BK/PCT-A
BK/PCT-A
    EATON(伊顿)
    BK/PCT-A
BK/PCT-A 数据手册
Bussmann® Printed Circuit Board Fuseholder PCT-A For GMT Fuses CATALOG SYMBOL: PCT-A FUSEHOLDER 125 VOLTS FOR USE WITH GMT FUSES Materials: Thermoplastic U.L. Flammability: 94 VO Terminals: 0.025 x 0.062 Plating: Bright Tin DUMMY FUSE NOT INCLUDED Dimensional Data ALARM TERMINAL 0.250 (REF.) FUSE TERMINAL 0.840 (REF.) FUSEHOLDER BODY 0.640 (REF.) 0.450 0.250 (REF.) (REF.) 0.438 0.110 (2 PLACES) HOLE PATTERN GAUGE 0.450 +0.002 0.450 +0.002 0.700 +0.002 0.101 DIA. HOLE (TYP. - 3 PLACES) The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 12-28-98 SB98107 Rev. A Form No. PCT-A Page 1 of 1 BIF Doc #2117
BK/PCT-A 价格&库存
很抱歉,暂时无法提供与“BK/PCT-A”相匹配的价格&库存,您可以联系我们找货
BK/PCT-A
  • 1200+74.257151200+9.63723
