conductivity.
E
E
Figure 2
Figure 1
1/4˝ Diameter Fuses
Catalog
Number
End Clip
Stop Mat.**
5681-08
No
No
B (To
Finish
Spg. Br. Nickel
5681-15-R
Spg. Br. Bright Tin
5682-01
BeCu
Silver
5682-02
BeCu
Silver
5682-11
Yes BeCu
Yes
5682-41-R
5682-44-R
Albaloy
C
End Stop) (Contact)
0.41
0.265
0.32
0.132 2
0.108
0.132
0.262
0.41
0.32
0.132 1
Catalog
Number
End Clip
Stop Mat.** Finish
5956-16
No
B (To
C
Dimensions (Inches)
D
E
End Stop) (Contact) (Height) (Width)
Hole Fig.
Dia. Ref.
0.172 2
Spg. Br. Bright Tin
5960-07
BeCu
Silver
0.168
0.196
5960-09
BeCu
Silver
0.20
0.172
5960-44
Spg. Br. Nickel
0.20
5960-51
Yes Spg. Br. Bright Dip* 0.168
Yes Spg. Br. Bright Dip* 0.20
0.312
0.71
0.47
0.197
0.196
0.387
0.71
0.47
0.172 1
Spg. Br. Bright Tin 0.106
5960-53
Spg. Br. Bright Tin 0.132
5960-61-R
Spg. Br. Bright Tin
0.168
0.196
5960-62-R
Spg. Br. Bright Tin
0.168
0.132
5960-63-R
Spg. Br. Bright Tin
0.20
0.172
5960-64-R
Spr. Br. Bright Tin
0.20
0.128
End Clip
Stop Mat.**
B (To
Finish
Spg. Br. Bright Tin †
5674-01
BeCu
Yes BeCu
5674-10 Yes
C
Dimensions (Inches)
D
E
End Stop) (Contact)
5672-11 No
5674-41
13/32˝ Diameter Fuses
Dimensions (Inches)
D
E
Hole Fig.
(Height) (Width) Dia. Ref.
9/32˝ Diameter Fuses
Catalog
Number
• Clips are made of a spring bronze of distinctly superior
quality. This metal gives clips great gripping strength and
ability to retain fuses under adverse conditions.
0.362
Hole Fig.
Catalog
Number
0.52
5591-42
0.38
0.172 2
Bright Tin 0.168
Yes
5591-52
Silver
0.356
Spg. Br. Bright Tin
0.52
0.38
0.172 1
Dimensions (Inches)
D
E
Hole Fig.
End Stop) (Contact) (Height) (Width) Dia. Ref.
End Clip
Stop Mat.** Finish
5592-01
No
5592-11 No
B (To
C
0.26
0.51
0.89
0.60
0.252
0.56
0.89
0.60
Spg. Br. Bright Tin
BeCu
Silver
Spg. Br. Silver
0.172 1
0.20
2
0.20
* Bright Dip is actually treated bare metal with no plating.
** Spg. Br. — Spring Bronze; BeCu — Beryllium Copper.
† Hole in center of both clip and contact area.
The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of
this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of
any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
© 2012 Cooper Bussmann
St. Louis, MO 63178
www.cooperbussmann.com
1012 BU-SB08760
Page 1 of 1
Data Sheet 2132
很抱歉,暂时无法提供与“5682-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 16+48.0648716+6.19240
- 80+43.2408480+5.57090
- 国内价格
- 1+7.90560
- 200+3.06720
- 500+2.95920
- 1000+2.90520
- 国内价格 香港价格
- 100+33.64646100+4.33482
